[waves2Foam] Trying to add a new wave theory
Old   March 19, 2015, 03:19
Default Trying to add a new wave theory
Pablo Montalvo
Olbap is on a distinguished road
Hello everyone,
I started using OpenFOAM (2.3.0) recently and enjoyed it a lot. I really like the development of the waveFoam package, congratulations! Everything is built perfectly and I managed to run every tutorial, but now I have encountered a problem.
I want to add a new wave theory which is just a first order Stokes wave with modulation. So I wrote the .C and the header corresponding, and tried to run my case, which is for now the tutorial 3DWaves but with FirstOrderModulated for the wave theory.
I got the following error
setWaveParameters
Create time
Reading g
Reading waveProperties
--> FOAM FATAL ERROR:
Unknown wave property type stokesFirstModulationProperties
Valid wave property types are :
14
solitaryFirstProperties
stokesSecondProperties
cnoidalFirstProperties
combinedWavesProperties
potentialCurrentProperties
irregularProperties
bichromaticFirstProperties
stokesSecondModulationProperties
streamFunctionProperties
bichromaticSecondProperties
stokesFirstStandingProperties
externalSourceProperties
stokesFirstProperties
stokesFifthProperties
    From function setWaveProperties::New(const fvMesh&, const Time&, ...)
    in file preProcessing/setWaveProperties/setWaveProperties.C at line 261.
FOAM exiting
so I searched on the forum and I saw that one should add the wave properties files (code and header) in /waves2Foam/src/waves2FoamProcessing/preProcessing/setWaveProperties/ and /regular/ in my case. So I did, and modified the Make/files in waves2FoamProcessing, and built it without error. However, I still have the same error when I try to run my case. Do you know what could be the issue? Thanks in advance!
Olbap is offline   Reply With Quote
Old   February 8, 2021, 12:00
Arun Kumar
AR91 is on a distinguished road
Originally Posted by Olbap View Post
Hello everyone,
setWaveParameters
Create time
Reading g
14
irregularProperties
FOAM exiting
I am facing the same issue. Did you find a solution!?
Thanks,
Arun.
AR91 is offline   Reply With Quote
Old   February 16, 2021, 16:29
Arun Kumar
Thanks,
Arun.
Once again I stumbled onto the solution on my own. It is probably the 7th time this has happened after having asked a question on the forum and receiving no help.
To anyone who might be in this trouble. Check your WAVES_APPBIN and WAVES_LIBBIN in bin/bashrc inside waves2Foam. I set these to $FOAM_USER_APPBIN and $FOAM_USER_LIBBIN respectively. That fixed the issue.
Regards,
Arun.
Old   October 8, 2021, 04:20
irengclenk
irengclenk is on a distinguished road
Hi guys,
I am a beginner and was able to solve this by doing this:
1. check the options file is avalaible in the make folder. So if we want to modify the set wave properties
check the make folder here /home/u0142217/OpenFOAM/waves2Foam-master/src/waves2FoamProcessing/preProcessing
chosse the correct option version and rename it into options
2. Make sure the modified folder is written in the files
3. ./Allwmake
That worked for me. Hope it helps
irengclenk is offline   Reply With Quote
Pressure for wave height in an Water Wave Tank Cluain CFX 8 December 6, 2021 03:58
[waves2Foam] How to use stream function wave theory Melo1993 OpenFOAM Community Contributions 9 May 29, 2020 07:11
[waves2Foam] New wave theory coded in FORTRAN, how to add to waves2Foam? Kun_zheng OpenFOAM Community Contributions 6 August 30, 2017 04:58
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 09:23
Wave Theory oliver.mulryan Main CFD Forum 10 July 9, 2000 11:35
