Shengchao Xiao
Rep Power: 11 ![]() |
Hi, there,
An error was appeared when I run the waveFlume, the error was appeared during the calculation and the reminder of the error is as follow, #0 Foam::error: ![]() #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::sampledSurfaceElevation::sampleIntegrateAndW rite(Foam::sampledSurfaceElevation::fieldGroup<dou ble>&) at ??:? #4 Foam::OutputFilterFunctionObject<Foam::sampledSurf aceElevation>::execute(bool) at ??:? #5 Foam::functionObjectList::execute(bool) at ??:? #6 Foam::Time::run() const at ??:? #7 main at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? However, when I delete the following function in controlDict/system, the error will disappeared. functions { #includeIfPresent "../waveGaugesNProbes/surfaceElevationAnyName_controlDict"; } But, I want to get the surface elevation, so I can't delete it. Anyone can help me to solve this problem? Thanks a lot! |
Niels Gjoel Jacobsen
Rep Power: 37 ![]() ![]() |
Good morning Shengchao,
Are you getting this error, when you are running the standard wave flume test or have you made modifications? My best guess is that your wave gauges are outside of the computational domain. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
Shengchao Xiao
Hi, Niels,
Thank you for your quick reply, I modify the original waveFlume, In waveProperties/Constant the solitary wave is used Code:
relaxationNames (inlet outlet); initializationName outlet; inletCoeffs { waveType solitaryFirst; height 0.08; depth 0.2; direction (1 0 0); x0 (1 0 0); // Specifications on the relaxation zone shape and relaxation scheme relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX (0 0.0 -1); endX (5 0.0 1); orientation (1.0 0.0 0.0); } }; outletCoeffs { waveType potentialCurrent; U (0 0 0); Tsoft 2; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX (26 0.0 -1); endX (30 0.0 1); orientation (1.0 0.0 0.0); } }; Code:
convertToMeters 0.001; vertices ( ( 0 -200 0 ) ( 15000 -200 0 ) ( 15324 -200 0 ) ( 30000 -200 0 ) ( 0 0 0 ) ( 15000 0 0 ) ( 15324 0 0 ) ( 30000 0 0 ) ( 0 40 0 ) ( 15000 40 0 ) ( 15324 40 0 ) ( 30000 40 0 ) ( 0 200 0 ) ( 15000 200 0 ) ( 15324 200 0 ) ( 30000 200 0 ) ( 0 -200 0.1 ) ( 15000 -200 0.1 ) ( 15324 -200 0.1 ) ( 30000 -200 0.1 ) ( 0 0 0.1 ) ( 15000 0 0.1 ) ( 15324 0 0.1 ) ( 30000 0 0.1 ) ( 0 40 0.1 ) ( 15000 40 0.1 ) ( 15324 40 0.1 ) ( 30000 40 0.1 ) ( 0 200 0.1 ) ( 15000 200 0.1 ) ( 15324 200 0.1 ) ( 30000 200 0.1 ) ); blocks ( hex (0 1 5 4 16 17 21 20) ( 300 50 1 ) simpleGrading (0.5 1 1) hex (4 5 9 8 20 21 25 24) ( 300 10 1 ) simpleGrading (0.5 1 1) hex (8 9 13 12 24 25 29 28) ( 300 40 1 ) simpleGrading (0.5 1 1) hex (1 2 6 5 17 18 22 21) ( 20 50 1 ) simpleGrading (1 1 1) hex (9 10 14 13 25 26 30 29) ( 20 40 1 ) simpleGrading (1 1 1) hex (2 3 7 6 18 19 23 22) ( 300 50 1 ) simpleGrading (2 1 1) hex (6 7 11 10 22 23 27 26) ( 300 10 1 ) simpleGrading (2 1 1) hex (10 11 15 14 26 27 31 30) ( 300 40 1 ) simpleGrading (2 1 1) ); edges ( ); patches ( patch inlet ( (0 16 20 4) (4 20 24 8) (8 24 28 12) ) wall bottom ( (0 1 17 16) (1 2 18 17) (2 3 19 18) ) patch outlet ( (3 19 23 7) (7 23 27 11) (11 27 31 15) ) patch atmosphere ( (12 13 29 28) (13 14 30 29) (14 15 31 30) ) wall bridgemodel ( (5 21 25 9) (6 22 26 10) (5 6 22 21) (9 10 26 25) ) empty frontBack ( (0 1 5 4) (4 5 9 8) (8 9 13 12) (1 2 6 5) (9 10 14 13) (2 3 7 6) (6 7 11 10) (10 11 15 14) (16 17 21 20) (20 21 25 24) (24 25 29 28) (17 18 22 21) (25 26 30 29) (18 19 23 22) (22 23 27 26) (26 27 31 30) ) ); mergePatchPairs ( ); Code:
surfaceElevationAnyName { type waveGauge; pointDistribution lineDistribution; N 3; linestart (12.0 -0.15 0.05); lineend (14.0 -0.15 0.05); add ( 0 0.3 0); axis y; stretch 1.; } Thanks a lot! |
Hallo,
Yes, my initial guess was correct: your wave gauges are outside of the computational domain. Good luck, Niels
Shengchao Xiao
Hi, Neils,
The problem was solved, Thank you for your information! cheers, shengchao |
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 12:39 |
surface elevation vs time | libyano | FLUENT | 0 | July 10, 2018 02:30 |
Method I used to monitor wave elevation time history at some certain place in ccm+ | dai549592484 | STAR-CCM+ | 1 | November 3, 2015 23:22 |
Plotting wave Elevation vs Time | oe14d007 | Fluent Multiphase | 0 | October 27, 2015 23:55 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
