[waves2Foam] Overtopping function
Like Tree6Likes
Old   August 10, 2019, 13:01
Default Overtopping function
jfmae is on a distinguished road
Hello all!
I am now using Waves2foam as part of my research project on breakwaters. I have encountered some problems with the overtopping function, which I have implemented using the notes on the manual and one of the answers in this forum. The OpenFOAM version I am using is 2.3.0.
Attached I send a screenshot of the error message I get in the first iteration for waveFoam. At the bottom, where it says "in file /home/yl1181/OpenFOAM/... ": that directory does not exist. When I run the same case in different computers I also get non-existent directories under the following format: /home/foam/OpenFOAM/... .
Here I attach a sample basic case consisting of a flume with a slope and a box inside. It would be great if you could have a look at it and give me some advice on the case and what could be causing the error. The case runs perfectly without the overtopping function.
Additionally, I would like to have some information on how to apply porosity in waves2foam. My next stage would be to remove the box and replace it with the breakwater structure and to include porosity. However, I am a beginner with code in general and OpenFOAM and waves2foam in particular; I get quite lost without sample dictionaries or tutorials.
Any help is very much appreciated. Thank you!!!
Case.tar.gz
jfmae is offline   Reply With Quote
Old   January 23, 2020, 09:52
Ingmar Scholte
IngmarScholte is on a distinguished road
Hi all,
I also encountered the same problem when using the overtopping function and got the same error. I found that it uses rho*phi as a default input parameter, but I can't find where I could give the input of rhoPhi to the overtopping function.
Can somebody please help me with this
Kind regards,
Ingmar
IngmarScholte is offline   Reply With Quote
Old   February 3, 2020, 10:30
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi all,
It is possible to specify your own "rhoPhiName" in the overtopping dictionary; the use of "rho*phi" is only the default value.
Please see the constructor in the overtopping.C file for additional information.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   December 29, 2020, 05:34
Default rho*phi solution
George
gpouliasis is on a distinguished road
Hi all,
I was able to correct this issue by renaming rho*phi to rhoPhi in the overtopping.C source files and then recompiling the package. I am not sure if this is the fastest way, however it was straightforward and it worked just fine.
Kind Regards
ngj likes this.
gpouliasis is offline   Reply With Quote
Old   January 1, 2021, 10:12
ngj
Please note that the search string "rho*phi" is the default (due to definition in older versions), but it is possible to define a new keyword in the functionObject using the keyword "rhoPhiName". This means that one does not need to recompile or change the code.
Kind regards
Niels
Old   January 2, 2021, 07:46
George
Dear Niels,
Thanks a lot for the responce, I had already re-compiled the code before I found this post. Obviously defining "rhoPhiName" is better. (recompilation was a bit quick and dirty)
Thanks for the info and happy new year!
Kind Regards
Old   January 13, 2021, 03:34
Thumbs up hope to get an example
Ethan
ethan13 is on a distinguished road
Kind regards
Niels
Hi Niels,
I just encountered this problem now. Thanks for your solution to this problem. As I am new to this utility. I don't know how to implement what you suggested here. is it that I need to insert one more segment under functions in controlDict like below or other ways? Could you please show me one example? Thanks in advance.
functions
    rhoPhiName
        type ...;
Ethan
ethan13 is offline   Reply With Quote
Old   March 14, 2021, 16:07
Mateusz
Metqeu is on a distinguished road
Hello Niels,
I'm having a problem with the overtopping function. I also had a problem with rho*phi as some of my predecessors in this topic, but I fixed it now by modifying the relevant .C file. Unfortunately it still does not work, I'm getting this error message:
Write the overtopping
--> FOAM FATAL ERROR:
Not implemented
    From function Overtopping not implemented for boundaries
    in file overtopping/overtopping.C at line 203.
I did create the required face set, and then converted it to a face zone. It seems that this expression returns a false value:
if (mesh.isInternalFace(faceI))
Apparently, it means that the face label is not internal to the mesh. Unfortunately, I don't really know what it means. Please let me know if you have any ideas
Mateusz
Metqeu is offline   Reply With Quote
Old   March 15, 2021, 16:28
George
Originally Posted by Metqeu View Post
Hello Niels,
Not implemented
Mateusz
Hi Metqeu,
this error occurs when the overtopping face zones include boundary faces. That is the obvious, faces that are part of the boundaries and not the internal mesh. You can regulate this by playing with the bounding box in your topoSet dictionary. A nice way to visualize your overtopping faces is by using the Read Zones option in paraview. You will find this option when loading a case. Thus, before running your case you can play around with different settings in your topoSet dictionary, visualize them and repeat until you arrive at a satisfying result.
Hope it helps
ngj likes this.
Old   March 21, 2021, 14:38
Mateusz
Originally Posted by gpouliasis View Post
Hi Metqeu,
Hope it helps
Thanks a lot George! Got it all working well now.
I have noticed that the total overtopped volume varies quite a lot between simulations with different courant numbers. For example for max Co. of 0.25, the total volume is around 40 litres in my case, but for the max. Co of 0.7, the volume drops down to around 20 litres.
I've used the same grid, solver setup, wave input parameters for these simulations and yet I'm getting this large difference. Does anyone has an idea what's the reason for this? Also the overtopped volume for larger timesteps is actually closer to the experimental data.
Old   April 2, 2021, 08:14
George
Hi Metque,
I am not sure about this. Are you using the MULES (waveFoam) or isoAdvector (waveIsoFoam) method?
It is advised to use small CFL numbers in order to avoid numerical diffusion. You could verify that by plotting the wave spectrum near your structure for both cases and comparing.
I can refer you to the following works, related to overtopping with OF.
https://repository.tudelft.nl/island...8-996c18867221
https://repository.tudelft.nl/island...2-25e7fa6cf575
Metqeu likes this.
Old   April 2, 2021, 11:38
Mateusz
Hi Metque,
Thank you for your help. These dissertations will certainly be useful.
I am using MULES as I'm working on v1912 due to some problems I encountered during compilation. Do you think it would be worthwhile to switch to v2012 and try that new isoAdvector scheme?
Old   April 2, 2021, 14:21
George
Hi Metque,
no need to change to the new edition. You just need to compile the waveIsoFoam solver. This is what I did my self and it is working great.
Metqeu likes this.
Old   April 2, 2021, 15:09
Mateusz
Hi Metque,
Hi George, Did you do that on the v1912 version? I'm asking because the source files are in the v1812 and v2012 folders but not for the v1912. I'm wondering if there will be any compatibility issues.
Old   April 2, 2021, 15:14
George
Yes exactly. I just copied the folder from v1812 to 1912 and compiled the solver. Be carefull you will need to change the name of your OF version in the options file of the solver you copied. Check the bash script from the wave2foam compilation to figure out the necessary changes.
Metqeu likes this.
Old   August 4, 2021, 16:27
Default Regarding computing of overtopping for 2D models
  #16
Edwin Rajeev
edwinrajeev is on a distinguished road
Hi Metqeu,
Hope it helps
Hi George,
A quick question: Does this mean we cant to do an overtopping post processing for 2D simulations? Because the front and back faces are boundaries and the internal mesh would contain these? Has anyone computed overtopping for a 2D simulation?
Thanks
edwinrajeev is offline   Reply With Quote
Old   August 4, 2021, 16:54
Mateusz
Originally Posted by edwinrajeev View Post
Hi George,
Thanks
Hi Edwin, you can use overtopping function on a 2D case. Works great for me
ngj likes this.
Old   August 4, 2021, 17:00
Edwin Rajeev
Hi Mateusz,
Thanks for your response. I was trying to implement the overtopping on top of a breakwater in 2D and i was getting the same error as you.
I did the following steps:
topoSet:
actions
        name    overtopping.0;
        type    faceSet;
        action  new;
        source  boxToFace;
        box     (330 -1 15) (380 0 30);
setsToZones -noFlipMap
But i received the error:
Not implemented
I am not sure what I am doing wrong. COuld you let me know what I might be missing or doing wrong or the procedure that you followed?
Thank you for your response again.
Old   August 5, 2021, 02:48
Mateusz
Hi Mateusz,
topoSet:
actions
        name    overtopping.0;
        type    faceSet;
        action  new;
        source  boxToFace;
Not implemented
Okay, I've got 2 tips that will hopefully make it work for you. Your faceset needs to start at 2nd cell with respect to the wall, i.e. it could be (330.5 -1 14.5), depends on your grid of course. I know this is not ideal as I imagine some overtopping volume will be lost, but that is the only solution that worked for me. The effect might be marginal if your insert a thin grid layer next to wall.
Second, if that is a 2D case then your topoSet limits should be set to [0,0] in the 3rd dimension.
Old   August 5, 2021, 14:26
Edwin Rajeev
Hi Mateusz,
Thank you for your response.
I tried both your suggestions and I am getting the same error for this problem I even tried it even for a 3D case and still getting the same error. I am sure I am doing something out of the ordinary for it to happen like that.
I even tried it with bejibattjes tutorial cases and had the same thing happening.
Is it possible for you to share your topoDict and controlDict file for the problem? Or is there any other file I should be thinking about?
Link for the problem setup: https://drive.google.com/file/d/1lBi...ew?usp=sharing
Thank you
overtopping, porosity, toposetdict, waves2foam
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
