February 14, 2011, 19:59 |
Swirl input using groovyBC
Hello Foamers,
I am trying to implement swirl input in a cylindrical tube (axis along z dir). I came across the groovyBC code to implement swirl input: inlet { type groovyBC; variables "rpm=8000.0;Un=55.8;c=sum(pos()*mag(Sf()))/sum(mag(Sf()));n=sum(normal())/mag(sum(normal()));p=pos()-c;r=mag(p)+1.0e-10;R=max(r); xt=vector(0,n.z,-n.y);xT=xt/mag(xt);yt=vector(n.y*n.y+n.z*n.z,-n.x*n.y,-n.x*n.z);yT=yt/mag(yt);"; valueExpression "-Un*normal() + (rpm*pi/30)*((p & yT)*xT - (p & xT)*yT)"; } Can someone explain what xt, yt, and (p & yT)*xT - (p & xT)*yT refer to? Thanks so much, Regards, gk Last edited by usergk; February 15, 2011 at 20:31. |
February 15, 2011, 12:43 |
Can anyone provide some hints here? Many thanks, gk Last edited by usergk; February 15, 2011 at 20:32. |
February 16, 2011, 03:08 |
Bernhard
Rep Power: 21 |
They are defined in variables. If you don't understand the formulation, make a sketch, using the known vectors (pos and normal), in a random orientation. In your sketch you will understand each term immediately. (With the assumption that this is a correct implementation of course )
February 16, 2011, 03:16 |
#4 | |
L.Tuominen
I have used following code: Code:
type groovyBC; variables ( "yp=pos().y;" "xp=pos().x;" "r=sqrt(pow(xp,2)+pow(yp,2));" "U_ax=31.35;" "U_t=20.97;" "theta=asin(xp/r);" "U_tx=sqrt(pow(U_t*cos(theta),2));" "U_ty=-U_t*sin(theta);" ); valueExpression "vector ( U_tx, U_ty, U_ax )"; Lasse |
February 16, 2011, 11:43 |
Thanks a lot for the inputs! Really appreciate it!
I was able to get it running using Lasse's code. gk |
July 25, 2013, 08:02 |
Federica Farisco
I used funkySetBoundary in openfoam 1.7 to generate a swirl in the inlet patch for a sector of a cylinder and it works. I have attached below the file funkySetBoundaryDict used. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // velocityswirl { field U; expressions ( { target value; patchName inlet; variables "rpm=1000.0;Un=10;c=sum(pos()*mag(Sf()))/sum(mag(Sf()));n=sum(normal())/mag(sum(normal()));n=sum(normal())/mag(sum(normal()));p=pos()-c;r=mag(pos()-vector(0,0,1))+1.0e-10;R=max(r);xt=vector(0,n.z,-n.y);xT=xt/mag(xt);yt=vector(n.y*n.y+n.z*n.z,-n.x*n.y,-n.x*n.z);yT=yt/mag(yt);"; expression "-Un*normal() + (rpm*pi/30)*(((pos()-c) & yT)*xT-((pos()-c) & xT)*yT)"; } ); } //!!! in "variables" do not leave any space between the definitions of two variables and in "espression" try to replace the name of few variables with their definitions !!! //!!! c=sum(pos()*mag(Sf()))/sum(mag(Sf())) works just for full patches; for other cases you have to set manually !!! |
January 29, 2018, 01:58 |
#7 | |
Kadu
Rep Power: 10 |
For complete (360 degree) cylinder- inlet { type groovyBC; variables ( "yp2=pos().y;" "zp2=pos().z;" "r2=sqrt(pow(zp2,2)+pow(yp2,2));" "U_ax2=0.5496*pow((1-mag(r2-0.0095)/(1.001*0.0035)),(1/7));" "U_t=0.15*(1-pow((mag(r2-0.0095)/(1.001*0.0035)),2));" "U_tz=-U_t*yp2/r2;" "U_ty=U_t*zp2/r2;" ); valueExpression "vector ( U_ax2, U_ty, U_tz )"; value uniform (0 0 0); } The 'value' might need to be added since without it some warning will be appeared. According to my understanding 'value' will be used only for first time-step. |
Quantifying the swirl in CFX, Swirl Number/Swirl Angle | tauqirnawaz | CFX | 23 | July 24, 2016 22:28 |
[swak4Foam] GroovyBC with power input (heat flux) | Tobi | OpenFOAM Community Contributions | 10 | January 12, 2016 10:04 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
Swirl in Pressure Swirl Atomizer | varunrajendra | FLUENT | 0 | August 19, 2009 12:09 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 10:54 |
