[waves2Foam] compilling wave2Foam in OpenFOAM 4.1 and ubuntu 16.04
Old   March 22, 2018, 01:11
Default compilling wave2Foam in OpenFOAM 4.1 and ubuntu 16.04
Ben 017
Ben UWIHANGANYE is on a distinguished road
Dear Segun
I was installing Wave2Foam but failed to excute Allwmake in wave2Foam folder at the last step.
it reporting the following msg:
ben@ben:~/waves2Foam$ ./Allwmake
ENVIRONMENTAL VARIABLES
EXTBRANCH=0
FOAMEXTENDPROJECT=0
OFPLUSBRANCH=0
WAVES_APPBIN=/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin
WAVES_DIR=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam
WAVES_GSL_INCLUDE=/usr/include
WAVES_GSL_LIB=/usr/lib64
WAVES_LIBBIN=/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/lib
WAVES_POST=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/applications/utilities/postProcessing
WAVES_PRE=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/applications/utilities/preProcessing
WAVES_SOL=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/applications/solvers/solvers410
WAVES_SRC=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/src
WAVES_TUT=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/tutorials
WAVES_UTIL=/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/applications/utilities
WAVES_XVERSION=0
WM_PROJECT_VERSION_NUMBER=410
FATAL ERROR.
The directory path /home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam does not exist.
Correct the path in bin/bashrc
This means that you should correct the environmental variable $WAVES_DIR
such that it is pointed (in absolute sense) to the path, where waves2Foam
is located.
Please note that once bin/bashrc is created, bin/bashrc.org is only an
inactive file. The latter is also the only of the two files, which is
updated through the SVN-repository.
EXITING
Would appreciate your support.
Thx!
Ben UWIHANGANYE is offline   Reply With Quote
Old   March 22, 2018, 01:56
Smile
Kun Zheng
Kun_zheng is on a distinguished road
Originally Posted by Ben UWIHANGANYE View Post
Dear Segun
EXTBRANCH=0
FOAMEXTENDPROJECT=0
OFPLUSBRANCH=0
WAVES_XVERSION=0
FATAL ERROR.
is located.
EXITING
Thx!
Hi, Ben
I am not sure if you miss the step of making directories:
$mkdir -p OpenFOAM/ben-4.1/applications/utilities
If not, please check the name of directories. I misspelled the "applications" as "application" when I install w2f. Good luck !
best regards,
Kun
Kun_zheng is offline   Reply With Quote
Old   March 22, 2018, 03:29
Post
Ben 017
Missing that step where? during the installation of OpenFoam4.1 or?
Please help!
Old   March 22, 2018, 13:52
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Ben,
Please try to carefully read the error message. This should help you and this problem has been treated multiple times above.
Anyway, in the waves2Foam folder there is a folder called bin. Here, there is a file bashrc, where the installation location must be specified.
Note that there are no solvers generated for OpenFoam 4.1., so you must generate them yourself. For that, there are clear instructions in the manual. Furthermore, I do not know, whether waves2Foam compiles on version 4.1.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   March 26, 2018, 07:08
Ben 017
I am compilling wave2Foam in OpenFoam4.1/ubuntu 16.04 and i am getting the following feedback:
EXTBRANCH=0
FOAMEXTENDPROJECT=0
OFPLUSBRANCH=0
WAVES_XVERSION=0
COMPILE LAPACK-3.3.1
lapack-3.3.1 has already been compiled
COMPILE SPARSKIT2
SPARSKIT2 has already been compiled
COMPILE OCEANWAVE3D
Pull changes from the OceanWave3D git repository ...
*** Please tell me who you are.
Run
git config --global user.email "you@example.com"
git config --global user.name "Your Name"
to set your account's default identity.
Omit --global to set the identity only in this repository.
fatal: unable to auto-detect email address (got 'ben@ben.(none)')
Cannot save the current index state
No stash found.
OceanWave3D has already been compiled
/home/ben/waves2Foam/ThirdParty
COMPILE FENTON4FOAM
fenton4Foam has already been compiled
COMPILE LIBRARY
'/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/lib/libwaves2Foam.so' is up to date.
'/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamProcessing.so' is up to date.
'/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/lib/libwaves2FoamPorosity.so' is up to date.
COMPILE SOLVERS
ls: cannot access '/home/ben/OpenFOAM/ben-4.1/applications/utilities/waves2Foam/applications/solvers/solvers410/*': No such file or directory
COMPILE PRE-PROCESSING
make[1]: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/relaxationZoneLayout' is up to date.
make[1]: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/waveGaugesNProbes' is up to date.
make[1]: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/setWaveField' is up to date.
make[1]: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/setWaveParameters' is up to date.
make[1]: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/sampleIncidentWaveField' is up to date.
make[1]: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/faceSetToSTL' is up to date.
COMPILE POST-PROCESSING
make: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/postProcessWaves2Foam' is up to date.
COMPILE BREEDER
Nothing available for compilation in the breeder
directory.
COMPILATION DONE
Could you help to know what to do get wave2Foam compiled.
I would appreciate !
Old   March 26, 2018, 11:57
ngj
Hi Ben,
See my reply above: there are no solvers available for OF4.1.
Kind regards
Niels
Old   March 26, 2018, 16:56
Post
Ben 017
Then, through which way should I compile it?
may you direct me? My supervisor said it works for him.
I have been trying and you see what it is giving:
EXTBRANCH=0
FOAMEXTENDPROJECT=0
OFPLUSBRANCH=0
WAVES_XVERSION=0
COMPILE SPARSKIT2
COMPILE OCEANWAVE3D
Run
No stash found.
COMPILE FENTON4FOAM
COMPILE LIBRARY
COMPILE SOLVERS
make: '/home/ben/OpenFOAM/ben-4.1/platforms/linux64GccDPInt32Opt/bin/waveFoam' is up to date.
COMPILE BREEDER
directory.
COMPILATION DONE
Old   March 27, 2018, 01:47
ngj
Hi Ben,
You are not nearly giving enough information for us to provide help. I have no idea, what you think is wrong.
Check this thread and follow the instructions:
How to give enough info to get help
Everything seems fine with the compilation and I recommend that you try some tutorials or ask you supervisor.
Kind regards,
Niels
[OpenFOAM.org] Can't find installation instruction for Openfoam 2.4.x , on Ubuntu 16.04 titanium OpenFOAM Installation 14 February 20, 2020 11:46
[waves2Foam] Difficulties installing with OpenFOAM 4.1 on Ubuntu 16.04 Ben UWIHANGANYE OpenFOAM Community Contributions 4 May 4, 2018 05:14
[OpenFOAM.org] Using OpenFOAM 2.3.0 from Deb pack in Ubuntu 14.04 + ParaView 5 from OpenFOAM 4.1 ad2eb OpenFOAM Installation 12 May 28, 2017 14:30
[OpenFOAM.org] Openfoam 4.1 conflicts with Cuda 7.5 on ubuntu 16.04 Hillie OpenFOAM Installation 2 April 3, 2017 21:59
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 14:25
