[Other] Multi species mass transport library [update] |
June 14, 2012, 05:34 |
Valerio Novaresio
Rep Power: 17 |
Dear all,
I'm happy to release an updated version of multi species mass transport library based on "Novaresio V., Garcìa-Camprubì M., Izquierdo S., Asinari P., Fueyo N., An Open-Source Library for the Numerical Modeling of Mass-Transfer in Solid-Oxide Fuel Cells, Computer Physics Communications, Elsevier B.V., pp. 22, 2011, Vol. 183, pag. 125-146, ISSN: 0010-4655, DOI: 10.1016/j.cpc.2011.08.003". I'd like to underline that the contribution of all the authors was fundamental (let me say indispensable...) for the theoretical background of this library. The library is fully integrated with OpenFOAM-1.6-ext (succesfully tested with "clean" version obtained using git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext). The diffusivityModels library contains a series of classes to compute binary diffusion coefficients (ChapmanEnskog, Wilke, Fuller, Constant) and Knudsen diffusion coefficien for porous media. The multiSpeciesTransportModels library contains a series of models to compute diffusive fluxes (SchmidtNumber, LewisNumber, FickDilutedMixture, Fick, MaxwellStefan). There are few differences between this library and the paper. In attached one can find a short documentation that also describes this differences. The library comes with a solver (a modified version of reactingFoam that can use the multi species mass library) and with a simple test case for methane laminar combustion (special thanks to Silvano Pautasso). The ./install script copies and compiles all files respectively in $FOAM_USER/lib, $FOAM_USER/applications and $FOAM_USER/run. Probably the code still has some bugs. Any suggestion, feedback. correction or further improvement will be appreciated. Best regards Valerio
...The best way to acquire new knowledge is to share it... |
June 14, 2012, 06:56 |
Anton Kidess
Rep Power: 29 |
I suggest also putting a link on the wiki: http://openfoamwiki.net/index.php/Main_ContribOther
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
June 14, 2012, 08:24 |
Valerio Novaresio
Rep Power: 17 |
Dear Anton,
I will follow your suggestion soon. Many thanks Valerio
June 14, 2012, 14:11 |
Library conversion to be compatible with OF-12.1.1
Elhaddad
Rep Power: 13 |
Hi All,
that are really good news, but that will be also nice getting able to run the library under OF-2.1.1. Many will be happy to read the programmer's suggestions regarding this. BR |
June 15, 2012, 08:08 |
Niklas Nordin
Rep Power: 29 |
Im in the process of updating your library to 2.1.x and I have a small question.
For instance, the correct routine in Fick.C show that there is a slight chance of making an easy mistake, (without knowing probably) the inert species mass fraction is grabbed from thermo like this. // Calculate inert species volScalarField& yInert = thermo_.composition().Y()[inertIndex_]; which is set to 1 - sum of the first N-1 species, like this yInert = 1 - yt; since yt is just calculated in the loop forAll(this->D_, i) where D is D_.setSize(species().size()-1); and it gets the name "D_" + species()[i], so D is 1 less than the number of species Now...if the inert specie is not placed in the last position in the species list, the inertIndex will point to the wrong specie and it will use the inertspecie to calculate yt... so basically everything will be a mess. why dont you do it like in the YEqn.H where you check the name of the species to see if its the same as the inert specie name if (Y[i].name() != inertSpecie) or if (i != inertIndex_) to prevent people from making this mistake and allow the inert specie to be placed anywhere in the species list. just a thought, N |
June 15, 2012, 09:51 |
Valerio Novaresio
Rep Power: 17 |
Dear Niklas,
you are completely right! Actually the library works only if the inert species occupies the last position. But (and I'm sorry for this) I forgot to mention it. This implementation is a kind of "misprint" of the firsts code versions . This bug fix was on to my to-do list, but I completely forgot it. I will add it again in my new to-do list! Many thanks to have discovered (and shared) this problem. Surely it will be useful for all people that want to experiment the library. Thanks again Valerio
July 17, 2012, 06:18 |
José Rodrigues
Rep Power: 15 |
Dear Niklas,
Did you manage to update Novaresio's library into OF 2.1.x? I'd be really interested on it. Does it use cantera for the transport properties? Regards Jose |
June 29, 2018, 23:27 |
#8 | |
Gao Zhengwei
Rep Power: 9 |
I am new here and trying to modfity this code. Nikilas provided a good suggestion and I noticed that some codes are needed to be modified to ensure the consistence. In file multiSpeciesTransportModel.C and multiSpeciesTransportModel.H: I added a private member inertSpecie_ , which is initialized as inertSpecie_(thermo.lookup("inertSpecie")), In the function correct() in file Fick.C, a slight change is made: [I] volScalarField yt = 0.0*thermo_.composition().Y(0); surfaceScalarField nt = turbulence_.phi(); label inertIndex = -1; forAll(species(), i) { volScalarField& yi = thermo_.composition().Y(i); surfaceScalarField& ni = n_[i]; if (yi.name() != inertSpecie_) { tmp<fv::convectionScheme<scalar> > mvConvection ( fv::convectionScheme<scalar>::New ( mesh_, fields, turbulence_.phi(), mesh_.divScheme("div(phi,Yi_h)") ) ); if (mesh_.relaxField("Yi"))//Mohsen { yi.storePrevIter(); } tmp<fvScalarMatrix> yEqn ( fvm::ddt(thermo_.rho(), yi) // + fvm::div(turbulence_.phi(), yi, "div(phi,Yi_h)") + mvConvection->fvmDiv(turbulence_.phi(), yi) - fvm::laplacian(D_[i],yi, "laplacian(D,Yi)") == Sy_ ); eqnResidual = solve(yEqn() , mesh_.solver("Yi")).initialResidual(); maxResidual = max(eqnResidual, maxResidual); if (mesh_.relaxField("Yi"))//Mohsen { yi.relax(mesh_.fieldRelaxationFactor("Yi"));//Mohsen } yi.max(0.0); // yi.min(1.0); ni = yEqn().flux(); nt -= ni; yt += yi; } else { inertIndex = i; } } // Calculate inert species volScalarField& yInert = thermo_.composition().Y()[inertIndex]; yInert = 1 - yt; forAll(yInert.boundaryField(), boundaryI) { forAll(yInert.boundaryField()[boundaryI], faceI) { yInert.boundaryField()[boundaryI][faceI] = 1- yt.boundaryField()[boundaryI][faceI]; } } yInert.max(0.0); n_[inertIndex] = nt; updateMolarFractions(); return maxResidual; Note that, the inertIndex is not the same inertIndex_ in multiSpeciesTransportModel.H I hope this will be helpful. |
February 17, 2019, 18:43 |
Update of library to OpenFOAM 6
#9 |
Joachim Herb
Rep Power: 21 |
I have created a non-complete update of the library to OpenFOAM-6. Main changes: - Handling of references, which are now const - The definition of turbulence.phi() seems to have changed: It is now a volume flux, but a mass flux is need, so that has been added as additional internal variable - Chemistry has changed so much, that I have (hopefully temporarily) disabled it. It compiles and runs (TM). I just tested it with the testCase given in the original library without chemistry. Any comments/improvements are welcome. |
February 18, 2019, 17:14 |
#10 | |
Joachim Herb
Rep Power: 21 |
Updates:
- To use transport const, thermo hConst change the commented lines in multiSpeciesTransportModels.C from Code:
// makeMultiSpeciesTransportModel(Fick, gasThermoPhysics); ... Code:
makeMultiSpeciesTransportModel(Fick, constGasHThermoPhysics); ... To start the attached test case, issue the following commands: Code:
blockMesh setFields modifiedReactingFoam Quote:
June 19, 2012, 22:55 |
#11 | |
chenxizhong
Rep Power: 14 |
Dear Niklas, I canot open the pdf file after downloaded , can you check the file or send me a copy, many thanks!
my email is suningchen@gmail.com Quote:
June 20, 2012, 08:27 |
#12 |
Niklas Nordin
Rep Power: 29 |
Sorry, but I cannot read the pdf either. It says its damaged.
July 17, 2012, 06:21 |
#13 | |
José Rodrigues
Rep Power: 15 |
Could you kindly re-upload the pdf file you posted on the 1st post to this thread? The original seems to be corrupt. Thank you! Regards Jose |
July 17, 2012, 16:18 |
#14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Well, this was funny... guess what: the 1st PDF file is in fact a DVI file!!! I opened it easily with Ubuntu's default "Document Viewer" from the Evince authors and was finding it strange that everyone wasn't able to open it. So I then tried with Gimp and it did complain about the bad PDF file. Tried with pdfedit to open it, same problem. pdf2ps, same deal. So I then did what I usually do: open the file with a text editor (or hex editor, if necessary) and saw several bytes then something about "TeX" and more bytes... so I then tried dvipdf et voilà, there you have it, the real PDF Have fun! Bruno
July 17, 2012, 16:52 |
#15 |
José Rodrigues
Rep Power: 15 |
LOL... funny
Thanks Bruno! Looks much better now! |
July 19, 2012, 07:20 |
#16 |
José Rodrigues
Rep Power: 15 |
Hi Again everyone!
I managed to compile Novaresio's library and the modifiedReactingFoam solver. Now I want to set up a new simulation with Smooke's chemistry scheme but the library needs addtional info in the transportDictionary, namely the collision diameter and the characteristic Lennard-Jones energy of each involving species, to compute the binary diffusion coefficient. I found in Novaresio's paper the some of these data is tabulated in "Hirshfelder et al., Molecular Theory of Gases and Liquids". However, neither the values he has in example case (supplied with the library) correspond to the ones in the former reference (despeite units), nor I am able to find data for all the species, namely, OH, H2O2, H, O, HCO, etc. Does anybody have any idea where can I find this data? Novaresio, could you enlighten me on this? Where did you get your data? Regards everyone! |
July 19, 2012, 11:55 |
#17 |
Marco A. Turcios
Rep Power: 28 |
I've been monitoring this thread and am quite interested in experimenting with it. Jose, other than Niklas' comment about the inert species, were there any other fixes required to get it running in 2.1.x? From your earlier comments it appears you were gunning for that.
Thanks! |
July 19, 2012, 12:02 |
#18 | |
José Rodrigues
Rep Power: 15 |
If you have any news on this please report them. I am very much interested on it. Anyways, if I have the time and patience, I will try to do it myself. Regards |
July 19, 2012, 12:08 |
#19 |
Marco A. Turcios
Rep Power: 28 |
No worries. I'm sure Niklas would have mentioned something else had he come across it. I've done work with both versions and have some experience adapting between the two, so maybe I'll also tackle it if I find the time (been working on polyTopoChangers in 21x and that's been taking a LOT of time).
Cheers |
July 19, 2012, 12:36 |
#20 | |
José Rodrigues
Rep Power: 15 |
Hi Again
I am getting a strange error with modifiedReactingFoam solver: If I try to use a Chemkin file as input for chemical scheme I get this error: Quote:
You can replicate this (i guess) by simply replacing the chemkin file (chem.inp) used in the dieselFoam tutorial distributed with OF by the chemistry used in the modifiedReactingFoam test case. Everything else is untouched. Cheers |
Species Mole and Mass Fraction Macro | combustion | FLUENT | 18 | February 5, 2024 12:23 |
UDS and fluent internal species transport model | jinsong | FLUENT | 0 | May 3, 2018 11:37 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
Surface instabilities with 2-phase species transport | richard222 | Fluent Multiphase | 0 | May 4, 2016 04:06 |
Questions for a species transport problems (snapshots attached) | aleisia | FLUENT | 2 | October 9, 2011 04:40 |
