[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Like Tree6Likes
Old   February 19, 2009, 18:10
Default GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Hi!
Those who find funkySetFields useful might find this interesting: http://openfoamwiki.net/index.php/Contrib_groovyBC
Basically it is a mixed-boundary condition where value, gradient and valueFraction can be specified using expressions.
Bernhard
PS: Starting from now I will answer all questions concerning setParabolicInlet.C with "Use groovyBC". That was the main reason for writing that boundary condition: setParabolicInlet on steroids
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   February 20, 2009, 05:36
Default Bernhard, You're the man!
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Bernhard,
You're the man! Funky + pyFoam + Groovy is the trifecta of OpenFOAM! I officially nominate you for the 2009 OpenFOAM MVP award, which will be presented at the 2009 Workshop in Montreal by the AOFAS (Academy of OpenFOAM Arts and Sciences) ;-) Any ideas for a prize worthy of this award??
On a serious note: good job, and thanks for contributions!
Eric
egp is offline   Reply With Quote
Old   February 25, 2009, 10:35
Default Hi Bernhard I have tried
Alexandre Pereira
alexandrepereira is on a distinguished road
Hi Bernhard
I have tried groovyBC, nice tool... :-D
BTW I have checked your posting in SVN, and I have a question :
Supposing I want to calculate the total ammount of NO2 in a dieselEngineFoam simulation in each time slice of my simulation, how could i use the volumeFieldFunctionObject that you posted in the SVN repository...? I mean, that is what that library is for, tight...?!
Best regards
Alex
alexandrepereira is offline   Reply With Quote
Old   February 26, 2009, 10:31
Default Hi Alex! Did you have a loo
Assistant Moderator
Bernhard Gschaider
Hi Alex!
Did you have a look at the README there? It refers you to http://openfoamwiki.net/index.php/Co...unctionObjects (which is for my standards a quite exhaustive documentation)
Yes. Something like
NO2Total {
type volumeIntegrate;
functionObjectLibs
"libsimpleFunctionObjects.so"
verbose true;
fields (
NO2
should do that. BUT as you are propably aware NO2 is the Mass-fraction and integrating that is only meaningful if the density is constant (IMHO). So what you'd need is something like
fields (
NO2*rho
and that is currently not possible (it would mean marrying the funkySetFields-function parser with a function object - not that difficult, basically one would have to tell the parser "get the files from the database not the disk", but it still needs some time)
Bernhard
Old   February 26, 2009, 11:00
Default Hi Bernhard Thx for the hin
Alexandre Pereira
Hi Bernhard
Thx for the hint... :-)
BRGDS
Alex
Old   February 26, 2009, 11:47
Default Hi Again Bernhard, As long
Alexandre Pereira
Hi Again Bernhard,
As long as my ( tiny ) C++ knowledge does not allow for more, I will resort to a "crude" but effective solution :
For each time, write the volScalarField rho*[NO2] and after the simulation use the volumeIntegrate functionObject to query the FOAM database and understand if Mr Yakov Borisovich Zeldovich will allow me to design a low emission high compression ratio HCCI engine... !!
I think tha dieselEngineFoam is the right app to do this... since I will use a blend of DME and isoOctane, with high fraction of exhaust recycle gas and a very lean burn stoichiometry, I can assume tha most of my fuel droplets will be evaporated at time of ignition, leading to Homogeneous charge premixed flame combustion...
( This is what i think... )
Tyx anyway
BRGDS
Alex
Old   February 26, 2009, 13:28
Default Hi Alex! I was thinking to
Assistant Moderator
Bernhard Gschaider
Hi Alex!
I was thinking to complicated (funkyFieldsFunctionObject). Of course, if you're willing to to modify your solver then you don't even have to write to disk. Just create (outside the timeloop!) a field named "NO2mass" (not the variable name. The name in the IOobject-part is important). Update it at every timestep. If you add it to the fields list the function object will find it (praise to the objectRegistry and to its implementor)
Bernhard
Old   February 27, 2009, 10:12
Default Hi Bernhard I changed the s
Alexandre Pereira
Hi Bernhard
I changed the solver, and now i can access volumeIntegrated quantities.. nice piece of code your simpleFunctionObjects... :-)
Now for one more question , simpleFunctionObjects compiles trivially in Linux gcc, I ported it ( at least tried to ) to win32 using the cross compiler mingw32, so that ppl at mechanical engineering department in my university can use it in win simulations with OpenFOAM; You see. at my department ppl are very ..."conservative" meaning that they have the "Microsoft mindset" so... convincing them to shift to Linux is not an easy task...
Anyway, I tried to build the dll under mingw32 compiler, and it reports that HUGE, which is refered to in panicDump.C is not defined within that scope...
Since i do not know enough of the class hierarchy in OpenFOAM, which #include should i add to panicDump.H in order to the linker to find "HUGE"...? were is it defined... ?
mingw32 linker is not as "smart" as g++, i guess.. :-(
Thx for yr help :-)
Alex
Old   March 2, 2009, 05:50
Default Hi Bernhard! Question to Yo
Marco Müller
marico is on a distinguished road
Hi Bernhard!
Question to Your groovyBC: Can I create boundary conditions for dynamicFvMesh solver (e. g. displacementLaplacian) with this tool? Propably not, because a pointScalarField has to be defined?!...
Is there a way to do this?
How long do I have to wait until groovyBC is able to? ;)
Thanks a lot
Marco
marico is offline   Reply With Quote
Old   March 2, 2009, 07:24
Default @Alexandre: The problem is no
Assistant Moderator
Bernhard Gschaider
@Alexandre:
The problem is not the compiler. It is that from math.h the line
# define HUGE 3.40282347e+38F
seems to be missing for the mingw-headers. As a quick fix just insert this line into panicDump.H
@marco:
Way ahead of you. Last week I checked the groovyBCPointPatch-class into the svn. I just didn't announce it. There is also a small demo for that there (an addaption of the icoDyMFoam/movingCone). Just do a "svn update", recompile and you should be set
Old   March 2, 2009, 08:27
Default Hi Bernhard Thanks a lot :-
  #11
Alexandre Pereira
Hi Bernhard
Thanks a lot :-)
I will try this
BRGDS
Alexandre
Old   March 3, 2009, 03:29
Default Hi Bernhard, thanks a lot,
  #12
Marco Müller
Hi Bernhard,
thanks a lot, too. (Das müsste meiner Diplomarbeit ziemlich gut helfen... ;)
Marco
Old   March 3, 2009, 11:05
Default Hi Bernhard Thanks for your c
  #13
lin
Hua Zen
lin is on a distinguished road
Hi Bernhard
Thanks for your contribution.
I have a feature request and wonder whether it's possible.
It seems that both funkySetFields and GroovyBC are only for analytical expressions.I wonder whether these utilities could read in data from a file instead of expression.Then the user could use any programming language to generate more complicated fields for the initial and boundary conditions and then use these utilities to start running.
lin is offline   Reply With Quote
Old   March 3, 2009, 12:23
Default Hi Hua! For boundary condit
  #14
Assistant Moderator
Bernhard Gschaider
Hi Hua!
For boundary conditions the timeVaryingMappedFixedValue-condition might be just what you need (haven't used it myself; have a look at the board for that). For initial-conditions I don't see the point:
a) if you get the data from another program/solver foo then you'll have to write a data-convert for that format: fooToFoam (have a look maybe the converter is already there)
b) if you write a custom-built program, then you might as well write it in OpenFOAM-C++ because that situation boils down to case a)
So: no. There are currently no plans for that, unless the need for that arises in one of the projects I get paid for.
Bernhard
Old   March 3, 2009, 15:01
  #15
lin
Hua Zen
Hi Bernhard
Thanks for your reply and useful infomation.
Old   March 5, 2009, 07:24
Default Hi Bernhard, just tried com
  #16
Marco Müller
Hi Bernhard,
just tried compiling groovyBC, seems that there are (at least) two files missing:
could not open file PatchValueExpressionParser.tab.hh for source file groovyBCPointPatchFields.C
could not open file pointPatchFieldMapper.H for source file groovyBCPointPatchFields.C
Maybe you can help?
Thanks
Marco
Old   March 5, 2009, 08:27
Default Hi Marco! PatchValueExpress
  #17
Assistant Moderator
Bernhard Gschaider
Hi Marco!
PatchValueExpressionParser.tab.hh is generated from the yy-File and will live in the Make-directory.
According to groovyBCPointPatchFields.dep the other file should reside here: $(WM_PROJECT_DIR)/src/OpenFOAM/lnInclude/pointPatchFieldMapper.H
Which version are you using? I compiled and tested that BC with a vanilla-1.5. I quickly checked and it seems to me that this file is not present in the dev-version. Maybe it's called differently or resides somewhere else. Don't know (there seems to be a number of other stuff missing from the dev that is needed for the point-BC)
I think for the time being you'll have to remove groovyBCPointPatchFields.C from Make/files and live without the point variant.
Or you try to cheat: copy the files that compiler is missing from a vailla/git-version to the directory of the library and compile (the compiler should find them now). Repeat until the compiler runs out of complaints. But even if it compiles I can't guarantee that it will work.
Bernhard
Old   March 5, 2009, 08:57
Default Hi Bernhard, thanks for loo
  #18
Marco Müller
Hi Bernhard,
thanks for looking after it. I installed 1.5-dev (I read it would be better for dynamic mesh cases than the 1.5 binary because of bugs... ;)
So I placed the x.H and x.C files needed in my InInclude directory and it seems that compilation went well except of warnings:
PatchResult.C:88: warning: deleting 'void*' is undefined
lex.ve.c:363: warning: use of old-style cast
groovyBCPointPatchField.C: In function 'const Foam::fvPatch& Foam::getFvPatch(const Foam::pointPatch&)':
groovyBCPointPatchField.C:55: warning: control reaches end of non-void function
I'll try probably tomorrow if it works
Marco
Old   March 6, 2009, 04:21
Default Hi again, I just tried out
  #19
Marco Müller
Hi again,
I just tried out groovyBC and got the following error at the beginning of calculation:
could not load /home/../linuxGccDPOpt/libgroovyBC.so: undefined symbol: _ZN4Foam20mixedPointPatchFieldINS_6TensorIdEEE8typ eNameE
Best Regards,
Marco
Old   March 6, 2009, 04:30
Default OK. This means that more cheat
  #20
Assistant Moderator
Bernhard Gschaider
OK. This means that more cheating is necessary. Get mixedPointPatchFields.C (the s is important) and add it to Make/files. Don't know when this will stop. Sorry
Ship resistance shows wiggles when using Overset mesh and dynamic mesh in Fluent Qingsong FLUENT 2 March 21, 2022 15:08
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 04:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 22:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
