[SOWFA] installing nrel sowfa
Old   April 18, 2016, 05:14
Default installing nrel sowfa
Peter Hu
huecu588755 is on a distinguished road
I'm trying to install Nrel sowfa code, but failed in version 3.0.1.I wonder if anyone suceed in installing it and which version is proper to swofa.
Thanks
huecu588755 is offline   Reply With Quote
Old   October 27, 2017, 23:20
Default Need you Help
Sam
consuto is on a distinguished road
Hello ,
I was trying to install and SOWFA into my ubuntu 16.04 lts. after unzip the file SOWFA-master into my Home, I run the ./makeNewWorkingDir .(I installed OpenFOM 2.4.0 in Ubuntu 16.04) ,it was show error like:
cp: cannot stat '/ifs/dm/cfd/app/OpenFOAM/SOWFA': No such file or directory
anyway, I active my openFOAM and also
cp -rs $SOWFAdir $WM_PROJECT_USER_DIR in SOWFA-master directory.
What should I do next.
Thanks for your help.
Sam
consuto is offline   Reply With Quote
Old   October 27, 2017, 23:53
Sam
I just changed the folder to my SOWFA directory and now it is Okay.
But there is still some fatal error at the end like this.
pisoFoamTurbine.C:38:49: fatal error: [/COLOR]horizontalAxisWindTurbinesALMfastv8.H: No such file or directory
compilation terminated.
pisoFoamTurbine.dep:687: recipe for target 'Make/linux64GccDPOpt/pisoFoamTurbine.o' failed
make: *** [Make/linux64GccDPOpt/pisoFoamTurbine.o] Error 1
Making dependency list for source file pisoFoamTurbine.C
could not open file horizontalAxisWindTurbinesADM.H for source file pisoFoamTurbine.C due to No such file or directory
SOURCE=pisoFoamTurbine.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/transportModels -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/fvOptions/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/home/sam/OpenFOAM/sam-2.4.0/src/turbineModels/turbineModelsStandard/lnInclude -IlnInclude -I. -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/pisoFoamTurbine.o
pisoFoamTurbine.C:38:43: fatal error: horizontalAxisWindTurbinesADM.H: No such file or directory
Making dependency list for source file turbineTestHarness.C
could not open file horizontalAxisWindTurbinesALM.H for source file turbineTestHarness.C due to No such file or directory
SOURCE=turbineTestHarness.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/turbulenceModels/incompressible/turbulenceModel -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/transportModels -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/transportModels/incompressible/singlePhaseTransportModel -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/meshTools/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/fvOptions/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/sampling/lnInclude -I/home/sam/OpenFOAM/sam-2.4.0/src/turbineModels/turbineModelsStandard/lnInclude -IlnInclude -I. -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude -I/home/sam/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/turbineTestHarness.o
turbineTestHarness.C:34:43: fatal error: horizontalAxisWindTurbinesALM.H: No such file or directory
turbineTestHarness.dep:680: recipe for target 'Make/linux64GccDPOpt/turbineTestHarness.o' failed
make: *** [Make/linux64GccDPOpt/turbineTestHarness.o] Error 1
could not open file horizontalAxisWindTurbinesALMAdvanced.H for source file turbineTestHarness.C due to No such file or directory
turbineTestHarness.C:34:51: fatal error: horizontalAxisWindTurbinesALMAdvanced.H: No such file or directory
Old   October 27, 2017, 23:57
Default installed but still some error like this.
Sam
pisoFoamTurbine.C:38:49: fatal error: horizontalAxisWindTurbinesALMfastv8.H: No such file or directory
Some error as above need to install other software?
Please help me out.
Thanks.
Sam
swofa
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 11:54
[SOWFA] NREL SOWFA Tutorial case mohsen.boojari OpenFOAM Community Contributions 0 March 8, 2016 10:35
[SOWFA] NREL SOWFA pisoFoamTurbine tutorial problem mohsen.boojari OpenFOAM Community Contributions 1 February 9, 2016 08:43
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 14:39
