[swak4Foam] funkydoCalc issue with snGrad
Old   August 15, 2016, 11:06
Default funkydoCalc issue with snGrad
Manu Chakkingal
manuc is on a distinguished road
Hello
I have n issue with snGrad usage with funkydocalc.
With swak4foam
I gave :
functions(
   NusseltNumber_hot
    type          patchExpression;
     outputControl  timeStep;
     outputInterval 1;
        patches (
                w_l
    verbose true;
        variables (
                "Tsat=300.1;"
                "ln2D=3.065;"      //length(.08)/k(.0261)
    expression "ln2D*snGrad(T)/(T-Tsat)";
        accumulations (
                    average
This gave me a Nusselt No. of 56.02 (neglect scaling)
With all data in disk I tried to obtian the same using funkyDoCalc as:
    NusseltNumber_hot
    valueType                        patch;
        patchName                        w_l;
        variables (
                        "Tsat=300.1;"
        accumulations (
                    max
Which is giving me 0 as output for max/min/average
I read in:
https://sourceforge.net/p/openfoam-e...2.1_v2.x/tree/
that the snGrad doesnt work when data is in disc and needs to be temporarily loaded. Could anyone explain on what to be done
Regards
Manu
Last edited by wyldckat; January 1, 2018 at 19:47. Reason: Added [CODE][/CODE] markers
manuc is offline   Reply With Quote
Old   January 1, 2018, 19:49
Retired Super Moderator
Bruno Santos
Quick answer, although really late by now: according to the information you've found, you must use this while the solver is running and cannot use it with funkyDoCalc.
Old   January 2, 2018, 11:00
Assistant Moderator
Bernhard Gschaider
Yep. Reason is that for such calculations to work correctly funkyDoCalc would have to call correctBoundaryConditions() on loaded fields. And that has the strong potential to crash if a boundary condition needs another field in memory and doesn't find it.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Prism Layer - Core Mesh Boundary Issue InfernoxCJC STAR-CCM+ 7 November 21, 2017 15:46
Convergence issue in natural convection problem chrisf90 FLUENT 5 March 5, 2016 08:30
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 06:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 02:00
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
