[waves2Foam] Compilation of waves2FoamMooring on OF-1912
Old   October 7, 2021, 13:12
Default Compilation of waves2FoamMooring on OF-1912
Carlos Eduardo Simőes de Almeida
cesa is on a distinguished road
Hello everyone,
I'm trying to compile the tool waves2FoamMooring on OF1912, but I can't. This is the error output:
write1DFvMesh/write1DFvMesh.C: In member function ‘void Foam::write1DFvMesh::updateMesh(const Foam::List<Foam::Field<Foam::Vector<double> > >&, const labelList&, const labelList&, const labelList&, const labelList&)’:
write1DFvMesh/write1DFvMesh.C:225:9: error: ‘Xfer’ was not declared in this scope
Xfer<pointField> xpp;
write1DFvMesh/write1DFvMesh.C:225:24: error: expected primary-expression before ‘>’ token
write1DFvMesh/write1DFvMesh.C:225:26: error: ‘xpp’ was not declared in this scope
write1DFvMesh/write1DFvMesh.C:225:26: note: suggested alternative: ‘lpp’
lpp
write1DFvMesh/write1DFvMesh.C:231:22: error: expected primary-expression before ‘>’ token
Xfer<faceList> xfaces;
write1DFvMesh/write1DFvMesh.C:231:24: error: ‘xfaces’ was not declared in this scope
write1DFvMesh/write1DFvMesh.C:231:24: note: suggested alternative: ‘face’
face
write1DFvMesh/write1DFvMesh.C:280:22: error: expected primary-expression before ‘>’ token
Xfer<cellList> xcells;
write1DFvMesh/write1DFvMesh.C:280:24: error: ‘xcells’ was not declared in this scope
write1DFvMesh/write1DFvMesh.C:280:24: note: suggested alternative: ‘cell’
cell
make: *** [/home/carlos/OpenFOAM/OpenFOAM-v1912/wmake/rules/General/transform:35: Make/linux64GccDPInt32Opt/write1DFvMesh/write1DFvMesh.o] Error 1
It looks like the Xfer function disappeared from OF-v1912, although users can find it in OF-v1712. Is there any way of compiling this utility on OpenFOAM v1912?
Best regards,
Carlos
cesa is offline   Reply With Quote
Old   October 7, 2021, 16:46
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Carlos,
I am pretty sure that it can be compiled, but you most likely need to dive into the code and correct for the changes in syntax.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 3, 2022, 06:28
Pere
katiuskas is on a distinguished road
Hi Carlos,
Have you tried removing the Xfer container declaration? So instead of
pointField& pp = xpp();
Just write:
pointField pp;
And when creating the fvMesh, try using std::move :
        oneDFvMeshPtr_ = new fvMesh
            IOobject
                meshName_,
                mesh_.time().constant(),
                mesh_.time(),
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            std::move(pp),
            std::move(faces),
            std::move(cells)
Let me know if that worked for you!
katiuskas is offline   Reply With Quote
[foam-extend.org] foam-extend-3.2 compilation on windows kirmaks OpenFOAM Installation 7 December 3, 2019 20:20
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit Sargam05 OpenFOAM Installation 13 March 22, 2014 05:21
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 05:56
Caseinsensitive unpacking and windowsmacos niklas OpenFOAM Installation 61 April 14, 2008 09:15
Compilation Error.... Arnab Siemens 4 September 12, 2004 15:54
