May 4, 2017, 16:27 |
edge refinement
Hello everybody,
I've read many threads of this forum over the last year and most of the time was able to find the error by myself. Now comes the time that I need to open a post :-) First of all, I would like to thank the community for your kind help, as far as I've seen it, you are always kind and try to help everybody as good as you can. So, now to my problem: I'm trying to simulate an internal flow and prepared the STL file with all its regions. But when it comes to the meshing process in CfMesh, some edges are not meshed correctly. I've looked at the .vtk file, which shows the edges generated by the command "SurfaceFeatureEdges -angle 30". It seems to detect the edges correctly, but didn't place the mesh nodes on these edges. My mesh has some very high skewness values of about 400-1200 which are way too high. I've played a bit with the cellsize, but that did not help me out a lot (I did not cut the cell size by half because this would increase the data space too much) Thank you in advance :-) Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | cfMesh: A library for mesh generation | | \\ / O peration | | | \\ / A nd | Author: Franjo Juretic | | \\/ M anipulation | E-mail: franjo.juretic@c-fields.com | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object meshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // surfaceFile "edges.fms"; maxCellSize 0.001; surfaceMeshRefinement { wall { surfaceFile "CAD/STL/wall.stl"; additionalRefinementLevels 3; refinementThickness 0.00004; } } boundaryLayers { // nLayers 3; // thicknessRatio 1.2; // maxFirstLayerThickness 0.5; patchBoundaryLayers { "wall.*" { nLayers 3; thicknessRatio 1.2; maxFirstLayerThickness 0.00001; allowDiscontinuity 0; } } } renameBoundary { newPatchNames { wall { newName walls; type wall; } leftWall1 { newName cyclic1; type cyclicAMI; neighbourPatch cyclic0; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); rotationAngle 180; // degrees } leftWall2 { newName cyclic1; type cyclicAMI; neighbourPatch cyclic0; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); rotationAngle 180; // degrees } rightWall1 { newName cyclic0; type cyclicAMI; neighbourPatch cyclic1; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); rotationAngle 180; // degrees } rightWall2 { newName cyclic0; type cyclicAMI; neighbourPatch cyclic1; transform rotational; rotationAxis (0 0 1); rotationCentre (0 0 0); rotationAngle 180; // degrees } inlet { newName inlet; type patch; } outlet { newName outlet; type patch; } } } // ************************************************************************* // |
June 6, 2017, 02:39 |
First, are you sure of the command line you're typing? I generally use: Code:
surfaceFeatureEdges.exe surfacefile.stl surfacefile.fms -angle 30 Code:
FMSToSurface -exportFeatureEdges surfacefile.fms temp.fms
e.g. Code:
maxCellSize 0.008; //boundaryCellSize 0.001375; localRefinement { ext1 {cellSize 0.004;} interAirAmbAirComb1 {cellSize 0.0025;} interAirAmbAirComb2 {cellSize 0.0025;} interAirAmbGlass {cellSize 0.004;} interAirAmbSolido1 {cellSize 0.003;} //0.0025 //totale interAirAmbSolido2 {cellSize 0.00075;} //0.0025 interAirAmbSolido3 {cellSize 0.00075;} //0.0025 interAirAmbSolido4 {cellSize 0.002;} //0.0025 interAirAmbSolido5 {cellSize 0.002;} interAirAmbSolido6 {cellSize 0.002;} outletComfort {cellSize 0.003;} //ext 2/3/4/3/5 - symmetryAmb - wallSerbatoio } surfaceMeshRefinement { refVentilatore {surfaceFile "refineGeometry/refVentilatore.stl"; additionalRefinementLevels 4;} // refinementThickness 0.002; } } edgeMeshRefinement { asole {edgeFile "refineGeometry/asole.vtk";additionalRefinementLevels 4;} //refinementThickness 0.002; angolo2 {edgeFile "refineGeometry/angolo2.vtk";additionalRefinementLevels 6;} } |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
