August 1, 2018, 09:15 |
Not meshing the entire geometry
Zander Meiring
Rep Power: 7 |
Hi there,
I'm trying to make use of the great software that is Cfmesh in order to mesh an axial fan. However, I am getting an issue where the blade is not being meshed properly, and I'm unsure what's causing it or how to fix it. The best way to describe is through a picture, and so one is attached here. The .stl of the blade is shown along with it's mesh. As can be seen, the mesh size is small enough to describe the geometry of the blade. Below is also my meshDict, if it helps. EDIT: Sorted it out. It was the use of keepCellsIntersectingPatches was what was causing issues Code:
surfaceFile "merged.stl"; maxCellSize 0.05; boundaryCellSize 0.005; minCellSize 0.0005; keepCellsIntersectingBoundary 1; localRefinement { "blade.*" { cellSize 0.0006; } } boundaryLayers { patchBoundaryLayers { "blade.*" { nLayers 8; thicknessRatio 1.2; maxFirstLayerThickness 0.0015; allowDiscontinuity 1; } } } renameBoundary { defaultName fixedWalls; defaultType wall; newPatchNames { "blade.*" { newName blade; newType wall; } "inlet.*" { newName inlet; newType patch; } "outlet.*" { newName outlet; newType patch; } "symm.*" { newName symm; newType symmetry; } "right.*" { newName right; newType symmetry; } "left.*" { newName left; newType symmetry; } } } keepCellsIntersectingPatches { "blade.*" { keepCells 1; } "symm.*" { keepCells 1; } } Last edited by yambanshee; August 8, 2018 at 08:09. |
August 2, 2018, 02:49 |
Zander Meiring
Rep Power: 7 |
forgot to upload the image! sorry
October 25, 2018, 03:43 |
KHB
Rep Power: 15 |
Does the issue remains when you use smaller cell near the edge?
October 29, 2018, 08:53 |
Zander Meiring
Rep Power: 7 |
[ICEM] Meshing a fractal geometry in ICEM | andrewmichael | ANSYS Meshing & Geometry | 0 | May 22, 2018 20:17 |
Dynamic Meshing of Simple 2D Geometry | harman79 | FLUENT | 2 | January 17, 2018 06:07 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Gambit meshing problem to following geometry | ahmadmln | ANSYS Meshing & Geometry | 2 | October 21, 2014 01:49 |
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry | robbierich90 | ANSYS Meshing & Geometry | 0 | October 30, 2011 13:12 |
