[waves2Foam] waveGaugesNProbes does not produce postprocessing data
Old   February 22, 2024, 05:26
Default waveGaugesNProbes does not produce postprocessing data
Marion Sant
edo2822 is on a distinguished road
Hey everyone,
I'm a newby in both OpenFoam and waves2foam.
I'm currently running waves2Foam tutorials to explore the functionalities.
I'm using the solitarywave tutorial which should already have everything needed to produce surface elevations value at every wave gaue every time interval of 0.025 seconds. However, when I run the ./Allrun script, which I modified by just adding
runApplication waveFoam
at the end.
I also tried to modify the system/controlDict file changin the last line from
#includeIfPresent "../waveGaugesNProbes/surfaceElevation_sets";
to
#includeIfPresent "../waveGaugesNProbes/surfaceElevation_controlDict";
However, all I get in the postProcessing folder, is a 0 folder. I would expect to have one folder for every writeInterval step.
What is wrong with my case?
I will upload both my complete case before running it and a case with the log.waveGaugesNProbes file after the .Allrun command, so that maybe you can understand better.
Thank you very much for your help!
File Type: zip log.waveGaugesNProbes.zip (716 Bytes, 0 views)
edo2822 is offline   Reply With Quote
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Postprocessing transient data AS_Aero STAR-CCM+ 6 September 14, 2017 02:33
[OpenFOAM] Paraview doesn't seem to be picking up data generated by icofoam MikeHersee ParaView 2 January 6, 2015 08:27
data postprocessing - need help astro1 Main CFD Forum 0 November 28, 2006 14:37
Postprocessing Pressure data spanwise over a wing Rick FLUENT 1 February 3, 2006 09:28
