[cfMesh] I can't create sharp edge mesh by cfMesh
Like Tree1Likes
  • 1 Post By franjo_j
Old   June 1, 2015, 09:13
Default I can't create sharp edge mesh by cfMesh
Choi Hak Kyu
prodo is on a distinguished road
I am a beginner in cfMesh.
Using Geometry file, I want to create a mesh with a sharp edge.
However, I can't make.
no matter how, setting smaller the size of the mesh.
I made .stl file by Gridgen.
What should I do?
Please refer to the attached figure.
Thank you for your help
This is my very simple meshDIct
| \\      /  F ield         | cfMesh: A library for mesh generation          |
|  \\    /   O peration     |                                                |
|   \\  /    A nd           | Author: Franjo Juretic                         |
|    \\/     M anipulation  | E-mail: franjo.juretic@c-fields.com            |
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
surfaceFile "7_KCS_Hull_Cylinder.ftr";
maxCellSize 0.7;
surfaceMeshRefinement
    insideSlider
        additionalRefinementLevels  3;
        surfaceFile "5_KCS_Cylinder.ftr";
        refinementThickness 0.05;
    //cellSize 0.3;
    Bow
        additionalRefinementLevels 6;
        surfaceFile "3_KCS_Bow.ftr";
    //cellSize 0.001;
    Stern
        surfaceFile "1_KCS_Stern.ftr";
    //cellSize 0.001;
    Rudder
        surfaceFile "4_KCS_Rudder.ftr";
    //cellSize 0.001;
    Center
        additionalRefinementLevels  5;
        surfaceFile "2_KCS_Center.ftr";
    //cellSize 0.1;
prodo is offline   Reply With Quote
Old   June 2, 2015, 09:01
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
The are two ways of handling features in cfMesh, and these are:
1. Boundaries between two patches in the surface mesh.
2. By marking edges in the surface mesh as feature edges in the fms file.
You can generate it by using surfaceFeatureEdges utility. Please check the manual and the ship5415Octree example.
surfaceFeatureEdges <inputSurf> <outputSurf>.stl -angle 40 generates a new stl file with patches bounded by selected feature edges.
surfaceFeatureEdges <inputSurf> <outputSurf>.ftr -angle 30 generates a ftr file with patches bounded by selected feature edges.
surfaceFeatureEdges <inputSurf> <outputSurf>.fms generates a fms file with selected feature edges and leaves the patches intact.
-angle is optional.
You can export fms to vtk by using FMSToVTK or FMSToSurface, when you want to visualise it in ParaView.
Regards,
Franjo
namsivag likes this.
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
Old   June 2, 2015, 09:54
Arrow
Choi Hak Kyu
Thank you for your answer, Franjo.
I already solve this problem by using surfaceFeatureEdges utility
I was seperate Hull surface and Plane surface by small feature angle.
and then I can obatin much better mesh around the boundary like Fig.1 and 2
But, there is another problem from small feature angle
1. Due to small feature angle, It create many useless small surface. like Fig3
2. Also, I can't create boundary layer around Hull, It works only around outer circle and this is significant problem for me.
3. It is not working boundary layer for seperated surface?
Can you give me some tips for this problem?
Thank you
This is my meshDict
|  \\    /   O peration     |                                                |
FoamFile
    version   2.0;
    format    ascii;
    class     dictionary;
    location  "system";
    object    meshDict;
maxCellSize 0.7;
//enforceGeometryConstraints 1;
boundaryCellSize   1;
boundaryCellSizeRefinementThickness 50;
objectRefinements
    box
    cellSize 0.005;
    type box;
    centre (3.12481351 0 -0.13085746);
    lengthX 0.5;
    lengthY 0.5;
    lengthZ 0.5;
boundaryLayers
//    nLayers 4;
//    thicknessRatio 1;
//    maxFirstLayerThickness 0.1;
    patchBoundaryLayers
        "ascii_file_exported_from_Gridgen_82"        //outer
            nLayers 3;
            thicknessRatio 1;
            allowDiscontinuity 1;
        "ascii_file_exported_from_Gridgen_76"        //inner
            nLayers 3;
            thicknessRatio 1;
        "ascii_file_exported_from_Gridgen_83"        //slider
            nLayers 3;
            thicknessRatio 1;
        "ascii_file_exported_from_Gridgen_81"        //top
            nLayers 3;
            thicknessRatio 1;
        "ascii_file_exported_from_Gridgen_78"        //Rudder side
            nLayers 3;
            thicknessRatio 1;
        "ascii_file_exported_from_Gridgen_79"        //Rudder side
            nLayers 3;
            thicknessRatio 1;
        "ascii_file_exported_from_Gridgen_80"        //Rudder side
            nLayers 3;
            thicknessRatio 1;
    insideSlider
    //cellSize 0.3;
    Bow
    //cellSize 0.001;
    Center
    //cellSize 0.1;
    Stern
    //cellSize 0.001;
    Rudder
        additionalRefinementLevels  8;
    //cellSize 0.001;
    Cap
        surfaceFile "9_KCS_Cap.ftr";
    //cellSize 0.001;
Old   June 2, 2015, 12:07
Franjo Juretic
Edge extraction may not be perfect when the surface mesh is not of good quality. You can play with the angle tolerance and find out what works best for your problem. Alternatively, you could try exporting the geometry as separate stl solids and merge them together into a single file.
I guess that you have a symmetry plane in your geometry. That is risky, and may merge the layer at the hull with the layer the symmetry plane.
There are rules how layers behave, and you can find read about them here: http://www.cfd-online.com/Forums/ope...rs-cfmesh.html
Regards,
Franjo
www.cfmesh.com
Old   June 10, 2015, 21:34
Choi Hak Kyu
As you say, i was seperate the geometry by small parts
and then, use surfaceFeatureEdges utility,
so, I can get the proper geomerty and .ftr files.
Finally, merged all surface by using surfaceAdd utility.
regards,
Old   November 11, 2015, 03:42
Giovanni
Gio Baila is on a distinguished road
Send a message via Skype™ to Gio Baila
Hi guys,
thank you Franjo,
I guess I'm having the same kind of problem and I would like to summarize the correct procedure for ship hull meshing. Considering that the starting point is a boolean difference between the ship and the symmetric domain, you suggest to:
1- Separate by hand the complete .stl in order to have different files, each one with a patch;
2- Apply surfaceFeatureEdges to each single file and save the content as .ftr (why not fms?)
3- Merge the .ftr with surfaceAdd (in which format?? still ftr??)
4- Create the mesh
Is it correct?
Why even if you use directly the surfaceFeatureEdge on the complete .stl file and you have the different patches as you want, the normals on the symmetryPlane gets screwed up after the meshing process??
Ciao,
Giovanni
Gio Baila is offline   Reply With Quote
Skewness , Minimum Edge Length and Mesh Quality in FLuent ViLaks FLUENT 2 March 2, 2017 05:57
3D Airfoil with Sharp Trailing Edge - Mesh Help Toofanian CFD Freelancers 1 August 15, 2016 18:03
[ANSYS Meshing] 3D Airfoil with Sharp Trailing Edge - Mesh Help Toofanian ANSYS Meshing & Geometry 0 August 8, 2016 19:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
