[swak4Foam] install in OF 2.1 error
Old   July 24, 2013, 15:14
Default install in OF 2.1 error
psk
david
psk is an unknown quantity at this point
Good Day Folks,
I try to install swak4Foam in Openfoam 2.1, I follow these steps
Step 1: [ svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ ], copy & paste in terminal window
step 2: [ hg clone http://hg.code.sf.net/p/openfoam-extend/swak4Foam ] copy & paste in terminal window
upto this step it works
step 3: [ hg update port_2.0.x ] copy & paste in terminal, I got error like this,
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ hg update port_2.0.x
abort: no repository found in '/home/toshiba/OpenFOAM/toshiba-2.1.0/swak4Foam' (.hg not found)!
kindly let me the step 3 is necessary? just I tried.
step4: ./Allwmake --->copy & paste in terminal window, I got error like,
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/swak4Foam$ ./Allwmake
No 'swakConfiguration'. Python etc won't work
Checking swak4Foam-version and generating file
Swak version is 0.2.4
No 'bison' found. This is absolutely essential for swak4Foam. Can't go on
Requirements for Library not satisfied. I see no sense in going on
Kindly help me
Million Thanks,
David
"Small Dream is a Crime"
psk is offline   Reply With Quote
Old   July 24, 2013, 17:13
Assistant Moderator
Bernhard Gschaider
Originally Posted by psk View Post
Good Day Folks,
Kindly help me
If it is your plan to get more answers by posting the same question every two hours in a different thread (http://www.cfd-online.com/Forums/ope...l#post441746):) won't work. Usually this annoys the people who already answered your question and they will stop answering altogether
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 25, 2013, 00:18
psk
david
Thanks for suggestion gschaider, finally I did, Now it works fine
I understand the problem, but you are telling , you didn't use Ubuntu, that the reason I start new thread, kindly let know any simple trick, to get more help without making annoying our OF folks.I am new to OF.
And also let me know which one are you using for OF.
Million Thanks,
David
Old   July 25, 2013, 05:13
Assistant Moderator
Bernhard Gschaider
Then you should have updated the question with the new information you've got. Something like "Have Ubuntu. How to install bison?" That way people don't have to start from scratch.
Concerning the installation of bison: http://bit.ly/144S7Pf The second link (http://en.kioskea.net/faq/30635-how-...n-under-ubuntu) looks nice (and there is a number of other links that looks promising)
Old   July 25, 2013, 11:48
psk
david
Good Day, Thanks for your reply & information gschaider,
I already did that one, kindly see this link (http://www.cfd-online.com/Forums/ope...tml#post441825 )
Also Kindly let me know, how to convert matlab m file to python? I go through this link:[ http://ompclib.appspot.com/m2py ], while running the converted python script it shows lot of error, I am new to python. If you have any idea share me.
Million Thanks,
David
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
