Problems after having installed 1.7.0-Version on SUSE
Old   April 20, 2012, 07:23
Unhappy Problems after having installed 1.7.0-Version on SUSE
Isabell is on a distinguished road
Hello everyone!
I'm a complete 'freshman' using OpenFOAM and as it seems even failed installing it. I'm supposed so use the 1.7.0-version for my bachelor thesis. After having installed and uninstalled OpenFOAM probably a thousand times I was completely sure that I did everything correctly this time, but the installation test found an error:
Checking basic setup...
Shell: bash
Host: linux-lwyo.site
OS: Linux version 3.1.0-1.2-desktop
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/Isabell/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/Isabell/OpenFOAM/Isabell-1.7.0 yes no
$WM_THIRD_PARTY_DIR /home/Isabell/OpenFOAM/ThirdParty-1.7.0 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/Isabell/OpenFOAM/OpenFOAM-1.7.0 yes yes yes
$FOAM_APPBIN ...7.0/applications/bin/linux64GccDPOpt no yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.7.0/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...7.0/applications/bin/linux64GccDPOpt no no
$WM_DIR ...sabell/OpenFOAM/OpenFOAM-1.7.0/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.7.0/lib/linux64GccDPOpt no yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.7.0/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...AM/Isabell-1.7.0/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...0/platforms/linux64Gcc/openmpi-1.4.1 no yes
Third party software
Software Version Location
gcc 4.6.2 /usr/bin/gcc
gzip 1.4 /usr/bin/gzip
tar 1.26 /bin/tar
icoFoam
WARNING: Conflicting installations:
OpenFOAM settings : /home/Isabell/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
*** The foam installation contains 1 critical error(s)
*** Review the output for warning messages and consult
*** the installation guide for trouble shooting.
done.
Unfortunately I have no idea what this is supposed to tell me ^^
May anyone help me? That would be great!
Isabell
Isabell is offline   Reply With Quote
Old   April 20, 2012, 11:13
Retired Super Moderator
Bruno Santos
Greetings Isabell and welcome to the forum!
The maximum Gcc version compatible with OpenFOAM 1.7.0 is the Gcc 4.4.x series; minimum is 4.3.3. For OpenFOAM 1.7.1 you can use Gcc 4.5.x.
Gcc 4.6.1 that comes with openSUSE 12.1 isn't supported by those older OpenFOAM versions. I think you can still get on openSUSE 12.1 the older Gcc 4.3.4, directly from YaST/zypper. You'll need at least the packages gcc43 and gcc43-c++.
For using this version gcc43 version, you can see the instructions on this post: http://www.cfd-online.com/Forums/ope...tml#post278809 post #2
If you want to build a custom version of Gcc 4.4: Automated scripts for building gcc 4.4.x and 4.5.x for using with OpenFOAM 1.7 series
Good luck!
Bruno
Old   April 25, 2012, 11:12
Hey!
Thank you very much for your soon response!
But in the meantime some things were changing and it came um that I will use the 2.0 Version now. I hope there will be no problems..Otherwhise I know where to aks now
Thank you again, it's a great forum!
Isabell
1.7.0, critical error, icofoam
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems about Paraview and PV3foamreader clark_liang OpenFOAM Installation 1 January 12, 2009 06:05
Problems compiling UDFs under SuSE 10.2 George FLUENT 1 February 21, 2007 08:36
Problems with Gcc410 bucky83 OpenFOAM Installation 2 April 12, 2006 09:30
Installing OpenFOAM on SuSE Linux 91 Lars Edvardsen (Edvardsen) OpenFOAM Installation 2 January 10, 2005 02:26
