OpenFoam on debian 7
Like Tree1Likes
  • 1 Post By p0kerus
Old   January 9, 2014, 12:44
Post OpenFoam on debian 7
p0kerus is on a distinguished road
i have finally managed to compile OpenFoam on debian 7 and started working on it , i have anoob question about files i can delete that are redudant after installion of openfoam.Any help apprecited
p0kerus is offline   Reply With Quote
Old   January 10, 2014, 18:29
Retired Super Moderator
Bruno Santos
Greetings p0kerus and welcome to the forum!
It would be helpful to know how exactly you installed OpenFOAM and which version... more specifically, which instructions you followed or at least if you used Deb packages or built from source code.
Anyway, the easiest way should be to remove all non-essential object and dependency files, by running:
foam
rmoall
rmdepall
But the detail is that if you are using the 2.2.x version of OpenFOAM, it will take you longer to build when you update from the repository.
Best regards,
Bruno
Old   January 11, 2014, 16:47
Default Thanks
Thank you @wlydkcat for your warm welcome to the forum , i am using open foam 2.2.2 and third party 2.2.2 , used the instruction used to build open openfoam on ubuntu 12.04 , and installed in /opt directory .And i wanted to remove unwanted files that are not necessary for the installation as i want to make deb file so i can give it to my classmate so they can use it
they all have debian 7 lxde installed
wyldckat likes this.
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
OpenFOAM Foundation Releases OpenFOAMŪ Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 09:07
Debian package for ubuntu 810 deepblue17 OpenFOAM Installation 26 May 5, 2010 07:43
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
OpenFOAM Training and Workshop Hrvoje Jasak Main CFD Forum 0 October 7, 2005 07:14
