[Other] Installing makeAxialMesh - strange wmake error
Old   December 17, 2018, 15:58
Default Installing makeAxialMesh - strange wmake error
krzychu111 is on a distinguished road
Background: I want to install makeAxialMesh because I have to make axisymmetric mesh from imported one by fluentMeshToFoam. I can't use extrudeMesh because fluentMeshToFoam creates both wedges as one boundary group.
I'm trying to install makeAxialMesh using official instructions.
Unfortunately there is no matching version with my openfoam version:
(amd64/bionic 4.1+dfsg1-2 uptodate) so I picked up the newest one v2.0.
When I'm running command ./Allwmake I'm getting:
./Allwmake
+ wmake makeAxialMesh
./Allwmake: 4: ./Allwmake: wmake: not found
Since I installed openfoam through apt-get I'm not able to find openfoam folder installation neither in usr nor in opt folder. So any solution to wmake: not found, found on the Internet, is not matching to my situation.
Please help me
krzychu111 is offline   Reply With Quote
Old   December 19, 2018, 18:29
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which Ubuntu or Debian or Linux Mint version are you using?
  2. The "openfoam" package provided by Debian/Ubuntu/Linux Mint is not the officially supported one by neither OpenFOAM.org nor OpenFOAM.com, which means that the maintainers at Debian did some changes that made things inconsistent with the public documentation for OpenFOAM. This to say that the wmake script is either not installed or is part of a separate package.
  3. All of this to day that you should instead either install from one of the Deb packages provided by openfoam.org or you should build OpenFOAM from source code, in case you really want to build additional code with OpenFOAM.
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
