[Helyx OS] Paraview can't find mesh
Old   June 27, 2020, 12:24
Default Paraview can't find mesh
Lauren Dransfield
ld1305 is on a distinguished road
I've been looking at using Helyx OS for the first time today, but keep running into a problem quite early on.
I've generated a bounding box, imported an STL to sit inside it, and generated a mesh. The mesh check comes back as OK. At this point I'd ideally like to view the mesh to have a look at the boundary, so I save and move to the Solver tab and open ParaView.
At this point I get the following error:
ERROR: In /home/ubuntu/OpenFOAM/OpenFOAM-7/applications/utilities/postProcessing/graphics/PVReaders/PVFoamReader/vtkPVFoamReader.cxx, line 202
vtkPVFoamReader (0x557b30e089a0): could not find valid OpenFOAM mesh
ERROR: In /home/ubuntu/OpenFOAM/ThirdParty-dev/ParaView-5.6.0/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 779
vtkPVCompositeDataPipeline (0x557b36171520): Algorithm vtkPVFoamReader(0x557b30e089a0) returned failure for request: vtkInformation (0x557b342d3010)
Debug: Off
Modified Time: 221672
Reference Count: 1
Registered Events: (none)
Request: REQUEST_INFORMATION
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
Any help is much appreciated, I'm possibly missing something pretty simple due to inexperience
If it helps, I'm using Helyx OS 2.4.0 with OpenFOAM 7
ld1305 is offline   Reply With Quote
Old   September 6, 2020, 04:00
sila
silambarasan7 is on a distinguished road
I am also getting same error
silambarasan7 is offline   Reply With Quote
Old   January 11, 2022, 17:24
Estudante
cleitontrindade is on a distinguished road
I was also having this problem, and I reduced the domain and it solved
cleitontrindade is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Dont find the converge in NACA0012 with structured mesh ynos OpenFOAM Running, Solving & CFD 2 December 14, 2013 06:03
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
