[swak4Foam] using groovyBC toPoints?
Like Tree2Likes
  • 2 Post By gschaider
Old   April 4, 2012, 06:23
Default using groovyBC toPoints?
fisch
fisch is on a distinguished road
i read that i can use the groovyBC in meshmotion simulations, too.
I try inside the pointDisplacement file the following:
bottom
type groovyBC;
value uniform (0 0 0);
valueExpression "vector(0,toPoint(0.05*(sin(pi*time()))),0)";
but i get the following error:
--> FOAM FATAL ERROR:
Parser Error at "1.10-16" :"syntax error, unexpected TOKEN_toPoint"
From function parsingValue
in file lnInclude/CommonValueExpressionDriverI.H at line 724.
FOAM exiting
Is it necessary to include there something or did i a mistake???
thanks in advance,
rupert
fisch is offline   Reply With Quote
Old   April 4, 2012, 07:36
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
bottom
type groovyBC;
FOAM exiting
thanks in advance,
rupert
OK. Two problems here:
a) to construct a pointVectorField it must be "vector(toPoint(0),toPoint(0.05*(sin(pi*time()))), toPoint(0))"
b) it seems that the construction of a pointVectorField is in the grammar for Fields (== funkySetFields) but not in Patches (==groovyBC)
If a bug-report shows up on the OF-extend-Mantis I will take care of point b. Point a you'll have to take care of yourself
gschaider is offline   Reply With Quote
Old   April 4, 2012, 08:17
fisch
point a i already tried, but it seems that he's not able to get the function toPoint.
I tried to post it in the bugtracker; did i do it the right way?
thanks a lot,
rupert
Old   April 10, 2012, 04:34
fisch
If anybody is interested, the problem is solved. See:
https://sourceforge.net/apps/mantisb...iew.php?id=130
Old   April 10, 2012, 05:14
fisch
now it's running without error messages but the result is not the desired one.
The code only moves the points on the mesh boundary and not the mesh (using the specified meshMotion solver) himself.
What I tried to get is a result like using the BC oscillatingDisplacement...
can you help me?
Old   April 10, 2012, 05:44
Assistant Moderator
Bernhard Gschaider
can you help me?
Have you set up the cellDisplacement-field to be consistent to be consistent with the point displacement? (have a look at the movingCone-example in the swak ... as far as I remember it is done just by using toFace( ... ) )
nimasam and chathuranga like this.
Old   April 10, 2012, 07:13
fisch
you were right; My mistake..
regarding the compiler flag: __linux__ solved the problem with icc
Old   March 5, 2015, 10:57
Tobi's Avatar
Tobias Holzmann
just one question... it the output of the face to point interpolation always there or could we suppress it?
Thanks in advance,
Keep foaming,
Tobias Holzmann
Old   January 6, 2016, 17:50
Gautami Erukulla
gautami is on a distinguished road
P { margin-bottom: 0.08in; } Hello Everybody,
I am trying to simulate a numerical wave tank using interDyMFoam solver on OpenFOAM version 2.2.0 (SuSE Linux 12.2). The idea is to generate waves by a piston wave maker, using groovy boundary condition at the inlet of the wave tank.
The dynamic mesh option is specified as:
  1. In the file “dynamicMeshDict” in “constant folder”
solver displacementLaplacian;
displacementLaplacianCoeffs
diffusivity uniform;
The groovyBC at the inlet is implemented as:
  1. In the file “pointDisplacement” under the folder “0”
    inlet
    type groovyBC;
    valueExpression "vector(toPoint(cos(-time())),toPoint(0),toPoint(0))";
  2. In the file “cellDisplacement” under the folder “0”
inlet
type groovyBC;
valueExpression "toFace(pointDisplacement)";
4. In the file “U” under the folder “0”
inlet
type groovyBC;
value uniform (1 0 0);
The solver for the cellDisplacement in the “fvSolution” file is GAMG.
When I run the case using interDyMFOAM, I do not get any syntax errors, but the run blows up for the very first time step.
In the log file it shows:
Interface Courant Number mean: 0 max: 0
Courant Number mean: 0.00934266978331 max: 0.165086855307
deltaT = 0.00111111111111
Time = 0.00111111
swak4Foam: Allocating new repository for sampledGlobalVariables
GAMG: Solving for cellDisplacementx, Initial residual = 1, Final residual = 9.36444116038e-06, No Iterations 8
GAMG: Solving for cellDisplacementz, Initial residual = 0, Final residual = 0, No Iterations 0
Execution time for mesh.update() = 0.08 s
time step continuity errors : sum local = 4.46786639335e-10, global = -2.72113359451e-11, cumulative = -0.000200000046943
GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 4.75866102817e-06, No Iterations 7
time step continuity errors : sum local = 0.245271051403, global = 0.243261713162, cumulative = 0.243061713115
When solving for alpha:
MULES: Solving for alpha1
Phase-1 volume fraction = -5.36408246329e+291 Min(alpha1) = -4.12021901801e+295 Max(alpha1) = 2.42152309773
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.
The alpha values go out of bounds.
I would like to mention here that if I run the same simulation with the following options, the code runs smoothly and the results seem to be good:
dynamic mesh option:
solver velocityComponentLaplacian;
velocityComponentLaplacianCoeffs
component x;
diffusivity inverseDistance (inlet);
And the groovyBC at the inlet is specified using:
PointMotionUx
cellMotionUx
Kindly can somebody please guide me, how to resolve this issue. The reason I am trying to implement the groovyBC using pointDisplacement to pointMotion is, I would like to add a floating box in the middle of the wave tank with “sixDoFRigidBodyDisplacement” and provide it a “linearSpring” restraint. I am assuming that this can be done only in pointDisplacement. Please do let me know if I am wrong and any ideas and suggestions would be highly invaluable.Thank you.
Most&More,
Gautami Erukulla.
gautami is offline   Reply With Quote
Old   January 7, 2016, 13:32
Gautami Erukulla
Dear All,
It was an oversight at my end.
If anyone is interested the "U" file in "0" folder should be declared as:
inlet
type movingWallVelocity;
Now it works fine.Thank you.
Most&More
Gautami Erukulla.
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
[swak4Foam] groovyBC issue - k and epsilon sagnikmazumdar OpenFOAM Community Contributions 24 March 1, 2015 07:16
[swak4Foam] groovyBC and Eqn.setReference() benk OpenFOAM Community Contributions 3 June 2, 2011 08:49
