[pythonFlu] Making managedFlu compatible to OpenFOAM-4.1
Like Tree1Likes
  • 1 Post By MatsukazeTenma
Old   June 16, 2017, 02:25
Default Making managedFlu compatible to OpenFOAM-4.1
Matsukaze Tenma
MatsukazeTenma is on a distinguished road
Hello all,
I am working on reviving pythonFlu package and managedFlu is a prerequisite for it
pythonFlu, managedFlu were built in correspondence with OpenFOAM-2.1.1 but now OpenFOAM has shifted to version 4.1. So when I try to install managedFlu I am getting errors regarding some header files not found. Indeed that's the case.
For example, In OpenFOAM-2.1.1 in directory src/finiteVolume/lnInclude there is a header file MRFZones.H but in OpenFOAM-4.1 the same header file is missing, and managedFlu requires that header file
Below are the other headers file which are required by managedFlu
basicPsiThermo.H
basicSolidThermo.H
PorousZones.H
I am sincerely putting all my efforts in this work and I would like to know if there are any solutions available for this. I would also like to know how these header files are generated when I manually compile OpenFOAM because on github repository the lnInclude folder in src/finiteVolume directory is not available
The link to managedFlu repository is https://github.com/asimurzin/managedFlu/
Thanks in advance
elvis likes this.
MatsukazeTenma is offline   Reply With Quote
Old   April 13, 2018, 02:29
Giovanni Stabile
giovastabile is on a distinguished road
Did you have any succes in reveving pytonflu for newer versions of OpenFOAM?
PhD Giovanni Stabile.
MyHomePage
giovastabile is offline   Reply With Quote
Old   April 13, 2018, 02:30
Giovanni Stabile
Did you have any success in reviving pytonflu for newer versions of OpenFOAM?
MyHomePage
openfoam 2.1.1, openfoam 4.1, pythonflu
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 15:54
[Docker] Running OpenFoam 4.1 from script without user intervention fnellmeldin OpenFOAM Running, Solving & CFD 9 June 7, 2017 18:04
Differences in interPhaseChangeFoam between OpenFOAM 2.3 and OpenFOAM 4.1 Mashiro5 OpenFOAM Running, Solving & CFD 2 May 29, 2017 04:13
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
