[ddtExtended] Extended objectFunction for postProcess application
Like Tree1Likes
  • 1 Post By Tobi
Old   November 5, 2017, 13:52
Default Extended objectFunction for postProcess application
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Dear all,
my contribution of the new time derivative object function is new implemented in the OpenFOAM Foundation toolbox. Information about the discussion can be found here:
As one can see, the implementation to the postProcess tool was not done based on the inconsistency of the time derivative (information are missing). However, I already build the extension which I host on my personal repository. However, keep in mind that you will overwrite one core file of FOAM (GeometricFields class).
The additional feature for the postProcess allows one to analyze the field change during the saved time steps:
  • for steady state analyzes it can be used to check out steady-state behavior (the derivation between the time folders should be neglect able)
  • or postProcess some field change but with no consistency to the real physics.
The library can be found here:
Have fun,
However, the additional implementation into the postProcess
makaveli_lcf likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   January 20, 2018, 16:11
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi Tobi! Thanks for your work!
I check repository main branch and I do not see source code in the main branch. Is it only avaiable at the OF-5.0 branch?
Cheers, Alex
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   January 21, 2018, 14:25
Tobi's Avatar
Tobias Holzmann
Hi Alex, thanks for your Feedback. Yes, it is only for 5.0 / dev. If there is no other branch, than I did not add it.
Keep foaming,
Tobias Holzmann
Error in compute process - No Active Application yetlyg FLUENT 8 October 27, 2018 22:30
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 11:52
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Extended version: Dynamic mesh fusij OpenFOAM 2 February 18, 2011 02:12
[GAMBIT] flow over extended surfaces in a channel (2D) abhishek_singh ANSYS Meshing & Geometry 0 November 9, 2010 18:09
