[Other] sedFoam: two-phase flow sediment transport model |
October 15, 2021, 20:40 |
Simulation of scour around a hydrokinetic turbine in river beds
#61 |
Thiago Vieira de Souza
Rep Power: 4 |
Greetings, Dr. Chauchat
I'm currently working on my master thesis investigating the effects of hydrokinetic turbines in live river beds. The idea is to combine sedFoam with turbinesFoam so as to deploy the Actuator Line Method to represent the turbine at a low computational expense. Unfortunately, I've been struggling with this case for quite a while. The effects of the turbine are not being computed at all throughout the simulations. Although I've imported the resources from turbinesFoam and all the files related to the turbine, I cannot seem the get the fvOptions right. I don't really know how to include the source terms related to the turbine in order to compute the effect of energy extracted from the turbine to fluid in the near wake. Are there any restrictions in sedfoam as to the use of fvOptions? Is it really possible to combine the Actuator Line Method (turbinesFoam) with sedFoam as I'm trying to do? I'd very much appreciate your response, professor. Thank you in advance! Kind regards, Thiago Vieira |
October 16, 2021, 03:26 |
#62 |
Cyrille Bonamy
Rep Power: 11 |
Dear Tiago,
Are you using the latest version of sedFoam? We have recently added and validated the fvOptions capabilities. So i think you can test again, and i'm pretty sure it's possible to combine the actuator line with sedfoam. Cyrille |
October 16, 2021, 04:15 |
#63 |
Julien CHAUCHAT
Rep Power: 13 |
Dear Tiago,
As Cyrille said we have recently implemented and validated fvOption in sedFOAM so there is no technical problem to do what you want. You may be interested by reading this article from French colleagues who coupled Actuator disk model and Blade Element Model with sedFoam : https://doi.org/10.1016/j.ijsrc.2021.02.003 I also encourage you to contribute to sedFoam by sharing your development with the community. Best regards, Julien CHAUCHAT |
October 17, 2021, 19:39 |
Scour around hydrokinetic turbine in live river beds
#64 |
Rep Power: 4 |
Dear Dr. Chauchat and Cyrille,
Thank you for your response, I'll try and update sedfoam to its latest version and see if it works. Also, I'll make sure to take a look at the article you recommended and share my progress with the community. Regards, Thiago Vieira |
October 26, 2021, 20:10 |
#65 |
Rep Power: 4 |
First of all, thank you for your help. I've updated sedFoam to its latest version, along with OpenFOAM-v2016 and it seems to be working perfectly. The fvOptions for the Actuator Line Method I'm trying to implement was read successfully. Even though I can see the model being selected in the log file, my simulations are still illegible. The flow simply goes right past the region of the mesh where the turbine was supposed to be. Also, I'm getting empty files (only zeros) for the forces generated by the turbine as output at each time step. Would you mind providing me with further assistance? The fvOptions, controlDict and Ub files follow attached. Below, the Actuator Line Method selection reads as follows in the log file: Selecting finite volume options type axialFlowTurbineALSource Source: turbine - selecting cells using cellSet turbine - selected 6174 cell(s) with volume 0.594442 Source: turbine.blade1 - selecting cells using cellSet turbine - selected 6174 cell(s) with volume 0.594442 Source: turbine.blade2 - selecting cells using cellSet turbine - selected 6174 cell(s) with volume 0.594442 Source: turbine.blade3 - selecting cells using cellSet turbine - selected 6174 cell(s) with volume 0.594442 Frontal area of turbine: 0.636173 Source: turbine.hub - selecting cells using cellSet turbine - selected 6174 cell(s) with volume 0.594442 Source: turbine.tower - selecting cells using cellSet turbine - selected 6174 cell(s) with volume 0.594442 Courant Number mean: 8.38152 max: 17.3442 Turbulence suspension term is included Choice for faceMomentum : false Starting time loop Thanks in advance! |
December 8, 2021, 05:55 |
#66 |
Thokala Divya
Rep Power: 4 |
I would like to do a similar apron scour problem for my case. Could you able to do it? Can I know which version of openfoam you have used? ESI or foundation? Which is the latest version you would suggest? I feel I can get some help from older versions because people have experiences? Can someone help me to get clarified in using latest version or old version. Divya |
December 10, 2021, 02:18 |
#67 |
Cyrille Bonamy
Rep Power: 11 |
we strongly suggest the latest version of openfoam.com (ESI)
May 7, 2022, 17:09 |
#68 | |
Thokala Divya
Rep Power: 4 |
Can I know the tutorial name please. only one 3D scour problem is there I couldn't see the results properly |
May 12, 2022, 14:19 |
#69 |
Cyrille Bonamy
Rep Power: 11 |
Indeed there is only one 3D tutorial. The case of @ajusree is a custom case i think, and @ajusree is not part of the sedfoam development team. So we don't have access to this simulation.
September 25, 2022, 03:23 |
#70 |
Jialin Pang
Rep Power: 3 |
Prof. Chauchat
I am a new openfoamer and I am trying to use sedfoam to simulate a realistic scour case. I have changed many boundary conditions and different input parameters, however, the horse shoe vortex didn't show up. With the same boundary condition and input parameters, the horse shoe vortex emerged in the pimpleFoam. Is there anything I need to take into account in a realistic case? The parameters in the constant folder are copied from tutorials/3DScour. Best regards, Jialin |
September 26, 2022, 12:52 |
#71 | |
Julien CHAUCHAT
Rep Power: 13 |
Dear Jialin,
Most likely you used the default advection schemes (div schemes in system/fvSchemes) and temporal scheme (ddt) which are first order in the tutorial. You need to change to second order for both if you want to see the horseshoe vortex developing. Best regards, Julien Chauchat Quote:
September 26, 2022, 20:56 |
#72 |
Jialin Pang
Rep Power: 3 |
Dear sir,
Thank you for the response. I will try to change the schemes and see if it works. Best regards, Jiali |
October 4, 2022, 07:08 |
scour around the cylinder
#73 |
Jialin Pang
Rep Power: 3 |
Dear sir,
Thanks again for your useful suggestion, after I changed div schemes and ddt schemes to second order, the horseshoe vortex emerged. But when I check the scour around the cylinder, the alpha_a in paraview barely changed. It is not getting better after I refined the mesh. Could you please give me some suggestions to correct this? Best regards, Jialin |
January 23, 2023, 07:49 |
#74 |
Rep Power: 3 |
Dear Professor:It was a great honor to read your article published on JFM(A finite-size correction model for two-fluid large-eddy simulation of particle-laden boundary layer flow).And I have some questions to consult with you:
Is the finite-size correction model included in your open-source case(3Dchannel560)?If so, can you tell me in which file to open it,If not, how can I get it? In the 0 file in 3Dchannel560, flm, alphaPlastic,Theta file appears. Can you explain to me what it represents Can this code be used to calculate a flow with a high sediment content, such as a sediment volume fraction around 0.2? |
January 24, 2023, 16:29 |
#75 | |||
Antoine MATHIEU
Rep Power: 8 |
Regards, Antoine MATHIEU |
January 24, 2023, 21:17 |
#76 |
Rep Power: 3 |
Thank you for your reply, I have sent you a private message, please share the source code with the finite-size correction model with me, you can also send it to me via email 22034146@zju.edu.cn. Thank you again for sharing this highly innovative code
January 30, 2023, 05:45 |
#77 | |
Rep Power: 3 |
Sorry to bother you again, but I don't seem to have received your private message or email. Could you please send it again? Regards, yang |
May 29, 2023, 09:23 |
2DPipelineScour tutorial.
#78 |
Feras Algafary
Prof. Chauchat
Hello, I'm relatively new to the open-form software, and I've been attempting to run the 2DPipelineScour tutorial. However, I encountered an issue where the simulation stopped after only four seconds. When I checked the simulation, I noticed some unusual behaviour at the inlet boundary condition for alpha.a. To resolve this, I switched the inlet boundary condition from a coded fixed value to a zero gradient, allowing me to complete the simulation successfully. I aim to conduct multiple simulations for this tutorial using different shear rates. The objective is to achieve diverse velocity profiles through these simulations. In the fluid velocity file (0-org/U.b), I adjusted the bottom friction velocity, starting with 0.04318, and then tried both 0.4318 and 0.004318, but found that the simulation remained unchanged from the original with a bottom friction velocity of 0.04318. Best regards, Feras Algafary Last edited by Feras2020; May 31, 2023 at 05:56. |
July 25, 2023, 09:30 |
#79 |
Eduard Puig Montella
Rep Power: 4 |
Hi Feras,
I checked the 2DPipelineScour tutorial and I noticed that both Kinetic theory and mu(I) rheology are on. I turned the kinetic theory off and the case works smoothly without any change at the boundary conditions. Concerning the friction velocity I made the changes in 0_org/U.a and 0_org/U.b, and the results seem sound (see figures below. For a friction velocity of 0.0043 the bed remains horizontal) . Make sure you change both the fluid and solid frictional velocity. Eduard bed_profiles_0.0043.jpg bed_profiles_0.043.jpg |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
use mixture model to simulate two-phase flow with phase change | dxm2008 | Fluent Multiphase | 5 | September 7, 2016 14:15 |
Free Surface Flow with Sediment Transport | M. Riffai | CFX | 3 | September 5, 2013 09:45 |
How do model two phase granular flow in Porous media? | bahman | FLUENT | 1 | December 6, 2012 04:39 |
Transitional Flow Shear Stress Transport (SST) k-omega Turbulence Model | josechen | FLUENT | 0 | July 20, 2011 16:06 |
