[openFuelCell] Allwmake script error on src directory
Old   May 10, 2021, 02:14
Thumbs down Allwmake script error on src directory
Joonsuk
HL7601 is on a distinguished road
I'm having a compile error problem of Allwmake script on src directory.
I looked up similar questions in the forum and followed the solution in the comments, but it doesn't work for me.
In my case, the same error occurs in both OF7 and OF8 on Ubuntu 20.04.
The error is as follows:
In file included from sofcFoam.C:145:
YairEqn.H:35:33: error: ‘class Foam::fvMesh’ has no member named ‘solver’; did you mean ‘Foam::dictionary Foam::solution::solvers_’? (not accessible from this context)
35 | YiEqn.solve(airMesh.solver("Yi"));
In file included from /opt/openfoam8/src/finiteVolume/lnInclude/fvSolution.H:37,
from /opt/openfoam8/src/finiteVolume/lnInclude/fvMesh.H:56,
from /opt/openfoam8/src/finiteVolume/lnInclude/fvCFD.H:7,
from sofcFoam.C:45:
/opt/openfoam8/src/OpenFOAM/lnInclude/solution.H:74:20: note: declared private here
74 | dictionary solvers_;
In file included from sofcFoam.C:148:
solveElectrochemistry.H:7:18: warning: unused variable ‘pAtm’ [-Wunused-variable]
7 | const scalar pAtm = physicalConstant:Atm.value(); // Pa - added SBB 06-12-2013
make: *** [/opt/openfoam8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/sofcFoam.o] Error 1
I cannot to solve it even if I try to fix it several days, so I post an inquiry.
I would like to express my gratitude to all of you for your help.
Thank you.
HL7601 is offline   Reply With Quote
allwmake, openfuelcell, transform:26
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 04:20
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 06:43
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
