[waves2Foam] setWaveField: command not found
Like Tree1Likes
Old   February 20, 2024, 11:33
wenzhe zhang
imzwz is on a distinguished road
the waveFlume is to test the relaxation zone method, the solver doesn't matter
imzwz is offline   Reply With Quote
Old   February 20, 2024, 11:52
Marion Sant
edo2822 is on a distinguished road
The interFoam application is also prescribed in the controlDict file of other waveFoam tutorials like standingWave. So this is normal right?
edo2822 is offline   Reply With Quote
Old   February 28, 2024, 04:08
Marion Sant
Dear Edoardo,
Sorry, I have no idea what happened on your computer. But if you run wavesFoam and return not found, maybe you don't compile the waves2Foam correctly. Because you are using openfoam.com not openfoam.org, the note version later than 1.7 should not be suitable for your situation.
Today I reinstall my PC, and the installation is written down in my personal note, you are welcome to take a look.
https://www.overleaf.com/read/dkvdsfdqnjqn#5a7e00
Good luck
wenzhe
Dear wenzhe,
Have you ever used the cnoidalFirst wave theory in waves2foam?
I'm trying to run a simulation with that and the setWaveFields fails.
I'll attach a folder with the log file and my setWaveField file if you have any clue!
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 06:39
Gmsh installation on terminal help spitfire Main CFD Forum 4 July 27, 2017 15:11
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
