[foam-extend.org] OpenFOAM-1.6-ext on Ubuntu 12.04 install errors
Old   June 2, 2012, 12:28
Default OpenFOAM-1.6-ext on Ubuntu 12.04 install errors
Ben K
benk is on a distinguished road
Hi, I've been trying to install the latest git version of OpenFOAM-1.6-ext on a clean Ubuntu 12.04 distro, but I'm having some problems.
I was able to install everything in the ThirdParty (via rpm) and didn't run into any errors, but I get a bunch of errors (internal compiler errors) that I don't understand when doing ./Allwmake. Some of these errors are:
In file included from /usr/include/c++/4.6/algorithm:63:0,
                 from lnInclude/UList.C:33,
                 from lnInclude/UList.H:443,
                 from lnInclude/List.H:44,
                 from lnInclude/boolList.H:37,
                 from lnInclude/PrimitivePatch.H:55,
                 from lnInclude/primitivePatch.H:36,
                 from lnInclude/polyPatch.H:52,
                 from meshes/polyMesh/polyPatches/derived/cohesive/cohesivePolyPatch.H:41,
                 from meshes/polyMesh/polyPatches/derived/cohesive/cohesivePolyPatch.C:27:
/usr/include/c++/4.6/bits/stl_algo.h: In function ‘void std::__inplace_stable_sort(_RandomAccessIterator, _RandomAccessIterator, _Compare) [with _RandomAccessIterator = int*, _Compare = Foam::UList<int>::less]’:
/usr/include/c++/4.6/bits/stl_algo.h:3488:5: internal compiler error: in dwarf2out_frame_debug_expr, at dwarf2out.c:2556
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.6/README.Bugs> for instructions.
SOURCE=meshes/polyMesh/polyBoundaryMesh/polyBoundaryMeshEntries.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/polyBoundaryMeshEntries.o
SOURCE=meshes/ProcessorTopology/commSchedule.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/commSchedule.o
SOURCE=meshes/polyMesh/globalMeshData/globalMeshData.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/globalMeshData.o
The bug is not reproducible, so it is likely a hardware or OS problem.
make: *** [Make/linuxGccDPOpt/cohesivePolyPatch.o] Error 1
make: *** Waiting for unfinished jobs....
+ decompositionMethods/AllwmakeLnInclude
+ wmakeLnInclude decompositionMethods
+ wmakeLnInclude metisDecomp
+ wmakeLnInclude parMetisDecomp
+ wmakeLnInclude scotchDecomp
+ wmake libso scotchDecomp
home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/OBJsurfaceFormatRunTime.o
/tmp/ccZVn3cW.s: Assembler messages:
/tmp/ccZVn3cW.s:36323: Error: unknown pseudo-op: `.ulebq28'
make: *** [Make/linuxGccDPOpt/GTSsurfaceFormatRunTime.o] Error 1
+ wmake libso meshTools
Making dependency list for source file cellClassification/cellClassification.C
Making dependency list for source file cellClassification/cellInfo.C
Making dependency list for source file cellQuality/cellQuality.C
Making dependency list for source file cellDist/cellDistFuncs.C
Making dependency list for source file cellDist/patchWave/patchWave.C
SOURCE=fields/fvPatchFields/basic/sliced/slicedFvPatchFields.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/triSurface/lnInclude     -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -IlnInclude -I. -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/slicedFvPatchFields.o
g++: internal compiler error: Segmentation fault (program as)
make: *** [Make/linuxGccDPOpt/fixedValueFvPatchFields.o] Error 4
I'm using gcc-4.6, g++-4.6, cpp-4.6. I've also tried to install this with 4.5 and 4.4 compiler versions without any success.
Also, I haven't installed a new openfoam version in a while and I'm not too sure what to do with the etc/prefs.sh file. After renaming prefs.sh-EXAMPLE to prefs.sh and then sourcing etc/bashrc, I get a print out of some environment variables, some of which seem to be set and some of which aren't:
 Environment variables defined for OpenMPI:
    OPENMPI_BIN_DIR       : /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/bin
    OPENMPI_LIB_DIR       : /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/lib
    OPENMPI_INCLUDE_DIR   : /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/include
    OPENMPI_COMPILE_FLAGS : -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/include -pthread
    OPENMPI_LINK_FLAGS    : -pthread -L/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
    MPI_HOME              : /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt
    MPI_ARCH_PATH         : /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt
    OPAL_PREFIX           : /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt
    PINC                  : -I/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/include -pthread
    PLIBS                 : -pthread -L/home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/openmpi-1.4.3/platforms/linuxGccDPOpt/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
Sourcing: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linuxGccDPOpt/etc/mesquite-2.1.2.sh
    MESQUITE_DIR is initialized to: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linuxGccDPOpt
Sourcing: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linuxGccDPOpt/etc/metis-5.0pre2.sh
    METIS_DIR is initialized to: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linuxGccDPOpt
Sourcing: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linuxGccDPOpt/etc/ParMetis-3.1.1.sh
    PARMETIS_DIR is initialized to: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linuxGccDPOpt
Sourcing: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linuxGccDPOpt/etc/ParMGridGen-1.0.sh
    PARMGRIDGEN_DIR is initialized to: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linuxGccDPOpt
    LIBCCMIO_DIR is initialized to:
Sourcing: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linuxGccDPOpt/etc/scotch-5.1.10b.sh
    SCOTCH_DIR is initialized to: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linuxGccDPOpt
Sourcing: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.8/platforms/linuxGccDPOpt/etc/cmake-2.8.8.sh
    CMAKE_DIR is initialized to: /home/ben/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.8/platforms/linuxGccDPOpt
    M4_DIR is initialized to:
    BISON_DIR is initialized to:
    FLEX_DIR is initialized to:
    ZOLTAN_DIR is initialized to:
    PYTHON_DIR is initialized to:
    QT_DIR is initialized to:
    PARAVIEW_DIR is initialized to:
I'm not sure if this could be causing any problems or not.
Any tips would be much appreciated!
benk is offline   Reply With Quote
Old   June 6, 2012, 19:28
Retired Super Moderator
Bruno Santos
Greetings Ben,
Well, you maybe missed the following error message on the first output box you've posted:
Like the message (in bold) states, something veeery wrong is going on in your machine. Last time I saw this, I had one of the 4 memory sticks completely out-of-service Now I have my machine running with just 3 sticks...
I suggest two things:
  1. Install stressapptest and test your system's memory+CPU interoperability:
    sudo apt-get install stressapptest
    stressapptest --cc_test -W
    You can also use the "-M" option for defining the number of MB of RAM to test with. For example, for 3000 MB:
    stressapptest --cc_test -W -M 3000
  2. Boot a live CD/DVD with an older version of any Linux distribution and do the same test with stressapptest.
If both of these give you a report of a problem with your hardware, then it's very likely a bad memory module.
But it's also possible that's a problem with the hard-drive or that your Ubuntu installation is missing a beat somehow, either because of a bad install or because it's not fully compatible with your machine.
And it could also be because the CPU or memory is running too hot!
Good luck!
Bruno
Old   July 2, 2012, 11:52
Hugues Chratiart
Vault13dweller is on a distinguished road
Hi everybody,
I'm trying to install OpenFOAM-1.6-ext on my computer with distribution Ubuntu 12.04 (32 bits) but I couldn't solve a problem in stage 3. I'm following these instructions :
http://openfoam-extend.git.sourcefor...3472fd1ef579fa
Here is the error I get (at the end of the code):
This system rpm command: rpm --force-debian
Starting ThirdParty AllMake: Stage3
Package name      : metis-5.0pre2
Package URL       : http://glaros.dtc.umn.edu/gkhome/fetch/sw/metis/OLD/metis-5.0pre2.tar.gz
RPM spec file name: metis-5.0pre2.spec
Additional flags  :
Updating the ThirdParty environment variables before building package metis-5.0pre2
Package metis-5.0pre2 is already installed
Done installing package
Package name      : ParMGridGen-1.0
Package URL       : http://www.mgnet.org/mgnet/Codes/parmgridgen/ParMGridGen-1.0.tar.gz
RPM spec file name: ParMGridGen-1.0.spec
Additional flags  :
Updating the ThirdParty environment variables before building package ParMGridGen-1.0
Package ParMGridGen-1.0 is already installed
Package name      : libccmio-2.6.1
Package URL       : https://wci.llnl.gov/codes/visit/3rd_party/libccmio-2.6.1.tar.gz
RPM spec file name: libccmio-2.6.1.spec
Additional flags  :
Updating the ThirdParty environment variables before building package libccmio-2.6.1
Making package libccmio-2.6.1 using RPM.
Building package libccmio-2.6.1 using SPEC file : libccmio-2.6.1.spec. Optional args:
Exécution_de(%prep): /bin/sh -e /home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.oaSIgG
+ umask 022
+ cd /home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD
+ rm -rf libccmio-2.6.1
+ /bin/gzip -dc+ home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/SOURCES/libccmio-2.6.1.tar.gz
/bin/tar -xf -
+ STATUS=0
+ [ 0 -ne 0 ]
+ cd libccmio-2.6.1
+ echo Patch #0 (libccmio-2.6.1.patch_0):
+ /bin/cat -s -p1 --fuzz=0
+ exit 0
Exécution_de(%build): /bin/sh -e /home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.JuDrlx
+ umask 022
+ cd libccmio-2.6.1
+ [ -n gcc ]
+ export CC=gcc
+ [ -n g++ ]
+ export CXX=g++
+ [ -n  ]
+ [ -n  ]
+ [ -n  ]
+ [ -z 2 ]
+ unset RELEASE
+ unset DEBUG
+ unset STATIC
+ unset SHARED
+ [ -d libadf ]
+ cd libadf
+ RELEASE=1 SHARED=1 make -f Makefile.qmake all
..//config/runqmake ../ \
      -o Makefile.adf adf.pro 2>&1 | tee qmake.vars
..//config/runqmake: line 47: /home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf/..//config/unknown/qmake: No such file or directory
make[1]: Entering directory `/home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf'
make[1]: *** No rule to make target `/u/xeona04/people/prewett/src/libccmio/config/linux64_2.4-x86-glibc_2.2.5/qmake.conf', needed by `Makefile.adf'.  Stop.
make[1]: Leaving directory `/home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/libccmio-2.6.1/libadf'
make: *** [all] Error 2
error: bad output status for /home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.JuDrlx (%build)
Thank you in advance for any help
Vault13dweller is offline   Reply With Quote
Old   July 3, 2012, 03:57
Elvis
elvis will become famous soon enough
+ cd libccmio-2.6.1
+ [ -n gcc ]
+ export CC=gcc
+ [ -n g++ ]
+ export CXX=g++
+ [ -n ]
+ [ -n ]
+ [ -n ]
+ [ -z 2 ]
+ unset RELEASE
+ unset DEBUG
+ unset STATIC
+ unset SHARED
+ [ -d libadf ]
+ cd libadf
error: bad output status for /home/utilisateur/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/tmp/rpm-tmp.JuDrlx (%build)[/CODE]
do you follow http://openfoam-extend.git.sourcefor...cb6bbd;hb=HEAD
elvis is offline   Reply With Quote
Old   July 3, 2012, 12:59
Hugues Chratiart
Indeed, it seemed there was no difference between 64 and 32 bits in this installation process.
Old   July 19, 2012, 17:45
Hugues Chratiart
This was solved with this new installation process :
http://openfoam-extend.git.sourcefor...02de56;hb=HEAD
Old   July 27, 2012, 04:27
Default errors in install openfoam 1.6 ext to ubuntu 12.04 32 bit
Sabrinho Gonzalez
spam3c is on a distinguished road
Hi everyone,
I am trying to install openfoam-1.6-ext to ubuntu 12.04 32 bit (upgraded from 11.10).
I am following the procedure given at
at line 86 I got the error
bash: /opt/OpenFOAM-1.6-ext/bin/foamEtcFile: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/bin/foamCleanPath: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/etc/settings.sh: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/etc/aliases.sh: No such file or directory
I thought that might not be so important and continued
and at line 91, I got
bash: cd: /opt/OpenFOAM-1.6-ext/ThirdParty: No such file or directory
before continuing further I would like to ask what to do?
I have checked the /opt/ folder but nothing exists there.
I could not copy the "OpenFOAM-1.6-ext" folder directly from
/home/spam3c/OpenFOAM/
to
/opt/
I am a new user in linux and openfoam.
Sorry for the dummy questions that i may ask
Thanks for the comments and help
spam3c is offline   Reply With Quote
Old   July 27, 2012, 07:56
Martin Beaudoin
mbeaudoin will become famous soon enough
The instructions provided assume that your installation directory is located under ~/OpenFOAM.
You are obviously installing 1.6-ext under /opt, so you have to expect some adjustments.
Please check the "user editable" section of your file etc/bashrc. The variable 'foamInstall' is the one you need to adjust.
This necessary adjustment, and others, are profusely documented on this Forum and on various wikis all over the Web. Next time, just supply your error messages to Google for some magic...
Martin
Originally Posted by spam3c View Post
Hi everyone,
to
/opt/
mbeaudoin is offline   Reply With Quote
Old   July 27, 2012, 08:07
Sabrinho Gonzalez
Thanks for the reply and google advice
Surely, I use a lot and it makes me lost sometimes.
After following the previous lines in the given procedure
The openfoam files are stored in this folder
/home/spam3c/OpenFOAM/OpenFOAM-1.6-ext
and the /home/spam3c/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
file has the following part which I guess it tries to install to my home directory
but not
to /opt/openfoam...
where my previous installation of openfoam-2.1.0 is there.
# USER EDITABLE PART
# either set $FOAM_INST_DIR before sourcing this file or set
# $foamInstall below to where OpenFOAM is installed
# Location of FOAM installation
foamInstall=$HOME/$WM_PROJECT
# foamInstall=~$WM_PROJECT
# foamInstall=/usr/local/$WM_PROJECT
# foamInstall=/opt/$WM_PROJECT
# foamInstall=/usr/lib
# END OF (NORMAL) USER EDITABLE PART
Still I get the same error, I am confused.
Thanks
Old   July 28, 2012, 12:19
Martin Beaudoin
Basically, it looks like you are still sourcing your OF 2.1.0 environment prior to initializing your installation of 1.6-ext.
Since both installations are sharing some common basic environment variables, your 1.6-ext initialization file is looking for some files under your 2.1.0 installation, hence the error messages.
Make sure you are not activating OF from your $HOME configuration files, like from your ~/.profile or ~/.bashrc. This is a bad idea when you need to switch between various OF versions.
Martin
but not
to /opt/openfoam...
Thanks
Old   July 30, 2012, 02:58
Default Official build instructions not working for new 12.04 install
  #11
atg
Karl
atg is on a distinguished road
I am not sure why, but the script from Sourceforge does not result in a working build of 1.6-ext on a fresh 12.04 Ubuntu install. Third Party script #4 gives errors, and the final ./Allwmake appears to go very well until yPlusRAS (see below). I would appreciate a hint as I have now burned up at least a week of evenings and a weekend trying to get this working. I am hampered by not being able to understand the code enough to figure out the specific problem.
I reinstalled Ubuntu now and it will not work on either the 3.2.0.23, 3.2.0.26 or 3.2.0.27 kernels. So I suppose it has nothing to do with the kernel. I kept my old home folder but removed the OpenFOAM directory entirely and re-cloned it etc. per the instructions.
My environment variables seem OK:
karl@karl-Ubuntu-CFD:~/OpenFOAM/OpenFOAM-1.6-ext$ . ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/etc/settings.sh
OPENMPI_BIN_DIR : /usr/bin
OPENMPI_LIB_DIR : /usr/lib/openmpi/lib
OPENMPI_INCLUDE_DIR : /usr/lib/openmpi/include /usr/lib/openmpi/include/openmpi
OPENMPI_COMPILE_FLAGS : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread
OPENMPI_LINK_FLAGS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
MPI_HOME : /usr
MPI_ARCH_PATH : /usr
OPAL_PREFIX : /usr
PINC : -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi -pthread
PLIBS : -pthread -L/usr/lib/openmpi/lib -lmpi -lopen-rte -lopen-pal -ldl -Wl,--export-dynamic -lnsl -lutil -lm -ldl
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt/etc/mesquite-2.1.2.sh
MESQUITE_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/mesquite-2.1.2/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64Gcc46DPOpt/etc/metis-5.0pre2.sh
METIS_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/metis-5.0pre2/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64Gcc46DPOpt/etc/ParMetis-3.1.1.sh
PARMETIS_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMetis-3.1.1/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt/etc/ParMGridGen-1.0.sh
PARMGRIDGEN_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParMGridGen-1.0/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt/etc/libccmio-2.6.1.sh
LIBCCMIO_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/libccmio-2.6.1/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64Gcc46DPOpt/etc/scotch-5.1.10b.sh
SCOTCH_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/scotch-5.1.10b/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.8/platforms/linux64Gcc46DPOpt/etc/cmake-2.8.8.sh
CMAKE_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/cmake-2.8.8/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/qt-everywhere-opensource-src-4.7.4/platforms/linux64Gcc46DPOpt/etc/qt-everywhere-opensource-src-4.7.4.sh
QT_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/qt-everywhere-opensource-src-4.7.4/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.12.0/platforms/linux64Gcc46DPOpt/etc/ParaView-3.12.0.sh
PARAVIEW_DIR is initialized to: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/ParaView-3.12.0/platforms/linux64Gcc46DPOpt
Sourcing: /home/karl/OpenFOAM/OpenFOAM-1.6-ext/etc/aliases.sh
I looked through the third party logs and it seems that #4 is where the trouble begins. It completes, but the final ./Allwmake script hangs up reliably on the incompressible yPlusRAS:
Making dependency list for source file yPlusRAS.C
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/LES/LESModel -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/LES/LESdeltas/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc46DPOpt/yPlusLES.o -L/home/karl/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt \
-lincompressibleLESModels -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home/karl/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/yPlusLES
SOURCE=yPlusRAS.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/yPlusRAS.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/transportModels -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/incompressible/RAS/derivedFvPatchFields/wallFunctions/nutWallFunctions -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/turbulenceModels/compressible/RAS/derivedFvPatchFields/wallFunctions/mutWallFunctions -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/basic/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc46DPOpt/yPlusRAS.o -L/home/karl/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt \
-lincompressibleTransportModels -lincompressibleRASModels -lbasicThermophysicalModels -lspecie -lcompressibleRASModels -lfiniteVolume -lmeshTools -lsampling -lOpenFOAM -liberty -ldl -lm -o /home/karl/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/yPlusRAS
The terminal cursor just keeps blinking indefinitely (>12 hours) at this point and there is no processor or network activity. This is an four core machine building on eight threads. I actually had 1.6-ext working on it not long ago, but a kernel update appeared to kill it.
I think the problem is in the fourth ThirdParty build script, which gives me this sort of thing for several pages (see below), even though it completes the script. Is this a problem building Qt? Any input appreciated.
Thanks in Advance; I hope I have included enough information to answer the question.
Karl
g++ -m64 -Wl,--no-undefined -Wl,-O1 -Wl,-rpath,/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/qt-everywhere-opensource-src-4.7.4/platforms/linux64Gcc46DPOpt/lib -Wl,-rpath,/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/packages/qt-everywhere-opensource-src-4.7.4/platforms/linux64Gcc46DPOpt/lib -shared -Wl,-soname,libQtSvg.so.4 -o libQtSvg.so.4.7.4 .obj/release-shared/qsvggraphics.o .obj/release-shared/qsvghandler.o .obj/release-shared/qsvgnode.o .obj/release-shared/qsvgstructure.o .obj/release-shared/qsvgstyle.o .obj/release-shared/qsvgfont.o .obj/release-shared/qsvgtinydocument.o .obj/release-shared/qsvgrenderer.o .obj/release-shared/qsvgwidget.o .obj/release-shared/qgraphicssvgitem.o .obj/release-shared/qsvggenerator.o .obj/release-shared/moc_qsvgwidget.o -L/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/lib -lQtGui -L/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/lib -L/usr/X11R6/lib64 -lQtCore -lpthread -lz
ln -s libQtSvg.so.4.7.4 libQtSvg.so
ln -s libQtSvg.so.4.7.4 libQtSvg.so.4
ln -s libQtSvg.so.4.7.4 libQtSvg.so.4.7
rm -f ../../lib/libQtSvg.so.4.7.4
mv -f libQtSvg.so.4.7.4 libQtSvg.so libQtSvg.so.4 libQtSvg.so.4.7 ../../lib/
make[1]: Leaving directory `/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/svg'
cd src/script/ && make -f Makefile
make[1]: Entering directory `/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/script'
/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/bin/qmake -spec ../../mkspecs/linux-g++-64 -o Makefile script.pro
make[1]: Leaving directory `/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/script'
g++ -c -m64 -fPIC -Wall -Wreturn-type -fno-strict-aliasing -Wcast-align -Wchar-subscripts -Wformat-security -Wreturn-type -Wno-unused-parameter -Wno-sign-compare -Wno-switch -Wno-switch-enum -Wundef -Wmissing-noreturn -Winit-self -fno-stack-protector -O2 -fvisibility=hidden -fvisibility-inlines-hidden -D_REENTRANT -fPIC -DQT_SHARED -DJSC=QTJSC -Djscyyparse=qtjscyyparse -Djscyylex=qtjscyylex -Djscyyerror=qtjscyyerror -DWTF=QTWTF -DQT_BUILD_SCRIPT_LIB -DQT_NO_USING_NAMESPACE -DQLALR_NO_QSCRIPTGRAMMAR_DEBUG_INFO -DQT_NO_CAST_TO_ASCII -DQT_ASCII_CAST_WARNINGS -DQT3_SUPPORT -DQT_MOC_COMPAT -DQT_USE_FAST_OPERATOR_PLUS -DQT_USE_FAST_CONCATENATION -DBUILDING_QT__=1 -DWTF_USE_ACCELERATED_COMPOSITING -DNDEBUG -DBUILDING_QT__ -DBUILDING_JavaScriptCore -DBUILDING_WTF -DWTF_USE_JAVASCRIPTCORE_BINDINGS=1 -DWTF_CHANGES=1 -DNDEBUG -DJS_NO_EXPORT -DQT_NO_DEBUG -DQT_CORE_LIB -DQT_HAVE_MMX -DQT_HAVE_3DNOW -DQT_HAVE_SSE -DQT_HAVE_MMXEXT -DQT_HAVE_SSE2 -DQT_HAVE_SSE3 -DQT_HAVE_SSSE3 -DQT_HAVE_SSE4_1 -DQT_HAVE_SSE4_2 -DQT_HAVE_AVX -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -I../../mkspecs/linux-g++-64 -I. -I../../include/QtCore -I../../include -I../3rdparty/javascriptcore/JavaScriptCore -I../3rdparty/javascriptcore -I../3rdparty/javascriptcore/JavaScriptCore/assembler -I../3rdparty/javascriptcore/JavaScriptCore/bytecode -I../3rdparty/javascriptcore/JavaScriptCore/bytecompiler -I../3rdparty/javascriptcore/JavaScriptCore/debugger -I../3rdparty/javascriptcore/JavaScriptCore/interpreter -I../3rdparty/javascriptcore/JavaScriptCore/jit -I../3rdparty/javascriptcore/JavaScriptCore/parser -I../3rdparty/javascriptcore/JavaScriptCore/pcre -I../3rdparty/javascriptcore/JavaScriptCore/profiler -I../3rdparty/javascriptcore/JavaScriptCore/runtime -I../3rdparty/javascriptcore/JavaScriptCore/wrec -I../3rdparty/javascriptcore/JavaScriptCore/wtf -I../3rdparty/javascriptcore/JavaScriptCore/wtf/symbian -I../3rdparty/javascriptcore/JavaScriptCore/wtf/unicode -I../3rdparty/javascriptcore/JavaScriptCore/yarr -I../3rdparty/javascriptcore/JavaScriptCore/API -I../3rdparty/javascriptcore/JavaScriptCore/ForwardingHeaders -I../3rdparty/javascriptcore/JavaScriptCore/generated -I../../include/QtScript -I.rcc/release-shared -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/3rdparty/javascriptcore/WebKit/qt/Api -I../3rdparty/javascriptcore/JavaScriptCore/pcre -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/3rdparty/javascriptcore/JavaScriptCore/tmp -I../3rdparty/javascriptcore/JavaScriptCore -I../3rdparty/javascriptcore/JavaScriptCore/parser -I../3rdparty/javascriptcore/JavaScriptCore/bytecompiler -I../3rdparty/javascriptcore/JavaScriptCore/debugger -I../3rdparty/javascriptcore/JavaScriptCore/runtime -I../3rdparty/javascriptcore/JavaScriptCore/wtf -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/script/../3rdparty/javascriptcore/JavaScriptCore/unicode -I../3rdparty/javascriptcore/JavaScriptCore/interpreter -I../3rdparty/javascriptcore/JavaScriptCore/jit -I../3rdparty/javascriptcore/JavaScriptCore/profiler -I../3rdparty/javascriptcore/JavaScriptCore/wrec -I../3rdparty/javascriptcore/JavaScriptCore/API -I../3rdparty/javascriptcore/JavaScriptCore/bytecode -I../3rdparty/javascriptcore/JavaScriptCore/assembler -I../3rdparty/javascriptcore/JavaScriptCore/generated -I. -Iparser -I.moc/release-shared -o obj/release/pcre_compile.o ../3rdparty/javascriptcore/JavaScriptCore/pcre/pcre_compile.cpp
g++ -c -m64 -fPIC -Wall -Wreturn-type -fno-strict-aliasing -Wcast-align -Wchar-subscripts -Wformat-security -Wreturn-type -Wno-unused-parameter -Wno-sign-compare -Wno-switch -Wno-switch-enum -Wundef -Wmissing-noreturn -Winit-self -fno-stack-protector -O2 -fvisibility=hidden -fvisibility-inlines-hidden -D_REENTRANT -fPIC -DQT_SHARED -DJSC=QTJSC -Djscyyparse=qtjscyyparse -Djscyylex=qtjscyylex -Djscyyerror=qtjscyyerror -DWTF=QTWTF -DQT_BUILD_SCRIPT_LIB -DQT_NO_USING_NAMESPACE -DQLALR_NO_QSCRIPTGRAMMAR_DEBUG_INFO -DQT_NO_CAST_TO_ASCII -DQT_ASCII_CAST_WARNINGS -DQT3_SUPPORT -DQT_MOC_COMPAT -DQT_USE_FAST_OPERATOR_PLUS -DQT_USE_FAST_CONCATENATION -DBUILDING_QT__=1 -DWTF_USE_ACCELERATED_COMPOSITING -DNDEBUG -DBUILDING_QT__ -DBUILDING_JavaScriptCore -DBUILDING_WTF -DWTF_USE_JAVASCRIPTCORE_BINDINGS=1 -DWTF_CHANGES=1 -DNDEBUG -DJS_NO_EXPORT -DQT_NO_DEBUG -DQT_CORE_LIB -DQT_HAVE_MMX -DQT_HAVE_3DNOW -DQT_HAVE_SSE -DQT_HAVE_MMXEXT -DQT_HAVE_SSE2 -DQT_HAVE_SSE3 -DQT_HAVE_SSSE3 -DQT_HAVE_SSE4_1 -DQT_HAVE_SSE4_2 -DQT_HAVE_AVX -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -I../../mkspecs/linux-g++-64 -I. -I../../include/QtCore -I../../include -I../3rdparty/javascriptcore/JavaScriptCore -I../3rdparty/javascriptcore -I../3rdparty/javascriptcore/JavaScriptCore/assembler -I../3rdparty/javascriptcore/JavaScriptCore/bytecode -I../3rdparty/javascriptcore/JavaScriptCore/bytecompiler -I../3rdparty/javascriptcore/JavaScriptCore/debugger -I../3rdparty/javascriptcore/JavaScriptCore/interpreter -I../3rdparty/javascriptcore/JavaScriptCore/jit -I../3rdparty/javascriptcore/JavaScriptCore/parser -I../3rdparty/javascriptcore/JavaScriptCore/pcre -I../3rdparty/javascriptcore/JavaScriptCore/profiler -I../3rdparty/javascriptcore/JavaScriptCore/runtime -I../3rdparty/javascriptcore/JavaScriptCore/wrec -I../3rdparty/javascriptcore/JavaScriptCore/wtf -I../3rdparty/javascriptcore/JavaScriptCore/wtf/symbian -I../3rdparty/javascriptcore/JavaScriptCore/wtf/unicode -I../3rdparty/javascriptcore/JavaScriptCore/yarr -I../3rdparty/javascriptcore/JavaScriptCore/API -I../3rdparty/javascriptcore/JavaScriptCore/ForwardingHeaders -I../3rdparty/javascriptcore/JavaScriptCore/generated -I../../include/QtScript -I.rcc/release-shared -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/3rdparty/javascriptcore/WebKit/qt/Api -I../3rdparty/javascriptcore/JavaScriptCore/pcre -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/3rdparty/javascriptcore/JavaScriptCore/tmp -I../3rdparty/javascriptcore/JavaScriptCore -I../3rdparty/javascriptcore/JavaScriptCore/parser -I../3rdparty/javascriptcore/JavaScriptCore/bytecompiler -I../3rdparty/javascriptcore/JavaScriptCore/debugger -I../3rdparty/javascriptcore/JavaScriptCore/runtime -I../3rdparty/javascriptcore/JavaScriptCore/wtf -I/home/karl/OpenFOAM/OpenFOAM-1.6-ext/ThirdParty/rpmBuild/BUILD/qt-everywhere-opensource-src-4.7.4/src/script/../3rdparty/javascriptcore/JavaScriptCore/unicode -I../3rdparty/javascriptcore/JavaScriptCore/interpreter -I../3rdparty/javascriptcore/JavaScriptCore/jit -I../3rdparty/javascriptcore/JavaScriptCore/profiler -I../3rdparty/javascriptcore/JavaScriptCore/wrec -I../3rdparty/javascriptcore/JavaScriptCore/API -I../3rdparty/javascriptcore/JavaScriptCore/bytecode -I../3rdparty/javascriptcore/JavaScriptCore/assembler -I../3rdparty/javascriptcore/JavaScriptCore/generated -I. -Iparser -I.moc/release-shared -o obj/release/pcre_exec.o ../3rdparty/javascriptcore/JavaScriptCore/pcre/pcre_exec.cpp
../3rdparty/javascriptcore/JavaScriptCore/pcre/pcre_compile.cpp: In function 'bool compileBranch(int, int*, unsigned char**, const UChar**, const UChar*, ErrorCode*, int*, int*, CompileData&)':
../3rdparty/javascriptcore/JavaScriptCore/pcre/pcre_compile.cpp:582:18: warning: variable 'tempptr' set but not used [-Wunused-but-set-variable]
...etc
atg is offline   Reply With Quote
Old   July 30, 2012, 09:13
Sabrinho Gonzalez
Thanks for the comment, Martin
After that, I have used aliases for the two installations and "allwmake" worked fine except the following error.
I got this error when I ran the foamInstallationTest.
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version : 4.6.3
Minimum required: 4.3.1
gcc 4.6.3
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
Somewhere, I have read that this is not an important error and will not affect my openfoam's working. Still, I would like to be sure, and that is why I ask.
I have also attached my make.log file.
Thanks a lot for your kind help.
Martin
Old   August 8, 2012, 06:42
Jack
JackW is on a distinguished road
I am following the same instructions: http://openfoam-extend.git.sourcefor...cb6bbd;hb=HEAD
...and I get the same problem as atg (it hangs up on the incompressible yplusRAS)
atg, I was wondering if you have solved your issue?
...also not all of the initial downloads can be found, (lines 10-20) -> I wondered if this was a major issue?
I have had OF-2.1.1 and OF-1.7 on this machine already. I am a relative newcomer to linux and so if there was something I was supposed to do in between installations you can just about guarantee I won't have done it! (except for sudo apt-get remove).
Or anyone, I was wondering if there is something I am supposed to do prior to this installation process?
Thank you for any help you can give me!
Jack
JackW is offline   Reply With Quote
Old   August 11, 2012, 23:49
atg
Karl
Sorry Jack,
I never did resolve that issue. It's too bad, because it actually worked for me before one of the latest Ubuntu updates seemed to screw it up. One of the first instructions is to sudo apt-get update your Ubuntu installation, so it leaves the OF package vulnerable to any changes Ubuntu might implement which create problems for the installer instructions.
Fortunately there are a bunch of .iso images out there that will get you up and running in no time. I used one from the OF workshop 7 with various versions installed. It is old 10.04 Ubuntu but no matter. You can run it from the USB or install it. I think this should work:
http://sourceforge.net/projects/open...x.iso/download
Now if I can only get myself to an actual workshop somehow...
Old   August 13, 2012, 12:08
Martin Beaudoin
You can easily forget about 'foamInstallationTest'.
Martin
gcc 4.6.3
CRITICAL ERROR
Old   August 13, 2012, 12:20
Martin Beaudoin
@yPlusRAS:
On my up-to-date Ubuntu 12.04 32-bits machine, with merely 1GB of RAM, this application compiles under 7s.
Out of curiosity, how much memory do you have on your system?
What is the value of this environment variable $WM_NCOMPPROCS ?
As for the rest of your logs, those are normal compilation output messages, not error messages.
For your information, AllMake.stage4 is for compiling QT and Paraview. This has nothing to do with yPlusRAS.
Martin
MPI_HOME : /usr
OPAL_PREFIX : /usr
Karl
...etc
Old   August 28, 2012, 04:52
mechy is on a distinguished road
Originally Posted by elvis View Post
Dear Elvis
when I run . ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
I encounter bellow error what should I do ?
bash: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/bin/foamEtcFile: Permission denied
bash: /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/bin/foamCleanPath: Permission denied
Best Regards
mechy is offline   Reply With Quote
Old   August 28, 2012, 05:37
Elvis
did you try to change the permission via chmod (hope you have got the rights to do so!?) user: 7=excute&read&write group: 5=excute&read other: 1=excute
sudo chmod -R 751 /home/aminiyasser/OpenFOAM/OpenFOAM-1.6-ext/bin
Old   August 30, 2012, 15:25
atg
Karl
I am not certain, but I think the problem I was having may have been due to the fact that this command (from the instructions) no longer appears to work:
sudo apt-get install zlib1g-dev
So if one uses the "all in one" command:
# You can also install everything at once:
sudo apt-get install git flex bison rpm g++ zlib1g-dev binutils-dev \
openmpi-bin libopenmpi-dev libxext-dev libxt-dev libxrender-dev \
libstdc++5 libgl1-mesa-dev libglu1-mesa-dev
one can miss the fact that one package did not install properly.
I downloaded it and installed it manually: http://packages.ubuntu.com/dapper/zlib1g-dev
Now stage 4 builds again.
Of course I could be totally wrong; if I knew anything I would not be asking for help here.
Thanks for your reply.
To answer your question, I tried it twice on two different machines, one with four core Xeon E3-1280 and 16Gb RAM, and one Core 2 Duo with 4Gb Ram, set to varying numbers of compiler processors. Both were failing at the same place. Now it is working on the Core2Duo machine in 32 bit again. I am debating whether to mess with the working 10.04 installation on the faster machine, as I have cufflink working over there now and it just doesn't seem worth the trouble.
@yPlusRAS:
Martin
Old   August 30, 2012, 16:15
Jack
Sorry Jack,
Thanks for this!
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Environment errors with .deb install and ubuntu 13.04 64 bit jonathanbyrn OpenFOAM Installation 14 September 26, 2013 05:22
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
