September 12, 2017, 04:45 |
Postprocessing transient data
Rep Power: 14 |
Hi All
I am using Starccm+ transient analysis, I dint save before simulation any Solution Histories. So I am currently just saving each 1000 time step results like Case1@1e-2.sim, Case1@2e-2.sim etc like physical time. So I have the transient results like this and each case is 40GB so it takes time to load and hence I am looking for a suggestion how to post process these transient results. I also want the Instantaneous and averaged results and also animation of the contour plots. SO could someone suggest how to do it effectively and efficiently ? Thanks in advance. |
September 12, 2017, 07:33 |
It will take regardless of your approach. The problem is that commercial softwares usually save the data in ascii format and that will take time to load. If you can try to save them in binary. I always use python and Fortran for postpricessing. Both are quite effective !!!
September 12, 2017, 08:15 |
For animation of contour plot you should have saved the required scene using update feature with trigger point as few time steps.
September 13, 2017, 02:23 |
Rep Power: 12 |
Just from my experience:
The problem with auto-exporting images of your scenes is that you won't be able to change anything afterwards. I auto-export my transient data with .trn- surface files and postprocess them later on in Star again. Maybe not the most effect way but it's at least pretty flexible... |
September 13, 2017, 23:50 |
#5 | |
Lane Carasik
Rep Power: 14 |
For animations, your best bet is to export out images of your representative scenes at the desired time steps. Then use a software like blender to make the videos after the fact. Also, I recommend doing some basic testing first to make sure all of your post processing features work first. |
September 14, 2017, 02:30 |
transient simulation
Niaz
Rep Power: 8 |
i hAve don transient simulations for 3 minutes and i have set monitors ,can i get concentration versus time graph in post processing? thanks in advance for help
September 14, 2017, 02:33 |
Lane Carasik
Rep Power: 14 |
Only if you have setup the reports/monitors and associated plots before you ran the simulation. Or are using the simulation history files.
UDF for transient pressure outlet boundary from data array | nathanblank | FLUENT | 1 | June 1, 2015 03:09 |
Transient profile data | bongbang | CFX | 2 | February 14, 2015 15:03 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 04:46 |
Writing a transient data fileld | ant | CFX | 0 | October 20, 2002 12:19 |
