[cfMesh] CFMesh doing long non-parallel calculation |
February 14, 2018, 11:10 |
benoit paillard
Rep Power: 16 |
Hi all,
I've noticed that, for some complicated geometries, CFMesh does long calculation (~10 to 20h) on a single core, mostly at the beginning of the process : mainly during template generation or before starting the boundary layer generation, when restarting from meshOptimisation. I've tried looking at the source code to see what happened there, but no luck so far... Has anyone else experienced that ? This is only for very complicated, and potentially bad quality geometry though. It works perfectly fine 99% of the time. Thanks ! |
January 28, 2020, 08:16 |
Joćo Duarte Miranda
Rep Power: 14 |
Dear bennn,
I know is a old post, but did you manage to solve the problem. I have the same for a rather complex case. What is strange is that for another even more complex case it worked well. Do you have some information/tips you can share? Thanks a lot! |
Openfoam parallel calculation performance study - Half performance on mpirun | Jurado | OpenFOAM Running, Solving & CFD | 22 | March 24, 2018 20:40 |
MPI error in parallel application | usv001 | OpenFOAM Programming & Development | 2 | September 14, 2017 11:30 |
Iterations Calculation stopped for long time - Simulation CFD 2015 | archNUOVO | Autodesk Simulation CFD | 0 | February 21, 2017 09:57 |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
parallel calculation on multiple computers | foam_noob | OpenFOAM | 4 | February 3, 2010 03:14 |
