[waves2Foam] Compling in OpenFOAM-v1912 faceSetToSTL fatal error
Old   April 10, 2020, 14:13
Default Compling in OpenFOAM-v1912 faceSetToSTL fatal error
Akram P A
simucentral is on a distinguished road
Hi Sir,
I was trying to compile waves2Foam in OpenFOAM-v1912. While compiling, I encountered the following error.
At first I noticed in the OceanWave3D compiling section,
src/initialization/Initialize.f90:48:18:
WRITE(fileop(1),*),'Error: Problem with specified input file.'
1
Warning: Legacy Extension: Comma before i/o item list at (1)
And in this section,
COMPILE PRE-PROCESSING
wmake faceSetToSTL
Making dependency list for source file faceSetToSTL.C
wmkdepend: could not open 'foamTime.H' for source file 'faceSetToSTL.C': No such file or directory
wmkdepend: could not open 'faceTriangulation.H' for source file 'faceSetToSTL.C': No such file or directory
wmkdepend: could not open 'triSurface.H' for source file 'faceSetToSTL.C': No such file or directory
faceSetToSTL.C:56:10: fatal error: faceTriangulation.H: No such file or directory
#include "faceTriangulation.H"
compilation terminated.
/home/simucentral/OpenFOAM/OpenFOAM-v1912/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/faceSetToSTL.o' failed
And in the end, it showed this,
COMPILE BREEDER
Nothing available for compilation in the breeder
directory.
COMPILATION DONE
Is this normal? Do I have a successful completion of waves2Foam now?
Sorry, I am an absolute beginner.
Can you please enlighten me on this?
Can I make simulations on irregular waves using this version?
Thank you so much.
simucentral is offline   Reply With Quote
Old   April 10, 2020, 23:39
Akram P A
I tried to do the step again. This is the full log.
v1912
ENVIRONMENTAL VARIABLES
EXTBRANCH=0
FOAMEXTENDPROJECT=0
OFPLUSBRANCH=1
WAVES_APPBIN=/home/simucentral/OpenFOAM/simucentral-v1912/platforms/linux64GccDPInt32Opt/bin
WAVES_DIR=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam
WAVES_GSL_INCLUDE=/usr/include
WAVES_GSL_LIB=/usr/lib64
WAVES_LIBBIN=/home/simucentral/OpenFOAM/simucentral-v1912/platforms/linux64GccDPInt32Opt/lib
WAVES_POST=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/postProcessing
WAVES_PRE=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing
WAVES_SOL=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/solvers/solvers1912_PLUS
WAVES_SRC=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/src
WAVES_TUT=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/tutorials
WAVES_UTIL=/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities
WAVES_XVERSION=0
WM_PROJECT_VERSION_NUMBER=1912
COMPILE LAPACK-3.3.1
lapack-3.3.1 has already been compiled
COMPILE SPARSKIT2
SPARSKIT2 has already been compiled
COMPILE OCEANWAVE3D
Pull changes from the OceanWave3D git repository ...
Saved working directory and index state WIP on master: bb7d99e bug fix for calling OceanWave3D
Already up to date.
On branch master
Your branch is up to date with 'origin/master'.
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
modified: common.mk
modified: makefile
no changes added to commit (use "git add" and/or "git commit -a")
Dropped refs/stash@{0} (7938bab451ff38c15143839641b4d8b763466cb0)
OceanWave3D has already been compiled
/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/ThirdParty
COMPILE FENTON4FOAM
fenton4Foam has already been compiled
COMPILE LIBRARY
v1912
wmake libso (waves2Foam)
wmake libso (waves2FoamProcessing)
wmake libso (waves2FoamSamplingNew)
wmake libso (waves2FoamPorosity)
COMPILE SOLVERS
wmake faceSetToSTL
make[1]: Entering directory '/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/faceSetToSTL'
g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/triSurface/lnInclude -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -DOFVERSION=1912 -DEXTBRANCH=0 -IlnInclude -I. -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/home/simucentral/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude -fPIC -c faceSetToSTL.C -o Make/linux64GccDPInt32Opt/faceSetToSTL.o
make[1]: *** [Make/linux64GccDPInt32Opt/faceSetToSTL.o] Error 1
make[1]: Leaving directory '/home/simucentral/OpenFOAM/simucentral-v1912/applications/utilities/waves2Foam/applications/utilities/preProcessing/faceSetToSTL'
/home/simucentral/OpenFOAM/OpenFOAM-v1912/wmake/makefiles/apps:29: recipe for target 'faceSetToSTL' failed
make: *** [faceSetToSTL] Error 2
COMPILE POST-PROCESSING
COMPILE BREEDER
directory.
COMPILATION DONE
Posting this update in the hope that it will provide more info.
Old   April 26, 2020, 05:17
Akram P A
With this setup, I tried to run the 3DWave tutorial problem. However, I couldn't run the case. In the log.faceSet and the subsequent log files, it says..
/home/simucentral/OpenFOAM/OpenFOAM-v1912/bin/tools/RunFunctions: line 228: faceSet: command not found
Any advice on how to proceed?
Old   April 26, 2020, 14:27
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hallo,
I just tried compiling under 1912 with a clean check-out from the repository. It compiled without any problems.
The missing faceSet is due to a obsolete functionality in OpenFoam. Please adjust by using topoSet instead.
Kind regards
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   April 27, 2020, 16:43
Smile
Akram P A
Hi Niels,
Thank you so much for your quick response.
As advised, I did a clean up and did a fresh check out and compiled again. I ran the 3Dwaves tutorial problem again. The faceSet showed the same error.
However, the waveFoam completed the run. This is the first look.
I will try with topoSet instead of faceSet, then I will need the topoSetDict.I will have to study more to get that right.
I was going to compile v1812 actually.
Thank you Niels.
Warm Regards,
Akram
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
