July 30, 2018, 04:03 |
Multiple inlet and outlet issues
Rep Power: 8 |
Urgent help please!!!
I am running this case (absorption column) with two inlets and two outlets But when I run, I get negative volume fraction I did not use setFields because I didn't want any material in the domain before running. So the domain is empty before the simulation is started. When I checked the results in paraview, it looks as though the liquid inflow is leaving the domain instead I have attached the necessary files Thank you |
Pressure Boundary Inlet and Outlet | AS_Aero | CFX | 5 | March 28, 2018 10:46 |
Total Pressure Drop at inlet and outlet | AS_Aero | Main CFD Forum | 10 | September 8, 2017 04:54 |
pump outlet pressure higher than inlet pressure | jstan3 | FLUENT | 14 | February 13, 2014 23:44 |
flow around a circular cylinder with velocity inlet and outflow outlet | shuoxue | OpenFOAM Running, Solving & CFD | 0 | November 2, 2013 04:32 |
define BCs at inlet and outlet for natural ventilation simulation | jjz2013 | Main CFD Forum | 0 | January 29, 2013 15:50 |
