March 4, 2011, 15:40 |
Installing Discretizer
John Damnson
I'm trying to use Discretizer with OpenFOAM 1.7.x on a Macbook Air with OS 10.6.6. booted in 32bit mode. I followed the installation method they gave (unpacking the discretizer-32bit.tar.gz, going in to the unpacked directory, commanding ./discretizer_setup.sh) but the command returns the following error Slave:discretizer Savindu$ ./discretizer_setup.sh readlink: illegal option -- f usage: readlink [-n] [file ...] ./discretizer_setup.sh: line 23: ./ruby/1.9.1-p243/bin/ruby: No such file or directory Contrary to the error message, there IS such a file named "ruby" and when I run it by double clicking it, an error message says that it can't execute the binary file. why is this??? Can anyone give a "for Dummies" kind of step-by-step method to install Discretizer? THANK YOU! |
March 5, 2011, 09:50 |
are sure that discretizer runs on a mac out of the box? From the download page http://www.discretizer.org/node/2 you will see existing binaries for Linux and Windows, but no Mac! elvis |
March 6, 2011, 11:53 |
Yes it works. Discretizer on Mac OS Snow Leopard
John Damnson
first u need to install FXRuby (many ways. Google it)
Download the discretizer-32bit.tar.gz for Linux etc and extract the files Then probably install the OpenGL extensions (gem install ruby-opengl) "cd" into discretizer/discretizer/svn/discretizersetup in the extracted directory type "ruby discretizersetup.rb" The beautiful GUI of Discretizer will appear! Savindu Hewa |
May 24, 2011, 02:45 |
Where to get Discretizer :: setup??
Manoj L Das
Greetings!!! Can any body tell me where to get Discretizer :: setup ? I installed discretizer on RHEL5 but there I couldnot found anything for import mesh and for Boundary conditions and OF case setup. I guess Discretizer :: setup could do it, but where is that actually??? Regards, MLD |
May 24, 2011, 15:57 |
John Damnson
Hey, my last post is a little wrong. you shouldn't cd into the directory where discretizersetup.rb is located. go into the directory where discretizer.rb is located and type "ruby discretizer.rb". In the GUI that opens, you'll be able to import stuff.
May 25, 2011, 06:05 |
Manoj L Das
yes you are right. Now I got the discretizer-setup. Is indeed very helpful in setting up a case in OF. Thanks for your help.
But when using that I was little confused on setting porous region. Infact when I selected the solver rhoPorousSimpleFoam, the porous Zones were activated, But I was not able to assign a porosity of 0.6 in all the internal cell zones. Also, The porouszones menu under the solver shows "NoPorous zones". Can you tell me how to set a porous zone on all the inernal cell zones. I had gone through a document named "PorousMedia in OpenFoam", but I could not understaned the concept of local coordinate system e1, e2 and e3, how to use it to difine porous zone. Thanks for your help on this in advance. MLD |
June 7, 2013, 06:41 |
I can't install Discretizer on Ubuntu 12.10
Steven
PRE { direction: ltr; color: rgb(0, 0, 0); }PRE.western { }PRE.cjk { }PRE.ctl { }P { margin-bottom: 0.21cm; direction: ltr; color: rgb(0, 0, 0); }P.western { font-family: "Liberation Serif","Times New Roman",serif; font-size: 12pt; }P.cjk { font-family: "DejaVu Sans"; font-size: 12pt; }P.ctl { font-family: "Lohit Hindi"; font-size: 12pt; } Hello everybody !
I am a new user of Ubuntu 12.10, and I would like to use the software OpenFOAM to do some aerodynamics studies for my final engineering internship. To do it well, I want to use the mesh software Discretizer, but I don't manage to install it... Could someone help me and give me the real steps of installation for Ubuntu 12.10 ? Here are the installation steps I found on DIscretizer website: #!/bin/sh # install required libs sudo apt-get install g++ libxrandr-dev libgemplugin-ruby rubygems libopengl-ruby ruby1.8-dev libfox-1.6-0 libfox-1.6-dev libfox-1.6-doc libfxscintilla17 libfxscintilla-dev subversion subversion-tools # download FXRuby gem wget http://rubyforge.org/frs/download.ph...uby-1.6.16.gem # install FXRuby sudo gem install fxruby-1.6.16.gem # checkout discretizer from sourceforge svn svn co https://discretizer.svn.sourceforge....ot/discretizer discretizer # run discretizer cd discretizer/discretizer ruby discretizer.rb But I meet a lot of error messages and I don't understand the meaning of them... admin01@ubuntu:~$ sudo apt-get install g++ libxrandr-dev libgemplugin-ruby rubygems libopengl-ruby ruby1.8-dev libfox-1.6-0 libfox-1.6-dev libfox-1.6-doc libfxscintilla17 libfxscintilla-dev subversion subversion-tools [sudo] password for admin01: Lecture des listes de paquets... Fait Construction de l'arbre des dépendances Lecture des informations d'état... Fait E: Impossible de trouver le paquet libfxscintilla17 (….) admin01@ubuntu:~$ sudo gem install fxruby-1.6.14.gem Building native extensions. This could take a while... ERROR: Error installing fxruby-1.6.14.gem: ERROR: Failed to build gem native extension. /usr/bin/ruby1.9.1 extconf.rb /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require': cannot load such file -- ftools (LoadError) from /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require' from extconf.rb:3:in `<main>' Gem files will remain installed in /var/lib/gems/1.9.1/gems/fxruby-1.6.14 for inspection. Results logged to /var/lib/gems/1.9.1/gems/fxruby-1.6.14/ext/fox16/gem_make.out admin01@ubuntu:~$ svn co https://discretizer.svn.sourceforge....ot/discretizer discretizer Révision 129 extraite. admin01@ubuntu:~$ cd discretizer/discretizer admin01@ubuntu:~/discretizer/discretizer$ ruby discretizer.rb ruby: No such file or directory -- discretizer.rb (LoadError) admin01@ubuntu:~/discretizer/discretizer$ I know that the last problem is due to a wrong localisation of the file "discretizer.rb" but I really don't know what I have to type to find it and to be able to use Discretizer. You can't imagine how important it is for me to use it in order to validate this internship. I am looking forward to reading your answers ! Airmax |
June 16, 2013, 14:09 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all! @Airmax: Welcome to the forum!
I'm not sure if Discretizer will be the right tool for you, but here goes just the same. The following instructions have been tested in Ubuntu 12.04 x86_64:
This was rather complicated to figure out... fortunately Ubuntu and Ruby have a lot of things that make it a lot easier... Best regards, Bruno
Last edited by wyldckat; October 26, 2013 at 12:49. Reason: Fixed the attached file, because the second script did not have exec permissions - fixed SVN command |
June 17, 2013, 03:34 |
Steven
Hi Bruno,
First of all; thank you for your help. I tried the different stpes you gave me but I stil have a problem with the 6th step (installation of fxruby...) and I can't finish well to install Discretizer... Here are the error messages I have in the tereminal: P { margin-bottom: 0.21cm; } admin01@ubuntu:~/OpenFOAM/discretizer$ sudo gem install fxruby Fetching: fxruby-1.6.27.gem (100%) Building native extensions. This could take a while... ERROR: Error installing fxruby: ERROR: Failed to build gem native extension. /usr/bin/ruby1.9.1 extconf.rb checking for sys/time.h... yes checking for signal.h... yes checking for deflate() in -lz... yes checking for png_create_read_struct() in -lpng... yes checking for jpeg_mem_init() in -ljpeg... yes checking for TIFFSetErrorHandler() in -ltiff... yes checking for XftInit() in -lXft... yes checking for XShmQueryVersion() in -lXext... yes checking for XFindContext() in -lX11... yes checking for glXCreateContext() in -lGL... yes checking for gluNewQuadric() in -lGLU... yes creating Makefile make compiling librb.c librb.c: In function ‘SWIG_Ruby_define_class’: librb.c:487:11: attention : variable ‘klass’ set but not used [-Wunused-but-set-variable] compiling menu_wrap.cpp menu_wrap.cpp: In function ‘void SWIG_exception_(int, const char*)’: menu_wrap.cpp:578:41: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:581:38: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:584:43: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:587:41: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:590:40: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:593:43: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:596:41: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:599:42: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:602:39: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:605:36: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp:608:43: erreur: le format n'est pas une chaîne littérale et pas d'argument de format [-Werror=format-security] menu_wrap.cpp: At global scope: menu_wrap.cpp:553:13: attention : ‘void SWIG_AsVal(VALUE, int*)’ defined but not used [-Wunused-function] In file included from ./include/FXRuby.h:878:0, from ./include/FXRbCommon.h:99, from menu_wrap.cpp:559: ./include/inlinestubs.h:20:1: attention : ‘void FXApp_init(FX::FXApp*, VALUE, bool)’ defined but not used [-Wunused-function] menu_wrap.cpp:790:1: attention : ‘void free_FXMenuPane(FX::FXMenuPane*)’ defined but not used [-Wunused-function] menu_wrap.cpp:1019:1: attention : ‘void free_FXScrollPane(FX::FXScrollPane*)’ defined but not used [-Wunused-function] menu_wrap.cpp:1412:1: attention : ‘void free_FXMenuCaption(FX::FXMenuCaption*)’ defined but not used [-Wunused-function] menu_wrap.cpp:1631:1: attention : ‘void free_FXMenuSeparator(FX::FXMenuSeparator*)’ defined but not used [-Wunused-function] menu_wrap.cpp:1937:1: attention : ‘void free_FXMenuTitle(FX::FXMenuTitle*)’ defined but not used [-Wunused-function] menu_wrap.cpp:2210:1: attention : ‘void free_FXMenuCascade(FX::FXMenuCascade*)’ defined but not used [-Wunused-function] menu_wrap.cpp:2478:1: attention : ‘void free_FXMenuCommand(FX::FXMenuCommand*)’ defined but not used [-Wunused-function] menu_wrap.cpp:2799:1: attention : ‘void free_FXMenuBar(FX::FXMenuBar*)’ defined but not used [-Wunused-function] menu_wrap.cpp:3131:1: attention : ‘void free_FXMenuCheck(FX::FXMenuCheck*)’ defined but not used [-Wunused-function] menu_wrap.cpp:3432:1: attention : ‘void free_FXMenuRadio(FX::FXMenuRadio*)’ defined but not used [-Wunused-function] cc1plus: some warnings being treated as errors make: *** [menu_wrap.o] Erreur 1 Gem files will remain installed in /usr/lib/ruby/gems/1.9.1/gems/fxruby-1.6.27 for inspection. Results logged to /usr/lib/ruby/gems/1.9.1/gems/fxruby-1.6.27/ext/fox16_c/gem_make.out And then, at the last step I have: admin01@ubuntu:~/OpenFOAM/discretizer/lib$ ruby discretizer.rb /usr/local/lib/site_ruby/1.9.1/rubygems/custom_require.rb:36:in `require': cannot load such file -- fox16 (LoadError) from /usr/local/lib/site_ruby/1.9.1/rubygems/custom_require.rb:36:in `require' from discretizer.rb:38:in `<main>' What is it due to? Can someone help me to solve this problem? Thank you in advance. Best regards, Maxence |
June 17, 2013, 18:40 |
Bruno Santos
Rep Power: 128 |
Hi Airmax,
I've tried the instructions on Ubuntu 12.10 x86_64 inside a virtual machine. I tried using both ruby 1.8 and 1.9 and I was not able to make it work It's not possible to build fxruby due to some problem with the compiler or dependency on certain libraries, which I'm not able to figure out. Right now, there are only a couple suggestions I'm able to do:
Bruno
July 12, 2013, 12:57 |
#11 | |
Basta
Rep Power: 12 |
All is OK with your method but i have only one problem that after step 9 when i enter ./discretizer.sh the program start but when i type ./discretizersetup.sh the program doesn't start. DO You have any solution? |
July 12, 2013, 17:37 |
#12 |
Bruno Santos
Rep Power: 128 |
Greetings mina.basta and welcome to the forum!
Sorry about that, I forgot to give executable permissions to the script "discretizersetup.sh" I've corrected the attached file in the post #8. You can also fix the problem by running the following command: Code:
chmod +x discretizersetup.sh Code:
./discretizersetup.sh Bruno
July 14, 2013, 05:38 |
#13 |
Basta
Rep Power: 12 |
Thank you Wyldckat, it's a pleasure for me to join your forum and thanks for the quick response & for your help. It works very good
September 13, 2013, 10:08 |
Thank you Bruno for the guidance
#14 |
Anil Kunwar
Rep Power: 11 |
dear Bruno,
you have been guiding the beginners like us in the context of OpenFOAM and related softwares. the step by step method you have provided herein is very useful for people willing to use discretizer software. in one of the pages, you have taught us to use alias command in bash file when using OpenFOAM (of different versions together) and SALOME software. your way of explaining the things is very lucid and nice. thank you Yours Annier |
October 26, 2013, 18:20 |
#15 | |
Massachusetts
Rep Power: 12 |
Bruno
I am struggling with steps 8 and 9 of the installation. Screen shots attached are a result of the 4 commands. In addition to no images in the GUI, I am unable to import .stl files - discretizer shuts down when I attempt. I appreciate your help with this problem. Take care, Ben Quote:
October 26, 2013, 18:51 |
#16 |
Bruno Santos
Rep Power: 128 |
Hi Ben,
I think that there is something very strange is going on with your installation of OpenFOAM and which is affecting Discretizer. I say this because of all of those messages you are getting about "mpicc". How exactly did you install OpenFOAM and did you install more than one version of OpenFOAM? And are you certain that you are using Ubuntu 12.04? Best regards, Bruno
October 26, 2013, 18:58 |
#17 |
Massachusetts
Rep Power: 12 |
Bruno,
I am sure that I have Ubuntu 12.04 -LTS http://www.ubuntu.com/download/desktop If you are *pretty* sure that its an installation error I wouldnt be surprised - its been a learning experience with quite a few iterations - delete -> reinstall, ect. Should I delete ubuntu partitions and start from scratch? Thanks Ben |
October 26, 2013, 19:00 |
#18 |
Bruno Santos
Rep Power: 128 |
Hi Ben,
If you can, perhaps it's the best. Specially if you don't remember every step you've tried. Best regards, Bruno
October 26, 2013, 19:13 |
#19 |
Massachusetts
Rep Power: 12 |
Bruno
Do you see any compatibility problems with these installation guides? Ubuntu: http://www.ubuntu.com/download/deskt...g-term-support OpenFOAM (for Ubuntu 12.04 - 3rd entry) http://openfoamwiki.net/index.php/In...M-2.1.1/Ubuntu Thanks Ben |
October 26, 2013, 19:40 |
#20 |
Bruno Santos
Rep Power: 128 |
Hi Ben,
No, there isn't any incompatibility there. All I can think of is that some packages might have been removed when they shouldn't have. You can try redoing step #1 from the instructions for building OpenFOAM 2.1.1 from source code: http://openfoamwiki.net/index.php/In...u#Ubuntu_12.04 Best regards, Bruno
discretizer, installation, meshing, openfoam, snow leopard |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Install OF 1.6.ext on Arch based distribution | miro2000 | OpenFOAM Installation | 4 | October 9, 2013 14:39 |
Runing cavity on Discretizer | RTom | OpenFOAM Pre-Processing | 3 | June 25, 2013 01:11 |
[Discretizer] Discretizer | Rajshekar | OpenFOAM Community Contributions | 2 | November 23, 2010 11:13 |
