[swak4Foam] swak4foam for OpenFOAM 4.0
Like Tree28Likes
Old   July 8, 2016, 06:19
Default swak4foam for OpenFOAM 4.0
mnikku is on a distinguished road
So, this is pretty soon after the new version was launched, but has anyone managed to install swak4foam for OpenFOAM 4.0? Any ideas is the current version available even compatible? I couldn't get the development version to install "out of the box" and decided to ask around first to see if I should spend time trying on it, that is is it even possible or not.
3004207032 likes this.
mnikku is offline   Reply With Quote
Old   July 11, 2016, 11:07
Thumbs down compilation error !
T.D. is on a distinguished road
I tried to compile swak4foam version 0.4 with openfoam4.0 (in 64 bit), but always with no success. here the error:
-o Make/linux64GccDPInt64Opt/helpers/exprString.o
In file included from lnInclude/CommonValueExpressionDriver.H:843:0,
                 from helpers/exprString.C:39:
lnInclude/CommonValueExpressionDriverI.H: In member function ‘Foam::tmp<Foam::Field<bool> > Foam::CommonValueExpressionDriver::doLogicalNot(const Foam::Field<bool>&)’:
lnInclude/CommonValueExpressionDriverI.H:1176:22: error: assignment of read-only location ‘(& res.Foam::tmp<T>::operator()<Foam::Field<bool> >())->Foam::Field<bool>::<anonymous>.Foam::List<bool>::<anonymous>.Foam::UList<T>::operator[]<bool>(i)’
             res()[i] = a[i];
/home/TD/OpenFOAM/OpenFOAM-4.0/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt64Opt/helpers/exprString.o' failed
make: *** [Make/linux64GccDPInt64Opt/helpers/exprString.o] Error 1
Parser library did not compile OK. No sense continuing as everything else depends on it
Requirements for Library not satisfied. I see no sense in going on
Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard
Regards,
T.D.
T.D. is offline   Reply With Quote
Old   July 12, 2016, 02:51
Seems pretty similar to the error I received:
lnInclude/CommonValueExpressionDriverI.H:1170:22: error: assignment of read-only location ‘(& res.Foam::tmp<T>::operator()<Foam::Field<bool> >())->Foam::Field<bool>::<anonymous>.Foam::List<bool>::<anonymous>.Foam::UList<T>::operator[]<bool>(i)’
             res()[i] = a[i];
make: *** [Make/linux64GccDPOpt/helpers/exprString.o] Error 1
make: *** Waiting for unfinished jobs....
Old   July 27, 2016, 15:30
Sam Salehian
SmokedJuggler is on a distinguished road
Hi everyone,
I am trying to install sawkFOAM
my un=buntu version is 14.04
OpenFOAM version is 4.0
Swak version is 0.4.0
Bison is version 2.7.12-4996
Flex is version 2.5.35 (Minor version: 35)
I am getting the following errors:
reviously compiled for OpenFOAM 4.0
/home/sam/OpenFOAM/sam-4.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
No file 'swakConfiguration'. Python etc won't work. See README for details
Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems
Checking swak4Foam-version and generating file
abort: no repository found in '/home/sam/OpenFOAM/sam-4.0/swak4Foam' (.hg not found)!
OpenFOAM-version: Major 4 Minor 0 Patch 0 (-1 == x / 0) Fork: openfoam
No change to swak4FoamParsers/foamVersion4swak.H
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c helpers/exprString.C -o Make/linux64GccDPInt32Opt/helpers/exprString.o
lnInclude/CommonValueExpressionDriverI.H: In member function ‘Foam::tmp<Foam::Field<bool> > Foam::CommonValueExpressionDriver::doLogicalNot(co nst Foam::Field<bool>&)’:
lnInclude/CommonValueExpressionDriverI.H:1176:22: error: assignment of read-only location ‘(& res.Foam::tmp<T>:perator()<Foam::Field<bool> >())->Foam::Field<bool>::<anonymous>.Foam::List<bool>:: <anonymous>.Foam::UList<T>:perator[]<bool>(i)’
res()[i] = a[i];
make: *** [Make/linux64GccDPInt32Opt/helpers/exprString.o] Error 1
I would appreciate if someone could help me
Regards,
SmokedJuggler is offline   Reply With Quote
Old   August 4, 2016, 14:22
fluidflow
ARUNAVA SENGUPTA is on a distinguished road
Hi All,
I am also getting the same error while installing swak4Foam in OpenFOAM 4.0 in ubuntu 14.04. Any help how to rectify the error ?
With regards,
here is the tarball attachment of the log file
Last edited by wyldckat; September 17, 2016 at 06:51. Reason: merged posts done a few minutes apart
ARUNAVA SENGUPTA is offline   Reply With Quote
Old   August 4, 2016, 15:17
Default swak4Foam installation in OpenFOAM 4.0
fluidflowsteel
fluidflowsteel is on a distinguished road
Hi All,
I am trying to install swak4Foam in OpenFOAM 4.0 in Ubuntu 14.04. Getting the following error. also find attached the tarball of the log file.
Previously compiled for OpenFOAM 4.0
/home/arunava/OpenFOAM/arunava-4.0/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison)
abort: no repository found in '/home/arunava/OpenFOAM/arunava-4.0/swak4Foam' (.hg not found)!
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/GlobalVariablesRepository.C -o Make/linux64GccDPInt32Opt/repositories/GlobalVariablesRepository.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c namedEnums/MeshInterpolationOrder.C -o Make/linux64GccDPInt32Opt/namedEnums/MeshInterpolationOrder.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c namedEnums/LogicalAccumulationNamedEnum.C -o Make/linux64GccDPInt32Opt/namedEnums/LogicalAccumulationNamedEnum.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c namedEnums/NumericAccumulationNamedEnum.C -o Make/linux64GccDPInt32Opt/namedEnums/NumericAccumulationNamedEnum.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c ExpressionDriverWriter.C -o Make/linux64GccDPInt32Opt/ExpressionDriverWriter.o
res()[i] = a[i];
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c ExpressionResult/ExpressionResult.C -o Make/linux64GccDPInt32Opt/ExpressionResult/ExpressionResult.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c ExpressionResult/StoredExpressionResult.C -o Make/linux64GccDPInt32Opt/ExpressionResult/StoredExpressionResult.o
In file included from CommonValueExpressionDriver.H:843:0,
from ExpressionDriverWriter.C:39:
res()[i] = a[i];
ExpressionResult/ExpressionResult.C: In member function ‘void Foam::ExpressionResult::uglyDelete()’:
ExpressionResult/ExpressionResult.C:311:20: warning: deleting ‘void*’ is undefined [enabled by default]
delete valPtr_;
make: *** [Make/linux64GccDPInt32Opt/ExpressionDriverWriter.o] Error 1
with regards,
Last edited by wyldckat; September 11, 2016 at 15:58. Reason: Added [CODE][/CODE] markers
fluidflowsteel is offline   Reply With Quote
Old   August 4, 2016, 17:18
Jeff
jf_vt is on a distinguished road
According to the developper:
https://twitter.com/swakPyFoam
OF 4.0 is not supported in swak 0.4.0
I am also waiting
JF
jf_vt is offline   Reply With Quote
Old   August 16, 2016, 12:43
Pedro
pupo is on a distinguished road
Any updates on this front?
cheers
pupo is offline   Reply With Quote
Old   September 9, 2016, 16:27
Default bump!
Skanner Darkly
samtheman23 is on a distinguished road
me too!
Would love to see swak4Foam work in OF4.0. Seems like an amazing 'toolset'.
samtheman23 is offline   Reply With Quote
Old   September 14, 2016, 05:47
Default me too, too
Kim Ravn-Jensen
kimrj is on a distinguished road
I would have liked to contribute with a swak4Foam build for OpenFOAM 4.0. In the absense of that, I can contribute with:
  1. samtheman23: swak4Foam is an amazing toolset. I use swak4Foam on a daily basis with OpenFOAM 2.3.1.
  2. The compilation error message quoted above in this thread is a rather trivial consequence of a class method layout modification in OpenFOAM 4.0. However, when this has been corrected, (to me) nontrivial compilation error messages follow. I believe that swak4Foam can only be updated by somebody who really understands the swak4Foam code as well as the new class standards of OpenFOAM 4.0.
Coding gurus, please come to our rescue...
kimrj is offline   Reply With Quote
Old   September 16, 2016, 11:43
Lucas
LucasCosta is on a distinguished road
have someone resolved this problem?
LucasCosta is offline   Reply With Quote
Old   September 17, 2016, 06:56
Retired Super Moderator
Bruno Santos
Quick answer to everyone on this thread: Bernhard, the author of swak4Foam, is working on this, as he's mentioned here: https://twitter.com/bgschaid/status/776174507073699841 - and I quote:
Currently working on making #swak4foam compile on 4.0 The removal of „const &“ breaks a lot of stuff
There were a lot of changes made between OpenFOAM 3.0 and 4.0, which has lead to the current delay in an update for swak4Foam. And since each release of swak4Foam has to support more than one OpenFOAM version, it's taking longer this time to solve the current massive changes that happened in OpenFOAM.
You may have to wait at least a few more weeks until it's fully operational. In the meantime, if you truly need to use swak4Foam, you might want to take a step back to OpenFOAM 3.0.1.
Old   September 26, 2016, 18:23
Bruno Santos
Quick news update: Bernhard has managed to finish adapting swak4Foam to build with OpenFOAM 4.0 and OpenFOAM+ v1606+: https://twitter.com/swakPyFoam/statu...93042482642948
I won't be able to update and test the wiki right now, but here is what I expect that will work as intended, for the steps on how to download swak4Foam from the Mercurial repository:
  1. First, go into a good working folder. Run the following commands in a terminal to get to a good folder:
    mkdir -p $FOAM_RUN
    cd "$FOAM_RUN/../"
  2. The use either the first or the second option below:
    1. From the main Mercurial development repository, using the hg command, download from the repository and checkout the right branch:
      hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam swak4Foam
      cd swak4Foam && hg update develop
    2. Or manually download a snapshot from the Mercurial interface at Sourceforge.net:
      1. Go to this page: Mercurial repository for swak4Foam - branch "develop"
      2. Request a snapshot on that page; in other words click on the link Download Snapshot.
      3. Unpack the downloaded file and move the unpacked folder, into the folder indicated by this command: pwd
      4. Rename the folder to "swak4Foam".
These steps above will replace the step #3 on this list: http://openfoamwiki.net/index.php/In...tall_swak4Foam
edit: On post #40 you can find more details about how these instructions alone were a bit flawed.
arvindpj, mf3, yuanjiahui and 1 others like this.
Old   September 27, 2016, 14:58
Pedram
cfdGeek is on a distinguished road
Thanks wyldckat,
Though it's still giving the same error:
make: *** [Make/linux64GccDPInt32Opt/FieldValueExpressionParser.o] Error 1
cfdGeek is offline   Reply With Quote
Old   September 27, 2016, 15:39
Assistant Moderator
Bernhard Gschaider
Originally Posted by cfdGeek View Post
Thanks wyldckat,
The actual error is a few lines above what you're posting. Please look for that
BTW: are you using the released version of OF 4.0?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 27, 2016, 16:27
Bruno Santos
Quick status: swak4Foam "develop" branch, commit "3077:1989d3b9632b":
  1. Cannot be built with OpenFOAM 4.0, due at least to a bug in "src/finiteVolume/finiteVolume/fvc/fvcD2dt2.C", that was fixed here: https://github.com/OpenFOAM/OpenFOAM...3fdbb2d78ebe3e
  2. Cannot be built with the released OpenFOAM+ v1606+, due to the same exact bug
  3. Can be built with OpenFOAM 4.x, at least with the tree up commit be7fba6cff9b.
The tweet was a bit misleading The released snapshot versions are not supported, only the repository versions seem to be...
Old   September 27, 2016, 17:31
Pedram
Thanks for quick reply, here is the error:
../FieldValueExpressionParser.yy:3697:13: required from here
/opt/openfoam4/src/finiteVolume/lnInclude/fvcD2dt2.C:53:20: error: passing ‘const Foam::fv::d2dt2Scheme<Foam::SphericalTensor<double > >’ as ‘this’ argument of ‘Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh> > Foam::fv::d2dt2Scheme<Type>::fvcD2dt2(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = Foam::SphericalTensor<double>]’ discards qualifiers [-fpermissive]
and to answer your question yes I'm using OF 4.0
Old   September 27, 2016, 19:12
Assistant Moderator
Bernhard Gschaider
Nope. I added patches to the sources https://sourceforge.net/p/openfoam-e...distroPatches/ and also pointed to them in the README. There is only soo much place in a tweet
wyldckat and Vanadyel like this.
Old   September 27, 2016, 19:14
Assistant Moderator
Bernhard Gschaider
Yep. That is a bug in the OF 4.0 sources. Have a look in the distroPatches directory and apply the patch to your distribution. The problem should be fixed in the next OF-release
Old   September 30, 2016, 09:05
  #20
Sachin
smodh is on a distinguished road
hi....i am new in openfoam. is there anybody know how to install swak4Foam in openfoam4.0.
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/RepositoryBase.C -o Make/linux64GccDPInt32Opt/repositories/RepositoryBase.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/SurfacesRepository.C -o Make/linux64GccDPInt32Opt/repositories/SurfacesRepository.o
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/sampling/lnInclude -I/opt/openfoam4/src/fileFormats/lnInclude -I/opt/openfoam4/src/triSurface/lnInclude -I/opt/openfoam4/src/dynamicMesh/lnInclude -I/opt/openfoam4/src/surfMesh/lnInclude -I/opt/openfoam4/src/lagrangian/basic/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c repositories/MeshesRepository.C -o Make/linux64GccDPInt32Opt/repositories/MeshesRepository.o
/opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/helpers/exprString.o' failed
smodh is offline   Reply With Quote
[swak4Foam] swak4Foam installation on OpenFOAM 4.0 blttkgl OpenFOAM Community Contributions 1 March 14, 2017 11:06
[swak4Foam] and twoPhaseEulerFoam mnikku OpenFOAM Community Contributions 1 February 19, 2016 05:21
source term in near wall cell rajcfd OpenFOAM Pre-Processing 5 February 1, 2016 10:31
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
