[cfMesh] Meshing thin cutouts with cfMesh
Old   August 14, 2015, 05:09
Default Meshing thin cutouts with cfMesh
bjoernsu is on a distinguished road
I try to mesh a fluid with a subtracted duct (see Picture 1) by using cfMesh.
But there is always the Problem, that cfMesh ignore my cutout (see Picture 2).
I used surfaceFeatureEdges to get sharp edges at the fluid and surfaceMeshRefinement with the duct as .stl to get a finer mesh in this Region.
Has someone an idea how I can get a good mesh?
Best regards,
Björn
bjoernsu is offline   Reply With Quote
Old   August 20, 2015, 16:20
Default Remove cells near the cut-out
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
The cells near the cut-out are larger than the gap itself. Hence, pMesh does not resolve the gap because the initial mesh is designed to such that it is slightly larger that the domain that shall be meshed. This criterion results in the mesh being glued over the thin gap.
This problem can be solved either by refining the mesh such that the cells become smaller than the gap, or by using the removeCellsIntersectingPatches option for the patches at the cut-out. The second option will remove the cells intersecting the cut-out, and make the topology of the mesh similar to the geometry.
I hope this clarifies the cause of your problems.
Regards,
Franjo Juretic
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
Old   January 14, 2016, 22:20
Derwin Parkin
derz is on a distinguished road
hi Franjo,
Does removeCellsIntersectingPatches also help for dealing with baffles? Or is there another way to go about that?
I have a thin baffle surface in my geometry and I'm wondering what the best way to account for it in cfMesh is...
derz is offline   Reply With Quote
Old   January 15, 2016, 04:20
Franjo Juretic
removeCellsIntersectingPatches is an instruction for removing cells intersecting specified objects. In most cases, it is needed only when the cell size is larger than the features in a given region.
Baffles do not have a volume, and by using keepCellsIntersectingBoundary option, it is not possible resolve them irrespective of the selected cell size.
With baffles, the biggest problems are boundary edges, and the best way to overcome the problem is to extrude baffles into a volume, to avoid boundary edges.
Regards,
Franjo
www.cfmesh.com
Old   October 13, 2020, 13:43
Default extrude baffles into a volume
ves
Veskov Eugene
ves is on a distinguished road
Hi!
How I may extrude baffles into a volume in cfmesh
ves is offline   Reply With Quote
Help with meshing thin regions for fluid flow BarryS STAR-CCM+ 1 May 22, 2013 04:54
thin extrusion meshing guillaume Siemens 3 November 4, 2008 08:53
thin extrusion meshing guillaume Phoenics 0 October 27, 2008 18:39
thin extrusion meshing guillaume Fidelity CFD 0 October 27, 2008 18:39
thin extrusion meshing guillaume Main CFD Forum 0 October 27, 2008 18:36
