[Other] rhoEnergyFoam-Compressible Low-Dissipative solver |
August 11, 2018, 07:30 |
Hi all,
I recently developed rhoEnergyFoam, a compressible solver with shock capturing capabilities that is sensibly less dissipative than the standard compressible OpenFOAM solvers. The solver is described in the following publication https://www.sciencedirect.com/scienc...45793017301305 and the source code is available for research purposes at http://newton.dima.uniroma1.it/rhoenergyfoam/ Cheers, Davide |
December 22, 2018, 11:27 |
Michael Alletto
Rep Power: 15 |
just tied to connect to the web page of the solver, but the web page seems unreachable.
December 23, 2018, 18:20 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: The server must have gone down only recently. There is a Google Cache dated 21st of December 2018, so only a couple of days ago. You can find it by searching for:
site:uniroma1.it rhoenergyfoam
March 26, 2023, 06:40 |
Using rhoEnergyFoam for hypersonic flow to simulate HIT
SHISHIR SRIVASTAVA
I would like to use rhoEnergyFoam for homogeneous isotropic decaying turbulence for hypersoinc flows. This simulation i want to run for 128x128x128 grids. I am using OpenFoam v6. Please suggest me what changes are required in constant and system folders to run this simulation? Test case of 32x32x32 have been performed.
ausm scheme, compressible flows, energy conserving, low-dissipative, rhoenergyfoam |
PEMFC model with FLUENT | brahimchoice | FLUENT | 22 | April 19, 2020 15:44 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
compressible flow calculation error using rhoSimpleFoam solver | student4326 | OpenFOAM Running, Solving & CFD | 7 | November 2, 2015 11:34 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Near compressible fluid - denstiy-based solver | Hooman | Main CFD Forum | 8 | December 19, 2011 03:03 |
