[PyFoam] install on CAE_linux 2008
Old   June 19, 2009, 10:17
Default install on CAE_linux 2008
Adrien_B is on a distinguished road
Hi everybody (it's my first post),
I am using CAElinux2008 distribution and I try to instal PyFoam for ploting the residual error on FoamX.
I have read the wiki (http://openfoamwiki.net/index.php/Co...lation_as_root) but didn't not find any solutions (I am begginer on Linux !!), the shell respond "unable to open /usr/lib/python2.4/config/Makefile (No such file or directory)".
How can I instal this library ?
Thank in advance
Adrien
Adrien_B is offline   Reply With Quote
Old   June 20, 2009, 20:34
Assistant Moderator
Bernhard Gschaider
It's a long time since I tested CAELinux so I'll have to do some guesses here.
Just checking: you are acting as root (not as the caelinux-user or how is the default user called in CAELinux)
Obviously the Makefile is looked for by the setup.py-utility is not present on this system. In theory it should be sufficient to move the stuff from the bin directory to some directory that is in the PATH and the PyFoam-directory to a place in the PYTHONPATH. For details on this see http://openfoamwiki.net/index.php/Co...a_regular_user
Bernhard
install fluent on Windows 2008 Sever echoliu99 FLUENT 0 July 19, 2016 09:59
error make SU2 4.0.1 Heathckliff SU2 Installation 2 November 9, 2015 05:48
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 17:33
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
install FLUENT on mandriva 2008 santosh Main CFD Forum 3 January 14, 2009 12:45
