[swak4Foam] Error using groovyBC - 'parser error for expression driver'
Like Tree2Likes
  • 1 Post By odellar
  • 1 Post By odellar
Old   September 7, 2015, 08:13
Default Error using groovyBC - 'parser error for expression driver'
Olie
odellar is on a distinguished road
I'm using a valueExpression in my 0/U file in order to implement a boundary condition which is a function of a 'measurement' (probe reading). In the controlDict I have:
    vorticity
        type expressionField;
        autowrite true;
        dimension [0 0 -1 0 0 0 0];
        fieldName "vorticity";
        expression "curl(U)";
        verbose true;
        autowrite true;
        outputControl timeStep;
in order to compute the vorticity flow field whilst solving, followed by (again in the controlDict):
 sensorMeasurement
        type createSampledSet;
        outputControl outputTime;
        outputInterval 1;
        setName vorticity_sensor1;
        set {
                type cloud;
                axis xyz;
                points (
                        (0 -0.5 0.5)
in order to 'measure' the vorticity at a point, (0 -0.5 0.5), using a probe - the setName is vorticity_sensor1.
In my 0/U file I then have something which looks like this:
BOUNDARY1
type groovyBC;
value uniform (0 0 0);
variables (
"vorticityMeasurement{set'vorticity_sensor1}=average(vorticity);"
"w=vorticityMeasurement;"
"wMovingAvg=deltaT()*w/15.4+(1-deltaT()/15.4)*wMovingAvg;" //**** THIS LINE ****
storedVariables (
name wMovingAvg;
initialValue "0";
valueExpression "vector(1.4142*wMovingAvg,1.4142*wMovingAvg,0)";
However when I try run the solver (pimpleFoam) I get the following error (clearly corresponding to the line I've highlighted above):
[0] --> FOAM FATAL ERROR:
[0]  Parser Error for driver PatchValueExpressionDriver at "1.45-44" :"syntax error, unexpected $end"
"deltaT()*w/15.4+(1-deltaT()/15.4)*wMovingAvg"
Context of the error:
- From dictionary: /mnt/fastdata/cop13ojd/BFS_H_Infinity/processor0/0/U.boundaryField.actuator
  Evaluating expression "deltaT()*w/15.4+(1-deltaT()/15.4)*wMovingAvg"
[0]
[0]
[0]     From function parsingValue
[0]     in file lnInclude/CommonValueExpressionDriverI.H at line 1181.
[0]
FOAM parallel run exiting
[0]
[3]
[3]
[3] --> FOAM FATAL ERROR:
[3]  Parser Error for driver PatchValueExpressionDriver at "1.45-44" :"syntax error, unexpected $end"
Can anyone help me out here?
Thank you
Kummi likes this.
odellar is offline   Reply With Quote
Old   September 21, 2015, 08:34
Default No ideas?
Olie
No ideas?
Old   September 21, 2015, 09:25
Default An idea
Olie
I've just thought - this could potentially because I'm using a quantity I've computed called vorticity, which is a vector quantity - I actually only mean the z-component of the vector - what is the syntax in openFOAM to address a particular element of the variable?
In matlab for example one would write vorticity(3) to access the third element of the vector.
Thanks
Old   September 21, 2015, 11:14
Retired Super Moderator
Bruno Santos
Quick answer: I'm not familiar enough with groovyBC, but I suspect that the problem is in the first line of the expression list, namely this part:
The separator between "set" and "vorticity_sensor1" is a quote which is opened but not closed.
Where did you read about this feature, namely the ability to use the value on a "set"?
Old   September 21, 2015, 11:51
Olie
Thanks, but that is the correct way of using that expression.
I *think* I've now got it working, by saying average(vorticity.z) in order to access the z-component. It seems to be running fine, so we'll see.
wyldckat likes this.
groovybc, parser error, valueexpression
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] whats wrong with this groovyBC expression in parenthesis? immortality OpenFOAM Community Contributions 11 June 5, 2013 07:54
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
