[openSmoke] LaminarSMOKE compilation error
Old   June 30, 2019, 16:10
Smile LaminarSMOKE compilation error
Hafiz Ahmad
mdhfiz is on a distinguished road
When I was trying to compile one of the solvers in laminarSMOKE, I encountered this error.
hafiz@linux-hjxb:~/laminarSMOKE/solvers/laminarBuoyantSimpleSMOKE> wmake
wmakeLnIncludeAll: running wmakeLnInclude on dependent libraries:
    unknown option: '-I../../libs/radiationOpenSMOKE++/lnInclude'
Usage: wmakeLnInclude [OPTION] dir
options:
  -update | -u      update
  -silent | -s      use 'silent' mode (do not echo command)
  -help   | -h      print the usage
    Link all the source files in the <dir> into <dir>/lnInclude
Note
    The '-u' option forces an update when the lnInclude directory already exists
    and changes the default linking from 'ln -s' to 'ln -sf'.
    wmakeLnInclude error: base directory \ does not exist
Making dependency list for source file laminarBuoyantSimpleSMOKE.C
could not open file fvIOoptionList.H for source file laminarBuoyantSimpleSMOKE.C due to No such file or directory
could not open file Grammar_PolimiSoot_Analyzer.h for source file laminarBuoyantSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKE_PolimiSoot_Analyzer.hpp for source file laminarBuoyantSimpleSMOKE.C due to No such file or directory
-Wl,--start-group /opt/intel/mkl/lib/intel64/libmkl_intel_lp64.a /opt/intel/mkl/lib/intel64/libmkl_core.a /opt/intel/mkl/lib/intel64/libmkl_sequential.a -Wl,--end-group -lpthread -lm -lboost_date_time -lboost_filesystem -lboost_system -lboost_regex -lOpenFOAM -ldl  \
     -lm -o /home/hafiz/OpenFOAM/hafiz-6/platforms/linux64GccDPInt64Opt/bin/laminarBuoyantSimpleSMOKE
/usr/lib64/gcc/x86_64-suse-linux/7/../../../../x86_64-suse-linux/bin/ld: cannot find -lISATLib4OpenFOAM
collect2: error: ld returned 1 exit status
make: *** [/home/hafiz/OpenFOAM/OpenFOAM-6/wmake/makefiles/general:142: /home/hafiz/OpenFOAM/hafiz-6/platforms/linux64GccDPInt64Opt/bin/laminarBuoyantSimpleSMOKE] Error 1
This seems peculiar to me because as shown below, I believe the OpenSMOKE lib was compiled properly.
hafiz@linux-hjxb:~/laminarSMOKE/libs/radiationOpenSMOKE++> wmake
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file OpenSMOKEgreyDiffusiveViewFactorFixedValueFvPatchScalarField.C
Making dependency list for source file radiationCoupledBase.C
Making dependency list for source file OpenSMOKEwideBandDiffusiveRadiationMixedFvPatchScalarField.C
Making dependency list for source file OpenSMOKEgreyDiffusiveRadiationMixedFvPatchScalarField.C
Making dependency list for source file OpenSMOKEMarshakRadiationFixedTemperatureFvPatchScalarField.C
Making dependency list for source file OpenSMOKEMarshakRadiationFvPatchScalarField.C
Making dependency list for source file wideBandAbsorptionEmission.C
Make/linux64GccDPInt64Opt/derivedFvPatchFields/greyDiffusiveViewFactor/OpenSMOKEgreyDiffusiveViewFactorFixedValueFvPatchScalarField.o -L/home/hafiz/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt64Opt/lib \
    -lfiniteVolume -lmeshTools  -o /home/hafiz/OpenFOAM/hafiz-6/platforms/linux64GccDPInt64Opt/lib/libradiationOpenSMOKE++.so
I checked the dir 'libs/radiationOpenSMOKE++/lnInclude' and things seem to be in place. The problem is that it cannot locate the dir when I tried to compile one of the solver. How can I fix this?
mdhfiz is offline   Reply With Quote
Old   December 6, 2019, 09:23
Default Update?
Vincent
vince_cfd is on a distinguished road
Have you been able to solve your problem? I have the exact same problem with a different library/solver combination.
Able to compile library, able to create solver with a new name, but as soon as I want to add the library to the solver it stops working and prints a similar error.
vince_cfd is offline   Reply With Quote
Old   December 14, 2019, 04:19
Hafiz Ahmad
the message doesn't really mean anything. you could still run the case as per usual you should try testing the test cases.
sorry for the late reply, I'm not always online. but I'll try to help as much as I could
Old   May 19, 2020, 22:00
qian yao
mikeYao is on a distinguished road
hi mdhfiz
can you give me some details about how to compile laminarSMOKE or flametSMOKE. what does "adjust the paths to the Intel MKL library" mean (https://github.com/acuoci/flameletSMOKE). for optional Intel MKL library, should i download it first?
mikeYao is offline   Reply With Quote
Old   May 23, 2021, 10:30
Default solver compilation error.
Manish Singh
Manish_@ is on a distinguished road
foam@MANISH:/mnt/f/Laminarsmoke++/laminarSMOKE-master/solvers/laminarSimpleSMOKE$ wmake
options:
-update | -u update
Note
Making dependency list for source file laminarSimpleSMOKE.C
could not open file fvIOoptionList.H for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Grammar_PolimiSoot_Analyzer.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKE_PolimiSoot_Analyzer.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKE_Dictionary.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKE_DictionaryManager.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file math.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file LookupTable.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Grammar_VirtualChemistry.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file VirtualChemistry.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file ReactionPolicy_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file ThermodynamicsMap.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file ThermodynamicsMap_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file TransportPropertiesMap.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file TransportPropertiesMap_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file KineticsMap.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file TransportPropertiesMap_CHEMKIN.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file StoichiometricMap.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file JacobianSparsityPatternMap.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file KineticsMap_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Core for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file LU for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Cholesky for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file QR for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file SVD for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Geometry for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Eigenvalues for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file readOptions_ISAT.H for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file memoryAllocation_ISAT.H for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file lis_config.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file lis_config_win.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file lis.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file Species.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file AtomicComposition.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file ThermoPolicy_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file ThermoReader.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file ThermoReaderPolicy_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file TransportPolicy_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file TransportReader.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file TransportReaderPolicy_CHEMKIN.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKEStdInclude.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKEBaseClass.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKEUtilities.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKEFunctions.h for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file OpenSMOKEVector.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
could not open file KineticsUtilityFunctions.hpp for source file laminarSimpleSMOKE.C due to No such file or directory
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DOPENFOAM_VERSION=60 -w -DOPENSMOKE_USE_MKL=0 -DOPENSMOKE_USE_ISAT=0 -DDEVVERSION=1 -I../laminarSMOKE -I../laminarSMOKE/steady -I../../libs/radiationOpenSMOKE++/lnInclude -I../openSMOKEpp4laminarSMOKE/ -I/home/Laminarsmoke++/boost_1_76_0/include -I/home/Laminarsmoke++/eigen-3.4-rc1 -I/mnt/f/Laminarsmoke++/rapidxml/rapidxml-master -I/include -I/include -I/ -I/opt/openfoam6/src/finiteVolume/lnInclude -I/opt/openfoam6/src/fvOptions/lnInclude -I/opt/openfoam6/src/meshTools/lnInclude -I/opt/openfoam6/src/sampling/lnInclude -I/opt/openfoam6/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude -fPIC -c laminarSimpleSMOKE.C -o Make/linux64GccDPInt32Opt/laminarSimpleSMOKE.o
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DOPENFOAM_VERSION=60 -w -DOPENSMOKE_USE_MKL=0 -DOPENSMOKE_USE_ISAT=0 -DDEVVERSION=1 -I../laminarSMOKE -I../laminarSMOKE/steady -I../../libs/radiationOpenSMOKE++/lnInclude -I../openSMOKEpp4laminarSMOKE/ -I/home/Laminarsmoke++/boost_1_76_0/include -I/home/Laminarsmoke++/eigen-3.4-rc1 -I/mnt/f/Laminarsmoke++/rapidxml/rapidxml-master -I/include -I/include -I/ -I/opt/openfoam6/src/finiteVolume/lnInclude -I/opt/openfoam6/src/fvOptions/lnInclude -I/opt/openfoam6/src/meshTools/lnInclude -I/opt/openfoam6/src/sampling/lnInclude -I/opt/openfoam6/src/thermophysicalModels/basic/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/laminarSimpleSMOKE.o -L/opt/openfoam6/platforms/linux64GccDPInt32Opt/lib \
-L/home/foam/OpenFOAM/foam-6/platforms/linux64GccDPInt32Opt/lib -L/home/Laminarsmoke++/boost_1_76_0/lib -lradiationOpenSMOKE++ -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lgfortran -lboost_date_time -lboost_filesystem -lboost_system -lboost_regex -lOpenFOAM -ldl \
-lm -o /home/foam/OpenFOAM/foam-6/platforms/linux64GccDPInt32Opt/bin/laminarSimpleSMOKE
/usr/bin/ld: cannot find -lgfortran
/usr/bin/ld: cannot find -lboost_filesystem
/usr/bin/ld: cannot find -lboost_regex
/opt/openfoam6/wmake/makefiles/general:140: recipe for target '/home/foam/OpenFOAM/foam-6/platforms/linux64GccDPInt32Opt/bin/laminarSimpleSMOKE' failed
make: *** [/home/foam/OpenFOAM/foam-6/platforms/linux64GccDPInt32Opt/bin/laminarSimpleSMOKE] Error 1
Manish_@ is offline   Reply With Quote
Old   May 23, 2021, 10:33
Manish Singh
options:
-update | -u update
Note
I have encountered this error while compiling the laminarSimpleSmoke solver in openFoam6.
If anyone can help, that would be really helpful. I am in urgent need to get it done.
Old   March 22, 2022, 08:52
Chris
Jury is on a distinguished road
Did anyone get this error fixed?
Jury is offline   Reply With Quote
Old   October 4, 2022, 13:57
Default CHeck for the path of libraries
Chitturi B S S N D V V R Santhosh Kumar
santhoshkumarchitturi is on a distinguished road
You should install the gfortran. Use the following two codes in the terminal respectively.
sudo apt-get install gfortran
sudo apt-get install libboost-all-dev
This might solve your issue.
Last edited by santhoshkumarchitturi; October 4, 2022 at 14:01. Reason: Rechecking the question
santhoshkumarchitturi is offline   Reply With Quote
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
