[swak4Foam] funkySetFields
Old   June 7, 2010, 06:07
Default funkySetFields
Chrisi1984 is on a distinguished road
I discovered the lib funkySetFields to define nonconformal initial conditions.
I would like to know, if it is possible to set for one zone of the mesh a initial condition with fixed value (k=0) with funkySetFields.
Therby I want to define a porous zone as a laminar zone.
If you have an other idea to define a laminar zone without using mutliRegion, I would be glad about.
Best regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   June 7, 2010, 07:16
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by Chrisi1984 View Post
Best regards
Chrisi
Have a look at the end of section 4 of http://openfoamwiki.net/index.php/Co...funkySetFields . Use the function described there in the -contition-option and you should be set (BTW: k=0 is not a good idea in my opinion. You'll get a divison by zero)
Bernhard
gschaider is offline   Reply With Quote
Old   June 7, 2010, 08:13
Thank you,
I understood right, it is possible to define fixed values as initial conditon, but k=0 is bad?
Would mut=0 be a better definition?
Regards
Chrisi
Old   June 9, 2010, 04:31
Assistant Moderator
Bernhard Gschaider
Thank you,
No. k will only be set as an initial condition. It will be calculated in later time-steps.
k=0 anywhere usually results in a divisionByZero-error (try it).
No. That is calculated from other values.
Old   June 9, 2010, 05:22
Stefan Herbert
herbert is on a distinguished road
Hi Chrisi,
if you only want your porous zones to be treated as laminar, I would suggest to use mut=0 is this region. Because can't be done directly, I'd suggest the following workaround.
Just replace your UEqn
tmp<fvVectorMatrix> UEqn
    fvm::div(phi, U)
  - fvm::Sp(fvc::div(phi), U)
  + turbulence->divDevRhoReff(U)
by
volScalarField muEff = turbulence->muEff();
volScalarField muLam = turbulence->mu();
forAll(mesh.cellZones(), iZone)
    //if this is a porousZone
    forAll(mesh.cellZones()[iZone], iCell)
        label actualCell = mesh.cellZones()[iZone][iCell];
        //replace effective viscosity by the molecular one
        muEff[actualCell] = muLam[actualCell];
    fvm::div(phi, U)
  - fvm::laplacian(muEff, U) - fvc::div(muEff*dev2(fvc::grad(U)().T()))
Please tell me, if it works.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   June 11, 2010, 03:18
Thank you for your suggestion.
I tried solving with this, but I did not get a laminar zone.
Perhabs I have to define somewhere in the code you gave me the name of my porous zone, haven't I?
I tried solving with exactly your posted code.
Or should I personalize your code in a different way for my case?
Thanks in advance!
Regards Chrisi
Old   June 11, 2010, 03:58
Stefan Herbert
Hi Chrisi,
yes indeed, you might add some code at
//if this is a porous zone
My code actually goes through all cells included in any cell Zone and replaces the effective viscosity by the molecular (laminar) one. If there is a cell Zones that isn't a porous zone you have to exlude it from the loop via in if statement (e.g. by its name).
One more thing I have forgotten: You will have to do the same thing for alphaEff used in hEqn, because the changes in mut are not reported back to the turbulence model and therefore won't effect calculation of alphaEff from mut.
BTW: Maybe there is still a more elegant way to solve your problem. Keep on trying...
Regards,
Stefan
Old   June 11, 2010, 08:08
Hi Herbert,
thanks for your efforts.
But I 'm sorry I dont know how to put in this if statement. Because I have only one porous zone inside my mesh, it would be easier not to exclude all other zones I think.
How can I make an if statement to call different cell zones.
Can you translate your code for me?
That would be so nice of you.
Regards
Chrisi
Old   June 14, 2010, 04:30
Stefan Herbert
Hi Chrisi,
I thought about something like this:
forAll(mesh.cellZones(), iZone) //loop over all cellZones
     if (mesh.cellZones()[iZone].name() == "bla") //with bla being name of porous cellZone
         forAll(mesh.cellZones()[iZone], iCell) //loop over all cells in Zone
               label actualCell = mesh.cellZones()[iZone][iCell]; //"global" cell index of actual cell
               //replace effective viscosity by the molecular (laminar) one
BTW: What do you mean talking about "laminar"? If you want the flow to have a certain direction (e.g. in x-direction) you can influence by the loss coefficients. Just set the coefficients in the directions you want to have zero velocity to -1000. Then it should be 1000 times higher than in the specified flow direction. In this case you won't have to manipulate code.
Regards,
Stefan
Old   June 15, 2010, 02:21
thank you again.
At the moment your suggestions did not change really much, but it can be right anyhow.
So now why what I want to do: I want to find an equivalent for the laminar zone for porous regions like in Fluent. That there are no turbulent swirls in my porous zone.
I must check with an other case, if your code allow exactly this.
Best regards
Chrisi
Old   June 17, 2010, 03:26
Is it possible to call setFields during the calculation to overwirte mut only in my porous zone with zero in every time step?
Regards
Chrisi
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 09:01
[swak4Foam] how to use funkySetFields function in muliregion case bryant_k OpenFOAM Community Contributions 15 October 15, 2021 02:50
[swak4Foam] funkySetFields and funkySetBoundaryFields zxj160 OpenFOAM Community Contributions 19 February 14, 2018 19:07
[swak4Foam] funkySetFields: problem with processor boundary nmikhailov OpenFOAM Community Contributions 4 May 26, 2015 09:48
[swak4Foam] Problem with funkySetFields: How to set field on patch? DanielPT OpenFOAM Community Contributions 4 May 6, 2011 09:45
