[PyFoam] plm_rsh_agent path not found
Old   July 17, 2020, 14:32
Default plm_rsh_agent path not found
mahmoodn is on a distinguished road
The following command has no problem
mpirun porousSimpleFoam -parallel
However, when I use pyFoam, I get an error about plm_rsh_agent path not found:
$ pyFoamPlotRunner.py --procnr=16 porousSimpleFoam
 PyFoam WARNING on line 144 of file /home/marzieh/.local/lib/python3.6/site-packages/PyFoam/Execution/ParallelExecution.py : which can not find a match for porousSimpleFoam . Hoping for the best
The value of the MCA parameter "plm_rsh_agent" was set to a path
that could not be found:
  plm_rsh_agent: rsh
Please either unset the parameter, or check that the path is correct
Killing PID 28219
I didn't find a clear solution for that. I actually don't know is that a problem with pyFoam or mpi? Since I don't have an problem with mpirun, it should be a problem with pyFoam.
Any idea about that?
mahmoodn is offline   Reply With Quote
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
wmake error zxj160 OpenFOAM 0 March 26, 2012 10:52
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
