[waves2Foam] very frustrating problem related to reconstructing a case
Old   November 29, 2016, 07:48
Default very frustrating problem related to reconstructing a case
ArielJ
arieljeds is on a distinguished road
Hi all,
I'm having a very frustrating problem related to reconstructing a case. A couple of details:
1) I am running a deconstructed case on a cluster and then transferring the final reconstructed time step to my own machine to view it.
2) The case runs well and when I go to view it in paraview, the surface also looks good. However, as you can see in the attached image, the actual reconstruction is terrible. I checked it before I ran it and everything looked ok, all of the residuals look good, Courant number is good, etc
The problem seems to occur only when reconstructing, and only sometimes. I have had this problem before but it was not consistent and would be fine the next time. I am using pyFoam to decompose with the following:
pyFoamDecompose . 12
After reconstructing, the decomposed processors were deleted so I only have the reconstructed data now, which looks like the images I'm attaching. I really want to figure out why this is happening to stop it in the future.
Does anyone have any ideas?? Really appreciate the help and thanks in advance
arieljeds is offline   Reply With Quote
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 41 August 23, 2023 02:48
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 15:13
a reconstructPar issue immortality OpenFOAM Post-Processing 8 June 16, 2013 11:25
Problem of reconstructing pointVectorFields with parallel mesh motion (1.5.x) LESlie OpenFOAM 0 November 6, 2009 06:07
case example for ventilation problem. Kevin CFX 0 March 20, 2004 03:58
