March 26, 2015, 20:20 |
surfaceElevation in parallel
YS
Rep Power: 16 |
Hi all,
Over the time I receive fatal error while using the runtime 'surfaceElevation' functionObject in parallel runs. A typical error message is as follows: new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Fatal error in MPI_Probe: Other MPI error, error stack: MPI_Probe(113).................: MPI_Probe(src=32, tag=1, MPI_COMM_WORLD, status=0x7fffa9632b58) failed MPIDI_CH3I_Progress(401).......: MPID_nem_tcp_poll(2332)........: MPID_nem_tcp_connpoll(2582)....: state_commrdy_handler(2208)....: MPID_nem_tcp_recv_handler(2081): socket closed I wonder is there anyone here ever came across a similar problem. I have attached my blockMeshDict, decomposeParDict and controlDict for you to inspect or try to reproduce the error. Thanks a lot! blockMeshDict.txt controlDict.txt decomposeParDict.txt |
June 23, 2017, 04:55 |
Mehdi
Rep Power: 10 |
hello everyone,
Im using waveFoam with waveGaugesNProbes in parallel (waveFlume for ex) in OpenFOAM extend 4.0 but it buggs and print me this message: Code:
PIMPLE: Operating solver in PISO mode Reading g Reading waveProperties Reading waveProperties Reading field pd Reading field alpha1 Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Calculating field g.h Selecting turbulence model type laminar time step continuity errors : sum local = 0, global = 0, cumulative = 0 PCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 PCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 Courant Number mean: 0 max: 0 velocity magnitude: 0 Starting time loop Courant Number mean: 0 max: 0 velocity magnitude: 0 deltaT = 0.0011976 --> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libwaves2Foam.so" did not introduce any new entries Time = 0.0011976 PIMPLE: iteration 1 MULES: Solving for alpha1 Liquid phase volume fraction = 0.666667 Min(alpha1) = 0 Max(alpha1) = 1 Relaxing time: 0.01 s DILUPBiCG: Solving for Ux, Initial residual = 2.68409e-07, Final residual = 1.05821e-16, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1.14968e-07, Final residual = 3.61842e-16, No Iterations 1 DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.000906114, No Iterations 36 DICPCG: Solving for pd, Initial residual = 1.54019e-07, Final residual = 5.3285e-08, No Iterations 1 DICPCG: Solving for pd, Initial residual = 2.86385e-07, Final residual = 7.31041e-08, No Iterations 4 PCG: Solving for pd, Initial residual = 7.31022e-08, Final residual = 7.31022e-08, No Iterations 0 PCG: Solving for pd, Initial residual = 7.31161e-08, Final residual = 7.31161e-08, No Iterations 0 PCG: Solving for pd, Initial residual = 7.31161e-08, Final residual = 7.31161e-08, No Iterations 0 time step continuity errors : sum local = 6.55783e-12, global = -1.11635e-12, cumulative = -1.11635e-12 ExecutionTime = 0.32 s ClockTime = 1 s Courant Number mean: 4.43401e-07 max: 2.45643e-05 velocity magnitude: 0.000249729 deltaT = 0.00143023 [islin130:18297] *** Process received signal *** [islin130:18297] Signal: Aborted (6) [islin130:18297] Signal code: (-6) [islin130:18297] [ 0] /lib64/libc.so.6[0x3b2f432660] [islin130:18297] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3b2f4325e5] [islin130:18297] [ 2] /lib64/libc.so.6(abort+0x175)[0x3b2f433dc5] [islin130:18297] [ 3] /lib64/libc.so.6[0x3b2f4704f7] [islin130:18297] [ 4] /lib64/libc.so.6[0x3b2f475f3e] [islin130:18297] [ 5] /lib64/libc.so.6[0x3b2f47a4fa] [islin130:18297] [ 6] /lib64/libc.so.6(__libc_malloc+0x5c)[0x3b2f47abfc] [islin130:18297] [ 7] /usr/lib64/libstdc++.so.6(_Znwm+0x1d)[0x3b35cbd0bd] [islin130:18297] [ 8] /usr/lib64/libstdc++.so.6(_Znam+0x9)[0x3b35cbd1d9] [islin130:18297] [ 9] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam4ListIcE7setSizeEi+0x31)[0x7fec0906b571] [islin130:18297] [10] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam8IPstreamC1ENS_7Pstream10commsTypesEiiiiNS_8IOstream12streamFormatENS3_13versionNumberE+0x12d)[0x7fec0906bccd] [islin130:18297] [11] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libwaves2FoamSampling.so(_ZN4Foam7Pstream10gatherListINS_5FieldIdEEEEvRKNS_4ListINS0_11commsStructEEERNS4_IT_EEii+0x1b5)[0x7fec09a34ab5] [islin130:18297] [12] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libwaves2FoamSampling.so(_ZN4Foam23sampledSurfaceElevation20combineSampledValuesIdEEvRKNS_7PtrListINS0_15volFieldSamplerIT_EEEERKNS_4ListINS9_IiEEEERS6_+0x42f)[0x7fec09a352ef] [islin130:18297] [13] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libwaves2FoamSampling.so(_ZN4Foam23sampledSurfaceElevation18sampleAndIntegrateERNS0_10fieldGroupIdEERNS_5FieldIdEE+0x24e)[0x7fec09a1fe9e] [islin130:18297] [14] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libwaves2FoamSampling.so(_ZN4Foam23sampledSurfaceElevation23sampleIntegrateAndWriteERNS0_10fieldGroupIdEE+0x6e)[0x7fec09a207fe] [islin130:18297] [15] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libwaves2FoamSampling.so(_ZN4Foam26OutputFilterFunctionObjectINS_23sampledSurfaceElevationEE7executeEv+0xb2)[0x7fec09a3bae2] [islin130:18297] [16] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam18functionObjectList7executeEv+0x16e)[0x7fec090918ee] [islin130:18297] [17] /soft/irsrvsoft1/expl/centos_6/OpenFOAM/4.0/foam-extend-4.0/lib/linux64GccDPOpt/libfoam.so(_ZN4Foam4TimeppEv+0x71)[0x7fec09095b01] [islin130:18297] [18] waveFoam[0x42d728] [islin130:18297] [19] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3b2f41ed1d] [islin130:18297] [20] waveFoam[0x42a989] [islin130:18297] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 18297 on node islin130 exited on signal 6 (Aborted). -------------------------------------------------------------------------- NB: in all calcul with waveFoam the message bellow appear and i don't find this file : Code:
--> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libwaves2Foam.so" did not introduce any new entries Best regards, Mehdi Last edited by wyldckat; August 23, 2018 at 14:52. Reason: QUOTE->CODE |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
