[swak4Foam] Temperature dependent heat transfer coefficient with groovybc
Old   November 5, 2015, 20:07
Default Temperature dependent heat transfer coefficient with groovybc
P_P
P_P is on a distinguished road
I try to approximate heat loss in a rectangular bubble Column due to convection. In order to do so, I use the groovy boundary condition in OpenFOAM. The bubble column which consists of acrylic glass is insulated with styropor. At t=0 the bubble column contains water with a temperature of 46°C. As time progresses, the bubble column is fed with air which has a temperature of 18°C. The direct consequence is that the water temperature drops. In order to simulate this heat loss I used groovybc:
type                           groovyBC;
value                         uniform 319.15;
variables "k_1=0.597;htot=1/(0.03/0.035+0.01/0.19+1/0.021);Tinf=291.15;";
valueExpression             "Tinf";
fractionExpression     "1.0/(1.0+k_1/mag(delta())*1/htot)";
The number 0.021 represents the external heat transfer coefficient due to natural convection. In order to describe the heat loss more precisely, I would like to update the external heat transfer coefficient after each timestep. Therefore I need to access the nodetemperatures which are closest to the inner wall. Has someone got an idea how this problem can be handled during the simulation?
Greetings
P_P
P_P is offline   Reply With Quote
Heat Transfer Coefficient not changing with fluid temperature/ Wall temperature seshu1353 FLUENT 4 December 1, 2016 09:02
Multiphase heat transfer pkladisios CFX 8 June 7, 2016 01:41
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 13:32
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Question on heat transfer coefficient!!! Benny FLUENT 7 June 7, 2005 09:25
