[swiftBlock/swiftSnap] SwiftSnap is throwing an error on save
Old   December 13, 2016, 02:23
Default SwiftSnap is throwing an error on save
garumple is on a distinguished road
I have recently installed Blender and SwiftSnap, although I have run into a little snag.
I can create a model, assign faces/patches etc, however when I attempt to 'Write', I get an error : "TypeError: save() got multiple values for argument 'filepath'".
I have tried to cross a few things from the list:
  1. Downloaded the latest SwiftSnap from the git repo
  2. Tried different geometries to check it wasn't the model spazzing out
  3. Google for anyone else with the same issue.
I am a bit lost - has anyone else seen this before?
garumple is offline   Reply With Quote
Old   December 13, 2016, 03:06
Karl-Johan Nogenmyr
kalle is on a distinguished road
Hmm.. haven't seen this. What Blender version are you running? Do you mind sharing the full path and filename you try to use?
Kalle
kalle is offline   Reply With Quote
Old   December 13, 2016, 05:53
Thanks for the quick reply.
I'm running Blender 2.77. I should have mentioned this is a Windows 10 environment rather than a Linux environment.
The full path of the script is: "C:\Users\AppData\Roaming\Blender Foundation\Blender\2.77\scripts\addons\swiftSnap-master"
The full path of the attempted export is: "C:\Users\No\CAE\FWR_Eyeball", with a ".blend" file in that directory named either "FWR_Eyeball.blend" or "untitled.blend".
I have tried other directories (such as My Documents), but I get the same result.
The error I get looks like this:
Old   December 13, 2016, 05:58
Karl-Johan Nogenmyr
Hmm... probably some change in Blender's API is to blame for this. SwiftSnap is working with 2.70 - 2.72. Can you try to install that version instead? Old version are found on blender's website.
K
Old   December 13, 2016, 21:16
Thumbs up
It would appear that Blender has changed its API - version 2.72 works just fine.
Thanks for your help!
blender, swiftsnap
Very quick - Journal file command to save monitors lcaBR FLUENT 2 October 18, 2022 12:26
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 11:16
save case & data Saman95 FLUENT 1 August 12, 2018 06:09
[General] Save Animation Settings TomBot ParaView 2 August 26, 2017 07:54
terminate called after throwing an instance of 'int' b614910 SU2 10 July 27, 2014 22:16
