[waves2Foam] waves2foam freezing when starting time loop...
Old   June 13, 2018, 17:27
Default waves2foam freezing when starting time loop...
Peter Ladefoged
PeterL89 is on a distinguished road
Dear Niels,
First of all I would like to say that I really enjoy working with waves2foam and I am eager to learn as I will be using OpenFOAM for my master thesis. So thank you in helping developing this toolbox and manual for unexperienced users as myself...
I am currently working on a special course at DTU and experiencing a problem with the tutorials - not all tutorials however, as standingWave is working fine.
I am using OpenFOAM v1712 and running via the cluster on the gbar.
My problem is that when I try to run for instance the waveFlume or bejiBattjes tutorial I can run the first commands, i.e. blockMesh, waveGaugesNProbes, setWaveParameter, setWaveField all work. However when I get to running the solver waveFoam the terminal freezes at the "starting time loop" and no iterations follow...
I have figured out that the solver will run however if I delete the last function lines in the controlDict file :
functions
#includeIfPresent "../waveGaugesNProbes/surfaceElevationAnyName_controlDict;
I therefore suspect there might be a problem with the waveGaugesNProbes?
Do you have any suggestions as to what might be the problem I am facing?
Kind Regards
Peter
PeterL89 is offline   Reply With Quote
Old   February 10, 2020, 07:16
Jinshi Chen
JinshiC is on a distinguished road
Hi did you figure out the reason behind this? I am having similar situation right now. However, my solver still freezes after I delete that line. I have run the same case successfully. Thus I don't know what's going on.
Best,
JC
JinshiC is offline   Reply With Quote
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 5, 2023 23:48
Simulation stops at Starting time loop JMaverick93 OpenFOAM Running, Solving & CFD 3 March 18, 2018 06:08
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 05:28
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
