Help!! Need: Walkthrough OpenFOAM-1.6-ext on OpenSUSE 12.1 64bit
Like Tree1Likes
Old   August 9, 2012, 10:24
Default Help!! Need: Walkthrough OpenFOAM-1.6-ext on OpenSUSE 12.1 64bit
Chiku
iznal is on a distinguished road
Hi guys
I have tried a couple of days to install and compile the OpenFOAM-1.6-ext on my laptop. I didn't make it. There are two critical errors. Could someone post your successful Walkthrough of Install OpenFOAM-1.6-ext on OpenSUSE 12.1 64bit!
Thanks a lot!
iznal is offline   Reply With Quote
Old   August 9, 2012, 10:28
Retired Super Moderator
Bruno Santos
Uhm... The walkthrough your asking for is already available in 1.6-ext, in the path "doc/buildInstructions/openSUSE/12.1/Compilation_openSUSE_12.1_64bit.txt".
You can see it online here: http://openfoam-extend.git.sourcefor...it.txt;hb=HEAD
Old   August 9, 2012, 10:32
Chiku
It's not 100% correct, I did trying this one, but not succeed. Have you installed your 1.6-ext on OpenSUSE 12.1 64 bit?
Old   August 9, 2012, 10:43
Bruno Santos
I haven't tried it, but neither did you first reference that you had followed those instructions
What errors are you getting?
Old   August 9, 2012, 10:48
Chiku
It happens in gcc and gzip.
Checking basic setup...
Shell: bash
Host: linux-16n7.site
OS: Linux version 3.1.0-1.2-desktop
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/yukaiyu/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/yukaiyu/OpenFOAM/yukaiyu-1.6-ext no no
$WM_THIRD_PARTY_DIR ...OpenFOAM/OpenFOAM-1.6-ext/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext yes yes yes
$FOAM_APPBIN ...t/applications/bin/linux64Gcc46DPOpt yes yes yes
$FOAM_SITE_APPBIN ...M/site/1.6-ext/bin/linux64Gcc46DPOpt no no
$FOAM_USER_APPBIN ...t/applications/bin/linux64Gcc46DPOpt no no
$WM_DIR ...aiyu/OpenFOAM/OpenFOAM-1.6-ext/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...enFOAM-1.6-ext/lib/linux64Gcc46DPOpt yes yes yes
$FOAM_SITE_LIBBIN ...M/site/1.6-ext/lib/linux64Gcc46DPOpt no no
$FOAM_USER_LIBBIN ...ukaiyu-1.6-ext/lib/linux64Gcc46DPOpt no no
$MPI_ARCH_PATH /usr/lib64/mpi/gcc/openmpi yes no yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.3
User version : 4.6.2
Minimum required: 4.3.1
gcc 4.6.2
WARNING: Conflicting installations:
OpenFOAM settings : /bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.4 /usr/bin/gzip
tar 1.26 /bin/tar
icoFoam
OpenFOAM settings : /home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
Old   August 9, 2012, 10:51
Bruno Santos
OK, what are the first errors shown in "log.Allwmake"?
Old   August 9, 2012, 11:09
Bruno Santos
There is one step they didn't mention: after installing the system's Open-MPI, you have to log out and log back in. Otherwise it isn't known to the working session as to which mpirun to use.
Old   August 9, 2012, 11:10
Chiku
First one:
flex wmkdep.l
make: flex: Command not found
make: *** [/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/wmake/bin/linux64Gcc46/wmkdep] Error 127
Second One
wmakeLnInclude: linking include files to ./lnInclude
/bin/sh: /home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/wmake/bin/linux64Gcc46/wmkdep: No such file or directory
SOURCE=scotchDecomp/scotchDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/scotchDecomp.o
SOURCE=engineScotchDecomp/engineScotchDecomp.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/engineScotchDecomp.o
In file included from scotchDecomp/scotchDecomp.C:108:0:
scotchDecomp/scotchDecomp.H:39:33: fatal error: decompositionMethod.H: No such file or directory
compilation terminated.
Old   August 9, 2012, 11:12
Bruno Santos
OK, they are related. The first one should be fixed if you run as root (or with sudo):
zypper install -t pattern devel_C_C++
Old   August 9, 2012, 11:15
Chiku
Ok, but actually I followed the tutorial from Martin Beaudoin. The OpenMPI in stage2 is not installed in my laptop. I used the OpenMPI direct from System. Would you like to see all the log files, I could send you, cause I don't know how to post them all.
Old   August 9, 2012, 11:19
Bruno Santos
If I'm not mistaken, it won't be necessary for me to see the logs
I'm trying the steps myself and so far from your feedback the following steps are missing in the walkthrough:
  1. This needs to also be installed, to make sure that flex and other building utilities are installed:
  2. The system Open-MPI will only be fully available if you log out and log back in.
Old   August 9, 2012, 11:28
Chiku
Awesome! You are a big boss!
Any Ideas about this one?
scotchDecomp/scotchDecomp.C:116:20: fatal error: scotch.h: No such file or directory
make: *** [Make/linux64Gcc46DPOpt/scotchDecomp.o] Error 1
make: *** Waiting for unfinished jobs....
engineScotchDecomp/engineScotchDecomp.C:36:5: error: ‘adddictionaryMeshConstructorToTable’ in ‘class Foam::scotchDecomp’ does not name a type
make: *** [Make/linux64Gcc46DPOpt/engineScotchDecomp.o] Error 1
Old   August 9, 2012, 11:31
Chiku
You are right. The first error disappeared.
How to solve this issue? should I compile the OpenMPI with Allwmake.stage2?
Old   August 9, 2012, 11:35
Bruno Santos
Run AllMake.stage3 again.
If you can't log out and log back in, then let's try for now building OpenFOAM without logging out and back in.
Old   August 9, 2012, 11:55
Chiku
I have ran AllMake.stage3 agian.
and sourced the . ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc.
and ran the Allwmake. The error motionSolver.H comes out. Should I download it, and save in /home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude/
+ dynamicMesh/Allwmake
+ wmakeLnInclude dynamicMesh
+ wmake libso dynamicMesh
'/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libdynamicMesh.so' is up to date.
+ meshMotion/Allwmake
+ wmake libso fvMotionSolver
'/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libfvMotionSolver.so' is up to date.
+ wmake libso RBFMotionSolver
'/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/lib/linux64Gcc46DPOpt/libRBFMotionSolver.so' is up to date.
+ wmake libso mesquiteMotionSolver
SOURCE=mesquiteMotionSolver.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/meshTools/lnInclude -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude -IlnInclude -I. -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude -I/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64Gcc46DPOpt/mesquiteMotionSolver.o
In file included from mesquiteMotionSolver.H:40:0,
from mesquiteMotionSolver.C:27:
/home/yukaiyu/OpenFOAM/OpenFOAM-1.6-ext/src/dynamicMesh/dynamicMesh/lnInclude/motionSolver.H:41:32: fatal error: twoDPointCorrector.H: No such file or directory
make: *** [Make/linux64Gcc46DPOpt/mesquiteMotionSolver.o] Error 1
+ cd tetDecompositionMotionSolver
Old   August 9, 2012, 12:04
Bruno Santos
I have a feeling you better run the other stages as well, namely:
cd $WM_PROJECT_DIR/ThirdParty
./AllMake.stage1 >& log.AllMake.stage1
./AllMake.stage4 >& log.AllMake.stage4
Old   August 9, 2012, 12:22
Chiku
my log file contains no errors. But by doing the foamInstallationTest it shows a critical error.
Shell: bash
gcc 4.6.2
CRITICAL ERROR
tar 1.26 /bin/tar
icoFoam 1.6-ext ...OAM-1.6-ext/applications/bin/linux64Gcc46DPOpt/icoFoam
Summary
The foam installation contains 1 critical error(s).
done.
Old   August 9, 2012, 12:40
Bruno Santos
Not to worry, that's an old bug in the diagnosis script
I think you're ready to start using 1.6-ext!
Have fun!
iznal likes this.
Old   August 9, 2012, 23:42
Martin Beaudoin
mbeaudoin will become famous soon enough
@the build instructions for OpenSUSE 12.1 64bit:
I just tested every single instructions of the build instructions I wrote for OpenSUSE 12.1 64bit using a brand new OpenSUSE 12.1 64bit system.
Everything compiled without a single glitch. No need for additional packages. The instructions provided are complete and sufficient.
@OpenMPI on OpenSUSE 12.1-64bit:
You don't have to logoff nor reboot your system after configuring and compiling OF 1.6-ext in order to run a parallel simulation using the system installed mpirun on OpenSUSE 12.1-64bit .
This is nonsense. And yes, I took the time to test this as well.
@error messages from 'foamInstallationTest':
Have you seen any mention of 'foamInstallationTest' in the build instructions?
You did not because running this script is not necessary.
As a matter of fact, I can't even remember the last time I invoked that rather useless script.
Martin
mbeaudoin is offline   Reply With Quote
Old   August 10, 2012, 13:12
Bruno Santos
Martin,
I've updated the report: https://sourceforge.net/apps/mantisb...hp?id=149#c370
My apologies for not fully checking the instructions myself and delivered that complete log when I did the initial report.
Best regards,
Bruno
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 alberto OpenFOAM 12 July 28, 2010 11:59
Openfoam installation on OpenSuse 11.1 Bufacchi OpenFOAM Installation 1 June 15, 2010 19:55
OpenFOAM Live USB based on openSUSE 11.1 created with SUSE Studio alberto OpenFOAM 40 May 23, 2010 16:15
OpenFOAM 1.6 package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 36 September 2, 2009 12:46
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
