October 21, 2013, 12:30 |
OpenSUSE OpenFOAM-2.2.2-1.x86_64.rpm fails
Ulf
Rep Power: 12 |
Sorry, for such an error message,
but on my machines the installation for OpenSUSE 12.3 / 64bit fails: sudo rpm -i http://www.openfoam.org/download/sus...2-1.x86_64.rpm results in a: error: unpacking of archive failed on file /opt/OpenFOAM-2.2.2/OpenFOAM-2.2.2.gtgz;52644682: cpio: read failed - Keine Daten verfügbar error: OpenFOAM-2.2.2-1.x86_64: install failed I tried several hosts for download (all the same size) and i got the content of the rpm. Perhaps something was not included, as it should be. Fedora rpm is 10MB bigger. Thanks in advance Ulf |
October 21, 2013, 16:36 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Ulf and welcome to the forum!
Well something went very wrong on their side. I've reported this just now here: http://www.openfoam.org/mantisbt/view.php?id=1006#c2568 If you're in a hurry to get OpenFOAM 2.2.2 to work on openSUSE 12.3, I suggest you try these instructions: http://openfoamwiki.net/index.php/In...#openSUSE_12.3 Best regards, Bruno
October 22, 2013, 12:35 |
i586 works now - x86_64 still not to install
Ulf
Rep Power: 12 |
Thanks Bruno (and Sergio and Henry),
that was very fast! The i586 suse version seems to be ok and installs. But but the x86_64 has still an issue, only later: Code:
rpm2cpio OpenFOAM-2.2.2-1.x86_64.rpm | cpio -t ... ./opt/OpenFOAM-2.2.2/platforms/linux64GccDPOpt/lib/libsurfaceFilmModels.so cpio: verfrühtes Ende der Datei (file ends to early) Best regards Ulf |
October 22, 2013, 17:30 |
Bruno Santos
Rep Power: 128 |
Hi Ulf,
That bug report was closed and only the original poster can reopen it I was able to reproduce the same error you got! Feel free to create a new bug report yourself, so that you can reopen it later on, if necessary Best regards, Bruno
October 22, 2013, 19:20 |
Ulf
Rep Power: 12 |
Thanks Bruno,
this issue has now an own bug report: http://www.openfoam.org/mantisbt/view.php?id=1057 |
64bit installation, openfoam 2.2.2, opensuse 12.3 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
OpenFOAM 1.7 - openSUSE 11.3 - gcc 4.5.0 | alberto | OpenFOAM | 12 | July 28, 2010 11:59 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 05:56 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 18:07 |
OpenFOAM compilation fails on applicationsutilitiesmesh | geoffjay | OpenFOAM Installation | 12 | April 29, 2008 15:26 |
