[swak4Foam] Dynamically morphing airfoil using groovyBC
Old   May 20, 2022, 04:35
Default Dynamically morphing airfoil using groovyBC
toolpost is on a distinguished road
Hello
I am trying to simulate 2D flow around a dynamically morphing airfoil using OpenFOAM-v2106. The airfoil surface near the trailing edge is supposed to morphed downwards with time. I believe this can be achieved using groovyBC. I set everything up and the mesh seems to move, but I am facing a weird issue.
The original C-type mesh is created in ICEM CFD, and exported to OpenFOAM. I want to keep the first cell height near the wall as constant throughout the simulation in order to keep a constant y+. But as you can see from the screenshots, in the very first iteration something weird happens and the mesh moves in an abnormal way. In the first time step, the airfoil wall didn't move, but the mesh around it moved. This results in a deformed mesh where the wall distance become reduced on the top side but keeps as expected in the bottom side. Later from the next time-step on-wards, the mesh deforms in the same manner I expected, and from thereon the wall distance no longer changes.
I cannot post the case file here, because the mesh size is large. A minimalistic cellDisplacementDict to reproduce this is given below.
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      cellDisplacement;
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    TOP
           type          groovyBC;
         value        uniform (0 0 0);
          valueExpression    "vector(0,df,0)";
           variables
        "df=-0.3*time();"
    BOTTOM
           type          groovyBC;
           variables
        "df=-0.3*time();"
    FIXEDWALLS
        type            fixedValue;
    INLET
        type            fixedValue;
    OUTLET
        type            fixedValue;
    frontAndBack
        type            empty;
This is dynamicMeshDict
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      dynamicMeshDict;
 dynamicFvMesh   dynamicMotionSolverFvMesh;
 motionSolverLibs ("libfvMotionSolvers.so");
 motionSolver    displacementLaplacian;
 diffusivity  directional (20 0.1 0);
What am I doing wrong? Any suggestions would be greatly appreciated.
toolpost is offline   Reply With Quote
Old   May 20, 2022, 11:47
Deleted.....
Problem with airfoil shape optimization robyTKD SU2 Shape Design 7 March 7, 2022 16:18
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 09:48
