[cfMesh] cfMesh-v1.1.1
Like Tree7Likes
Old   December 23, 2015, 08:57
Tomislav Lugarić
tlugaric is on a distinguished road
Hi Ahmad!
Glad to hear you like our cfMesh mesher.
From your log I can see that it is complaining about missing "zlib.h" header file, so the "wmakeLnInclude" command does not do what it is supposed to.
You should install the zlib development package and try again. I don't know which Linux distro you are using, on Ubuntu you would type: "sudo apt-get install zlib1g-dev" for example.
As for the .run file, please tell me the name of the installer file, as well as which linux version you are using, so I can try to reproduce your problem.
If you asked the installer to install cfMesh source, it instals the OpenFOAM source as well, because cfMesh source relies on some parts of OpenFOAM.
After installing cfMesh, did you try to run it from your default terminal, or did you use the shortcuts placed on you deskop? If you try to launch it from your terminal, you need to source the installed cfMesh environment first (source [cfMesh_install_dir]/OpenFOAM-2.3.0/etc/bashrc) before you can use cfMesh.
Let me know if this helps
a_habib likes this.
Lead software developer at Creative Fields
Social media: Facebook, Twitter, LinkedIn, Google+, Pinterest, YouTube
tlugaric is offline   Reply With Quote
Old   December 23, 2015, 10:08
a_habib's Avatar
Ahmad Habib
a_habib is on a distinguished road
Hi Tomislav,
First of all, I'm using ubuntu 12 and I didn't take care to look at my desktop,
I tried the .run version and used the desktop shortcut and it worked.
Then I un-installed it and installed zlib.h as you suggested and then compiled the source version and it is working now.
Thanks a lot, and yes it is a great mesher. its easy and provides us several types of meshes. but I think tha the documentation still a little bit insufficient.
Keep up the good work.
P.S. my name is ahmad
a_habib is offline   Reply With Quote
Old   December 23, 2015, 10:55
Tomislav Lugarić
Hi Ahmad!
I am sorry for mistaking your name, I was reading an older post and got the names confused. I edited the post.
We have some more materials on our website cfmesh.com, and we will be providing some video tutorials in the near future. Feel free to check it out.
a_habib likes this.
Old   June 11, 2016, 04:12
crixman's Avatar
Christian
crixman is on a distinguished road
I installed foam-mesh for OF2.2.2. and foam-extend 3.1 and 3.2 without problems.
I am instead experiencing a problem with OF3.0.x - I got the following error - have to tested the installation for OF3.0.x or are you working now on that?
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -DUSE_OMP -fopenmp -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/triSurface/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/edgeMesh/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -c utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.C -o Make/linux64GccDPInt64Opt/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.o
In file included from lnInclude/DynList.H:233:0,
                 from lnInclude/VRWGraph.H:42,
                 from lnInclude/meshSubset.H:40,
                 from lnInclude/polyMeshGenPoints.H:42,
                 from lnInclude/polyMeshGenFaces.H:40,
                 from lnInclude/polyMeshGenCells.H:40,
                 from lnInclude/polyMeshGen.H:39,
                 from utilities/meshes/polyMeshGenModifier/polyMeshGenModifier.H:40,
                 from utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.C:28:
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = long int; long int staticSize = 16l]’:
lnInclude/helperFunctionsTopologyManipulationI.H:491:34:   required from here
lnInclude/DynListI.H:136:21: error: request for member ‘size’ in ‘l’, which is of non-class type ‘const int’
     setSize(l.size());
lnInclude/DynListI.H:138:32: error: subscripted value is neither array nor pointer
         this->operator[](i) = l[i];
lnInclude/DynListI.H: In instantiation of ‘Foam::DynList<T, staticSize>::DynList(const ListType&) [with ListType = int; T = Foam::Vector2D<double>; long int staticSize = 6l]’:
lnInclude/helperFunctionsGeometryQueriesI.H:1059:37:   required from here
     setSize(l.size());
make: *** [Make/linux64GccDPInt64Opt/utilities/meshes/polyMeshGenModifier/polyMeshGenModifierAddBufferCells.o] Error 1
make[1]: Entering directory `/home/chris/cfMesh-v1.1.1/executables/cartesian2DMesh'
Making dependency list for source file cartesian2DMesh.C
make[1]: Leaving directory `/home/chris/cfMesh-v1.1.1/executables/cartesian2DMesh'
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/triSurface/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/finiteVolume/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -c cartesian2DMesh.C -o Make/linux64GccDPInt64Opt/cartesian2DMesh.o
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3  -DNoRepository -ftemplate-depth-100 -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/triSurface/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/finiteVolume/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/edgeMesh/lnInclude -I../../meshLibrary/lnInclude -IlnInclude -I. -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/home/chris/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt64Opt/cartesian2DMesh.o -L/home/chris/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt64Opt/lib \
        -lmeshTools -ltriSurface -lfiniteVolume -ledgeMesh -L/home/chris/OpenFOAM/chris-3.0.x/platforms/linux64GccDPInt64Opt/lib -lmeshLibrary -lOpenFOAM -ldl  \
         -lm -o /home/chris/OpenFOAM/chris-3.0.x/platforms/linux64GccDPInt64Opt/bin/cartesian2DMesh
/usr/bin/ld: cannot find -lmeshLibrary
collect2: error: ld returned 1 exit status
make[1]: *** [/home/chris/OpenFOAM/chris-3.0.x/platforms/linux64GccDPInt64Opt/bin/cartesian2DMesh] Error 1
make: *** [cartesian2DMesh] Error 2
crixman is offline   Reply With Quote
Old   June 11, 2016, 06:19
Tomislav Lugarić
Hi crixman
Our cfMesh installer is tested with OpenFOAM 2.3.x, and is not guaranteed to work with OpenFOAM 3.0.x. We are working on an installer for OpenFOAM 3.0.x.
Old   July 22, 2016, 02:58
Quinn Reynolds
kittychunk is on a distinguished road
Originally Posted by tlugaric View Post
Hi crixman
...and one for OpenFOAM 4.0 as well, I hope
kittychunk is offline   Reply With Quote
Old   July 22, 2016, 06:50
Franjo Juretic
franjo_j is on a distinguished road
Send a message via Skype™ to franjo_j
Hi kittychunk, we have updated the development branch in the repository at Sourceforge it now compiles with OpenFOAM 4.0 - you can give it a try and let us know if you notice any problems.
Principal Developer of cfMesh and CF-MESH+
www.cfmesh.com
Social media: LinkedIn, Twitter, YouTube, Facebook, Pinterest, Instagram
franjo_j is offline   Reply With Quote
Old   July 22, 2016, 08:11
Quinn Reynolds
Thank you very much Franjo - the development branch compiled fine with OpenFOAM 4.0.
Old   August 3, 2016, 23:10
Ali
ashim is on a distinguished road
Hi Dr. Franjo Juretic,
I am trying to compile cfMesh (development brach ) for OpenFOAM -dev version in Ubuntu 14.10 and REHL 7.0. But I could not compile it yet. I am getting errors mostly related to the mesh library file DynListI.H. Would please have a look into it.
Thanks,
Ali
ashim is offline   Reply With Quote
Old   September 27, 2016, 06:24
Laurent Fitschy
GDTech is on a distinguished road
Dear Ali,
recent changes in dynamic list have been pushed to OpenFoam-dev.
The solution is to replace
 this->UList<T>::operator=(
by
 this->shallowCopy(
on lines 42, 55 and 67 in DynListI.H
Best regards
GDTech is offline   Reply With Quote
Old   September 27, 2016, 22:28
Ali
Hi Laurent Fitschy,
Thank you very much for you time. The problem is fixed in other way. When I was cloning the code, somehow I was getting older version. But when I have downloaded it as a snapshots and compile it, it works perfectly.
Regards
Ali
Old   November 28, 2017, 07:24
Lennart
elmo555 is on a distinguished road
I'm trying to build the latest cfMesh (cfMesh-v1.1.2) with the latest OpenFOAM release (OpenFOAM-v1706), but some files seem to have changed, to the compilation fails:
In file included from ../../meshLibrary/lnInclude/triSurf.H:41:0,
                 from checkSurfaceMesh.C:32:
../../meshLibrary/lnInclude/triSurfFacets.H:42:39: fatal error: geometricSurfacePatchList.H: No such file or directory
 #include "geometricSurfacePatchList.H"
What's the latest known version of cfMesh and OpenFOAM that compile? Any help is appreciated!
elmo555 is offline   Reply With Quote
[cfMesh] CFMesh for blue core CFD naveen.hariprasad OpenFOAM Community Contributions 2 March 4, 2018 16:11
[cfMesh] Parallel meshing in cfMesh v1.1.1 in windows naveen.hariprasad OpenFOAM Community Contributions 0 December 16, 2016 03:24
[cfMesh] feature edge error zordiack OpenFOAM Community Contributions 3 October 11, 2016 06:09
[cfMesh] overlapping problem using cfMesh v1.1.1 pici OpenFOAM Community Contributions 2 November 3, 2015 13:51
[cfMesh] mesh improvements for 'face tets' pici OpenFOAM Community Contributions 1 September 2, 2015 04:31
