error in installation openfoam 1.6ext
Old   October 25, 2013, 10:18
Default error in installation openfoam 1.6ext
maryam morta
mary mor is on a distinguished road
Hi
I installed the debian pack of openfoam1.6-ext based on the instructions on openfoamwiki on Ubuntu 10.04. After I add alias in .bashrc and run startOF16ext it says that :
bash: /opt/OpenFOAM-1.6-ext/bin/foamEtcFile: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/bin/foamCleanPath: No such file or directory
bash: /opt/OpenFOAM-1.6-ext/etc/settings.sh: No such file or directory
There's no file named by OpenFOAM-1.6-ext in opt directory. Besides I have installed another versions of OpenFOAM 2.0.1 and OpenFOAM 2.1.0.
What's the problem?
I appreciate any help...
Thanks
mary mor is offline   Reply With Quote
Old   October 26, 2013, 00:22
Nima Samkhaniani
nimasam is on a distinguished road
type
which icoFoam
to see whether you install OpenFOAM-1.6-ext or not?
Also it should be noted OpenFOAM-1.6-ext is not placed in /opt directory, as i remember (im not sure) it should be in /usr
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 26, 2013, 06:45
maryam morta
Thanks for reply
openfoam 2.1.0 has been installed.
Yes it exists in /usr/lib directory, but after I want to call it from terminal it gives the errors I mentioned in my previous post. It seems it hasn't been installed.
Doesn't it need to run wmake or anything else? The instruction says it's enough to add alias... to .bashrc
Regards
Old   October 26, 2013, 08:41
Retired Super Moderator
Bruno Santos
Greetings to all!
@Maryam:
It would come in handy which exact steps you've taken to create said alias. And if you created aliases for the other OpenFOAM versions as well?
In addition, have you started a new terminal after installing 1.6-ext?
For more information, I suggest the following blog post: Advanced tips for working with the OpenFOAM shell environment
Best regards,
Bruno
Old   October 26, 2013, 16:36
maryam morta
Hi Bruno,
As I mentioned, I followed the instructions in openfoamwiki,installation of debian pack linked by below:
http://openfoamwiki.net/index.php/In...ucid_10.04_LTS
For 1.6ext verision i added :alias startOF16ext="source /usr/lib/OpenFOAM-1.6-ext/etc/bashrc" to the end of line.
As well for OpenFoam2.1.0 I added . opt/openfoam210/etc/bashrc and it works.
And yes. I started a new terminal after installing! How can I check that it has been installed?!
Thanks,
Best Regards
Old   October 26, 2013, 16:44
Bruno Santos
Hi Maryam,
Uhm... OK. So I'm guessing you have something like this at the end of your "~/.bashrc" file:
. /opt/openfoam210/etc/bashrc
Change it to this:
alias startOF210="source /opt/openfoam210/etc/bashrc"
You will need a new terminal window whenever you want the other OpenFOAM version. For example:
  • To use OpenFOAM 1.6-ext, start a new terminal and run:
    startOF16ext
  • To use OpenFOAM 2.1.0, start a new terminal and run:
    startOF210
Best regards,
Bruno
Old   October 26, 2013, 17:39
maryam morta
thanks Bruno, I changed the code as you said.
Now after entering startOF16ext it says:
/usr/lib/gcc/i486-linux-gnu/4.4.3/../../../../lib/crt1.o: In function `_start':
(.text+0x18): undefined reference to `main'
collect2: ld returned 1 exit status
and when I try to run 2.1.0 version it gives the same error! as in my post #1:
bash: /usr/lib/openfoam210/bin/foamEtcFile: No such file or directory
bash: /usr/lib/openfoam210/bin/foamCleanPath: No such file or directory
bash: /usr/lib/openfoam210/etc/config/settings.sh: No such file or directory
bash: /usr/lib/openfoam210/etc/config/aliases.sh: No such file or directory
regards
Old   October 26, 2013, 17:49
Bruno Santos
That's strange... which Ubuntu version and architecture do you have?
You can check by running:
uname -m
cat /etc/lsb-release
I'm guessing that you did not start a new terminal window...
Old   October 26, 2013, 18:00
maryam morta
I don't know what happened by I once changed the line alias startOF210="source /opt/openfoam210/etc/bashrc" to alias startOF210='. /opt/openfoam210/etc/bashrc" and ran the terminal again and the following happened:
maryam@maryam-desktop:~$ startOF210
maryam@maryam-desktop:~$ startOF16ext
and the same is happening when I changed to the one you mentioned for alias.
I'm using Ubuntu 10.04.3 LTS lucid i686.
Regards
Old   October 26, 2013, 18:02
Bruno Santos
What does this give you?
tail ~/.bashrc
Old   October 27, 2013, 06:53
maryam morta
sorry for late answer. It was time for bed and then university!
It says"
# enable programmable completion features (you don't need to enable
# this, if it's already enabled in /etc/bash.bashrc and /etc/profile
# sources /etc/bash.bashrc).
if [ -f /etc/bash_completion ] && ! shopt -oq posix; then
. /etc/bash_completion
fi
Regards
Maryam
Old   October 27, 2013, 07:53
Bruno Santos
Hi Maryam,
I've finished installing the same packages on a virtual machine with an up-to-date Ubuntu 10.04 i686 and I do not get the same error as you do.
But I suspect I know what the problem really is. Run the following command:
ls -l $(which mpicc) /etc/alternatives/mpicc
It should show you this:
lrwxrwxrwx 1 root root 22 2012-09-28 15:10 /etc/alternatives/mpicc -> /usr/bin/mpicc.openmpi
lrwxrwxrwx 1 root root 23 2012-09-28 15:10 /usr/bin/mpicc -> /etc/alternatives/mpicc
If it does not show you this, then that is the reason why you're getting these problems.
Best regards,
Bruno
Old   October 27, 2013, 12:12
maryam morta
Hi Bruno,
It says:
lrwxrwxrwx 1 root root 21 2013-10-19 16:29 /etc/alternatives/mpicc -> /usr/bin/mpicc.mpich2
lrwxrwxrwx 1 root root 23 2013-10-19 16:30 /usr/bin/mpicc -> /etc/alternatives/mpicc
I have mpicc.mpich2 instead of you having mpicc.openmpi. Is this the problem?
Best regards,
Maryam
Old   October 27, 2013, 13:38
Bruno Santos
Hi Maryam,
In theory, yes, that's the problem. Do you need MPICH2 or can it be switched to Open-MPI as the default MPI?
Best regards,
Bruno
Old   October 27, 2013, 14:36
maryam morta
Hi Bruno,
No I don't need it.But I don't know how to change it.
Besides I have another question. Does the debian pack have any difference with source installation? If not why it is said in wiki that debian installation is better for beginners?
The svn and git seems not to work. So can I use the openfoamwiki.net instruction at http://openfoamwiki.net/index.php/In...1.6-ext/Ubuntu or not?
If not from which repository I should use?
Sorry for asking too much...
Best regards,
Maryam
Old   October 27, 2013, 14:59
Bruno Santos
Hi Maryam,
Well, it's better for beginners, if they have not already installed other software first
And if they have, it's sort-of assumed they have some experience with that other software.
Let's try taking care of fixing this problem with MPICH2. If it doesn't work, then you can try building from source.
OK, it's fairly simple. Run this command:
sudo update-alternatives --set mpi /usr/lib/openmpi/include
Now start a new terminal and try one of the alias commands, namely startOF16ext or startOF210.
Do not forget that you can only use 1 of these alias commands per terminal window!!
If later on you want to switch back to MPICH2 (quoting http://stackoverflow.com/a/18728955), run:
sudo update-alternatives --set mpi /usr/include/mpich2
Best regards,
Bruno
Old   October 27, 2013, 16:04
maryam morta
Yesss. It doesn't give any error, now. Thanks so much.
But I have another problem!
How can I get access to solvers and tutorial files It's different with the other version I had previously
Thanks for your patiance...
Best regards,
Maryam
Old   October 28, 2013, 02:49
Bruno Santos
Hi Maryam,
Run:
echo $FOAM_TUTORIALS
echo $FOAM_SOLVERS
And those two lines should tell you where they are.
For more, try:
export | grep FOAM
Best regards,
Bruno
Old   October 28, 2013, 03:07
maryam morta
Thanks Bruno
Yes I found the solvers folder but when I run echo for tutorials it says:
/usr/lib/OpenFOAM-1.6-ext/tutorials
But there's no such a folder in this directory. when I run : ls -a It doesn't show there's a tutorials folder
Regards,
Maryam
Old   October 28, 2013, 15:57
Bruno Santos
Hi Maryam,
Sorry, I forgot that the 1.6-ext available in the PPA has a very restructured installation, with some missing parts.
Almost 2 years ago I wrote this:
Originally Posted by wyldckat View Post
edit2: these packages are really crazy... the tutorials aren't in the "-doc" package, they are placed in the folder: "/usr/share/doc/openfoam-1.6-ext/examples"
Have a look in that folder. And if it's not in that folder, check this post: http://www.cfd-online.com/Forums/ope...tml#post330283 post #44.
Best regards,
Bruno
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 electrosin OpenFOAM Installation 40 May 31, 2016 05:11
Openfoam 2.1 installation in ubuntu 12.04 jsm OpenFOAM Installation 11 May 7, 2012 04:56
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 superfxfund OpenFOAM Installation 3 November 11, 2010 02:15
Some Query on Installation of OpenFoam lzgwhy OpenFOAM Installation 1 July 15, 2009 03:20
