[Other] Error accured while installing MembraneFoam with OpenFOAM v1706 |
June 13, 2019, 04:01 |
Yu Chen
Rep Power: 7 |
Hi Foamers,
I am new in studying openFoam and while I try to use the MembraneFoam and install it as the tutorial and found error. 1.PNG Is it because I did not install any nessary softwares before or my system is too old? Thanks in advance. Kawinsa |
June 16, 2019, 15:18 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: "MembraneFoam" seems to have been developed to use OpenFOAM 4. However, OpenFOAM 1706 has other definitions that are not compatible with the OpenFOAM 4 names...
You might want to try this branch: https://github.com/EdMBarry/MembraneFoam/tree/OF5 - to get the source code, run these commands: Code:
git clone https://github.com/EdMBarry/MembraneFoam/ membraneFoam_v5 cd membraneFoam_v5 git checkout OF5
June 18, 2019, 02:59 |
Thank you wyldckat for your answer!
Yu Chen
Rep Power: 7 |
Hi wyldckat,
Thank you for your answer! But when I run the installation, I found there is another error. 2.PNG and I searched the file and a similar one in the membraneFoam. 3.jpg and found the file is empty, the similar one in the membraneFoam is different has no file end with .so Should I download the “lib-” or just copy the files in the similar one? It is appreciated if there are any advices! Kawinsa |
September 1, 2019, 11:17 |
Carlos Anaya
Maybe at this point you had solved your problem, maybe not
I downloaded the Mathias Gruber version, neither worked for Windows nor .com versions, but 3.0.x and 4.x There are 2 versions, the -master and the new, -master only works on <4.x and had no errors for me on 3.0.x The new version had 2 errors on 4.x, one was about a file from previous versions that didn't exist anymore and I just erased the mention The second error was more complicated about a value "static" that wasn't defined like that, I just really searched about similar errors, tried to compile and it worked, I'm pretty new on coding and the test gave me "logical" data on the simulation, so I think it's fine Good luck |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[OpenFOAM.org] Problems with installing openfoam 5.0 on HPC Cluster | sjlouie91 | OpenFOAM Installation | 4 | January 20, 2019 15:35 |
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster | hello177 | OpenFOAM Installation | 1 | April 24, 2016 08:35 |
question about installing Openfoam 1.6-ext | Haotian | OpenFOAM Installation | 2 | November 17, 2013 18:47 |
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 | wyldckat | OpenFOAM Installation | 14 | February 12, 2013 04:43 |
